Question about Hotpoint WMA66 Front Load Washer
Hotpoint washing machine WMA66
I would like to fit the new door gasket to my machine but I dont know how to remove the old gasket and put new one in . Please help Thank you
  • smugger Nov 12, 2007
    I recently fitted a new door seal for a friend but they beleive that the seal should be positioned differently (they say it is leaking and there is a drain hole which should be at the bottom) Is there a specific position that the door seal should be in?
Thank you gittos73.
It's as gittos says. When you open the door and look inside, at the very top of the door is a white square. This holds the metal clip. If you push the little white dot in the middle of this clamp gently, it gives way and you will see the round metal clip that goes all the way round the door rubber (gasket). Remove this and you can put your fingers round the gasket and pull it toward you.
Then take the lid off the machine and you will see a 6mm nut with a spring behind it and a wire clip similar to the front one, going round the gasket where it attaches to the drum. This has a crosspoint (phillips type) head on it and you can get a small screwdriver into it and undo it all the way. Then slide the gasket off and it will come away.
Fitting it is the reverse but it is a little bit tricky as you have to get the gasket behind the lip to make the seal. Take your time and they will both go round properly.
Posted on May 28, 2008
    Novelist:
    Champion:
  • 244 Answers
To fit your new door seal you open the door there is a clamp holding front off door seal on,this is around the lip of it once you have taken this clamp off the door seal will just need pulling off the front and you will be able to push this into the inside of the drum now take the lid of look to the inside front of your washer were the seal attachs to the drum u will see a clamp around it undo that and then your dor seal will pull out now reverse the order in which u took it of and replace the seal once u have done it u will find it easy the next time m8
Posted on Aug 15, 2007
SOURCE:
Gasket replacement problem, Hotpoint WMF540 washing machine
most I have ever seen have slots in the sheet metal that tabs fit into like slide loc tabs.. this requires sliding the face up or down on the sides.. that may help..these are locked by internal screws that you can take out from tne inside ..
Jan 12, 2014 | Washing Machines
My hotpoint washing machine (model wma50) will not start due to the door lock light flashing yet the door is closed
common problem on these machine's, you need a new door handle which comes as a full assembley with spring and all attached.
open the door, using star screw driver remove top and bottom screws along with two near the catch.
the doo wil split enough to remove old handle and fit new 1.
Oct 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
How do I fit the door gasket
The door boot seal is secured both inside and out side drums.....1st you remove securing ring on the case then the other on inner drum, if its a hotpoint model then remove front panel firstly,if not you should be able to do with mahine switched off/ unplugged and lid removed.. it can be a wee bit trickey.
Mar 30, 2010 | Washing Machines
Hotpoint WMA66 starts to fill but instead of beginning to agitate it begins to spin for a second or two and then drains!
Sounds like a tacho fault. Could be you have a broken wire on the motor circuit. Tilt the machine back and take a look underneath at the wires leading to the motor. This is just to give you an idea if it is a broken wire, you shouln't try to repair it like this, you would need to remove the front panel to allow yourself enough space to affect a repair. For a workshop manual on the WMA66 which would give additional help and advice on dismantling and rebuilding as well as fault finding click on the link.
Mar 17, 2010 | Hotpoint WMA66 Front Load Washer
Fit a new door on a washing machine
You need to remove the wire clamp that holds the door seal on to the front of the cabinet, then pull seal off.
This will give you access to the door hinge assy, then you can replace the door complete.
Please rate my solution.
Thankyou.
Jan 27, 2010 | Hotpoint Washing Machines
How do I change the door seal on my Hotpoint WMA40 washing machine?
It's a push fit seal. Carefully remove the old one and for help, smear the new seal where it fits the machine and just push it into place securely.
Sep 07, 2009 | Hotpoint WMA40 Front Load Washer
Snapped door lock on hotpoint washer/dryer
What you need is a new door latch assy. To fit, remove all screws that hold the 2 halves of the door together, and prize the 2 halves apart, be careful the door glass does not fall to the floor and break.
Fit the new door latch, and reassemble door.
That should solve your problem.
The part is relatively inexpensive.
If you can;t obtain the part locally,then try:
www.hotpoint.co.uk
Plz rate my solution.
Thanks.
Dec 23, 2008 | Hotpoint Aquarius WD63 Front Load...
Changing the door gasket on Hotpoint Ultima WD860
Managed to work it out myself how to take the old door gasket off and attach the new one. Thanks. Machine working okay with no leaks or mould anywhere now.
Apr 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WMA66 Front Load Washer Logo
276 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
