Question about Russell Hobbs Kneading Paddle Blade for 10882 Bread Maker Machine
I cannot remove the paddle from the shaft
It wasnt cleaned propperly and the dough made it sticking to the shaft
    Genius:
  • Russell Hobbs Master
  • 1,280 Answers
First try soaking overnight with enough water to cover the paddle. If that doesn't work go to you tube and type in "how to remove a stuck bread machine paddle" Use a 1 gallon jug instead of 2 to start with, because if you have on of the thin pans 2 gallons might bend it. If that method doesn't work it may be impossible to remove.
Posted on Apr 21, 2013
Remove bread maker shaft
Not sure what you are asking but to remove the paddle you need to perhaps give it a slight twist and pull upwards. It musts be cleaned regularly to ensure it moves freely to mix the dough. If you haven't cleaned it for a while perhaps a short soak in cold water will loosen it.
May 11, 2014 | Kenwood Bm250 Bm256 Bm350 Bm366 Bm450...
Can't remove kneading blade
If you baked bread in it and cannot get the paddle free, put enough water in the pan to cover the paddle and let it set for 5 or 10 min to soak the bread crust that formed between the shaft and the paddle. Then take a hold of the shaft on bottom of pan with hand or pliers to hold it still and try to work the paddle clockwise with other hand until it becomes unwedged from shaft. Sometimes it gets wedged on shaft pretty tight due to the beating against dough ball and cooked bread holds it tightly wedged.
Apr 06, 2014 | Sunbeam 5891 Bread Maker
The paddle sticks to the shaft when removing finihed bread
Clean the shaft AND the inside of the paddle hole until it is 101 percent clean. Give BOTH a shot of non-stick spray when you use the machine.
Dec 15, 2012 | Black & Decker B2300 Bread Machine
My sister gave me a DAk Turbo II. FOr the life of me - how do you get the paddle out to remove and clean it? Robin
Here's the manual:
http://stevebottorff.com/DAK.htm
It's possible that the paddle is stuck to the shaft with dough that has dried. Try soaking the paddle with warm water.
Good luck from Detroit, MI.
Jun 11, 2011 | Vacuums
Lopsided 1.5 lb loaf
This sounds like a mixing problem. Put all the liquids in the bottom, then the dry, and finally the yeast on top so it mixes last.
After the first mixing, the dough should be a ball with nothing sticking to sides.
MEASURE ingredients carefully!
Verify that the paddle turns freely. If it doesn't, then dis-assemble the paddle and clean bearing and shaft. Lube with foodsafe grease before re-assembly.
Nov 14, 2009 | Kitchen Appliances - Others
I have the 5890 Sunbeam breadmaker, I love it except for the kneading blade bakes right in the bread, how can you give a loaf away with that in it?
You can take the paddle out of the bread pan after the last kneading cycle and before final rise. Do this rather quickly if you don't have a pause feature so you don't lose any rising time.
Take the bread pan out of the machine, put dough in a bowl, remove paddle, put dough back in pan, put pan back in machine.
Some people suggested to spray a small squirt of olive oil on the shaft to prevent sticking.
Hank
Aug 29, 2009 | Kitchen Appliances - Others
Can the kneading paddle be removed before baking?
Yes you can remove the paddle before baking. The cuizinart has a buzzer that sounds when to take the paddle out
If you want to take the paddle out you should make sure your machine has a pause feature so you don't lose any rising time.
Take pan out of machine, empty dough into a bowl, remove paddle, squirt the shaft in the bread pan lightly with veg oil (prevents sticking) then return the dough after final kneading time and before final rise.
Hank
Aug 26, 2009 | Kitchen Appliances - Others
The paddle will not stay on the shaft while mixing dough.
Probably the paddle and shaft are worn. Both are replaceable. Buy a new Paddle and a Kneader mounting shaft unit (Part No. ADA 29A115)
Panasonic Parts
National Parts Center at 800-332-5368 between the hours of 9:00 a.m. and 8:00 p.m. EST Monday through Friday.
Nov 16, 2008 | Panasonic SD-YD250 Bread Maker
Russell Hobbs Kneading Paddle Blade for 10882 Bread Maker Machine Logo
Top Russell Hobbs Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
ashburton
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Russell Hobbs Kitchen Appliances - Other Expert? Answer questions, earn points and help others
