Question about HP OfficeJet 7410 All-In-One InkJet Printer
Refilled ink cartridges and level indicators don't work. Thanks Ray
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
You can print until
your cartridges stop printing cause are empty
Posted on Apr 26, 2010
Empty cartridge light keeps flashing
These cartridges don't have anything internally to check for new ink. They simply work on a basis of counting pages and page coverage to estimate ink levels. As such it is perfectly normal for your printer to warn of low ink once the cartridge has been refilled.
A low ink warning in itself should not stop your printer from printing though. If it does it is likely that the light is actually indicating a problem recognising the cartridge after refilling. I would recommend cleaning the copper contacts on the front of the cartridge and checking for any messages on the connected PC or laptop for more information.
Oct 16, 2012 | HP DeskJet F380 All-In-One Printer
Reset a hp 74xl printe cartridge
If this is OEM ink and not Genuine INK then you got to play it by ear. WARNING refilled ink does damage the print head in this unit and can cause undisired effects. If you have been using refilled ink for a while then your damage is already in its begining stages. But the indicator on these cannot be reset to estimate the ink because it does nto have a chip resetter in it. Thanks
Aug 03, 2010 | Canon MX310 Office All-In-One Printer
Canon mx700 not recognizing cartridges
I suspect that your have a damaged refilled cartridge. Also, you may have a clogged nozzle. Canon printers are sensitive to the quality of the ink used in the cartridges and refill ink sometimes does not meet the manufacturer's specifications. You can check this by inserting a new OEM cartridge, running the deep cleaning utillity three times and a aligning the printhead. The other problem may be that the electronic chip on the refilled cartridge may either be damaged or blocked by dried ink. In any case, you need to discard the failing cartridge and replace it.
Let me know if this solves the problem. Thanks.
Feb 22, 2010 | Canon MX700 Office All-In-One InkJet...
How do I reset the ink level indication on a HP F4235 Deskjet printer when using a refilled cartrige?
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Dec 12, 2009 | Office Equipment & Supplies
With new cartridge indicates low ink level,
The ink level gauge may not work properly with refilled cartridges. Because of this, you might get low ink message after refilling. To install the refilled cartridge you might need to override the ink level gauge. Overriding the ink level gauge disables the printer’s ink level tracking feature, but allows you to use refilled cartridges. To override the ink level gauge, please check your printer reference guide. After disabling the ink level tracking feature you should check the ink level visually and as soon as the ink level gets low you need to refill the cartridge. You do not want to try to print with an empty cartridge. Trying to print with an empty cartridge may damage your print-heads.
otherwise you will have to replace the cartridge .
Oct 21, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
MP140 can't recognise the black cartridge that I've just installed. Error code 4 - any ideas? I've tried the manual - nothing, and not much luck online - Thanks
Error code 4 normally indicates that there is no unk, and the solution is by installing a genuine cartridge, Try to use Black PG40 remanufactured Canon printer ink cartridge. This cartridge is a high capacity cartridge which has been filled with 23ml of ink compared with the 16ml (Black) that you get with the originals. Compatible with: Canon Pixma MP140. if this error still occur it is better that you try the following procedure below:-
When you insert a refilled ink cartridge into your Pixma MP140 printer you should get a warning about the refilled cartridge. You should also be prompted, asking if you wish to disable ink level detecting. Agree to do so, and you won’t get the warnings again because the ink levels won’t be monitored by the printer.
Thanks
Oct 12, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
F4280 printer and hp 60 cartridge
keep the cartidge in Hot Water for 30 minutes. maybe it works.
May 30, 2009 | HP DeskJet F4280 All In One Printer InkJet
How to reset the ink level for a HP 60 ink cartridge? I have just refilled a HP 60 black ink cartridge but can not find anything on how to reset the ink level. I would do the "3 ink cartridge" trick but I...
You cannot reset the ink level indicator for the HP 60 ink cartridge. It shouldn't matter anyway because the level is only estimated for "management purposes only" (see user manual) meaning to let you know when it's near time to order a new cartidge. I have tried cycling through 3 different cartridges to reset the ink level for the one I refilled but it didn't work. Refill and just ignore the ink level indicator. Also, it's a good idea to clean the print heads with the solvent in the refill kit before refilling to remove old ink and imrpove print quality.
Apr 06, 2009 | HP DeskJet F4280 All In One Printer InkJet
No ink level indicator after reloading compatible ink.
This is something that's seen in Canon printers as well...
It's highly likely that because the chip has been "told" that it's a certain level and then refilled the printer logic is confused by the much higher level due to your refilling. As a result the printer suffers a sort of conflict and decides it can't trust any of the input and doesn't show any level information.
The only way you're likely to regain the ink level information is to replace the cartridge with an OEM/Original HP.
Jan 26, 2009 | Office Equipment & Supplies
Inkjet refills
hi,
as you are using a refilled cartridge, it is causing this problem. the thickness of ink in a hp genuine cartridge and a refilled cartridge varies. and also the refilled cartridge may make your printer faulty. so it is good to try with a new hp genuine ink cartridges.
thanks and regards
agnel
Feb 14, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP OfficeJet 7410 All-In-One InkJet Printer Logo
75 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
