Question about Motorola For RADIUS P110 7.5v 1200mAh NiCd Battery 2-Way Radio
My motorola radius GP 300 suddenly stoped working, disconnected from programmed network, how can i connect back and sees it working back?
  • Motorola Master
  • 1,654 Answers
GP300 radios will operate either radio-to-radio or in conjunction with a repeater. If your radio no longer works through a repeater, you might check to see if it will work in talk-around mode (radio-to-radio). Check with your repeater service provider to see if the repeater is in working order. One other item which might occur with a repeater would be if your radio is no longer recognized by serial number by the repeater. This is also something the service provider could help you with.
Best regards.
Posted on May 22, 2013
eradiostore
  • 1654 Answers
SOURCE: how to program frequences in a radius p110 radio
The P110 radio is computer programmable. The software is Motorola proprietary, so it is only available to Motorola dealers and a few select types of end-users. The best option is to have it programmed by a dealer. (Just for a cost example: Our dealership does them for $15 plus shipping.)
Posted on Aug 18, 2008
ALLEN CLARKE
  • 47 Answers
SOURCE: gm 300
fequency drifting, software adjustments or manul adjustment or both
Posted on Mar 05, 2009
eradiostore
  • 1654 Answers
SOURCE: How to program
The M1225 mobile is Motorola dealer programmable using the appropriate Motorola software, radio interface box (RIB) and programming cable. The cost for this type of programming is generally $15-$25.
Posted on May 30, 2009
eradiostore
  • 1654 Answers
SOURCE: what is the average charge for programing
On average $15-$25 is what our facility would charge for this type of radio, depending on the number of channels.
Best regards.
Posted on Mar 03, 2010
SOURCE: How to adjust and program the transmit power of
just push the pit butten
Posted on Mar 10, 2010
We order some motorola radius batteries and paid for them they never came what do i do
Hi David,
As you have all the transaction details, you will be able to do things, first of all, you need to contact the company/store you ordered them from and get a good reason for the delay.
Secondly, if within a reasonable timeframe (2 weeks) you still haven't received your items, you can apply to the small claims court for a hearing, to try to retrieve your money.
I hope this helps you.
Cheers,
Peter
Mar 17, 2013 | Radio Communications
I am in need of two batteries for my GP 300 hand held radio`s.
The best price I found for your batteries is on eBay. Here's a link to a current listing:
http://cgi.ebay.com/Battery-MOTOROLA-Radius-GP300-GP388-LTS2000-HNN9628-/290428070271?pt=LH_DefaultDomain_0&hash=item439edca97f
Jan 21, 2011 | Motorola GP300 Compatible 2 Way Radio...
Hello Guys..how to channelize my 2way Radio Motorola Radius Model
The GM300 is dealer programmable using Motorola proprietary software, a programming cable and radio interface box (rib). (Or on some models a ribless cable). I will continue to look for a user guide pdf. If I locate one I will post it.
May 01, 2009 | Radio Communications
Motorola Radius CM 300
The CM300 is programmable using Motorola propietary software, cable and RIB (radio interface box). The software is primarily available to Motorola dealers. The easiest way to have the radio programmed is to take or send your mobile radio to a dealer. Typically programming is around $25 for this unit.
If you provide the model number, it would be possible to give you more information about your radio. It can be VHF or UHF, 25, 40 or 45 watt. You could also google the model number. The model number begins with AAM50...
Jan 17, 2009 | Radio Communications
MOTOROLA RADIUS GP900
Unprogrammed channels will have a constant tone. It is possible your radio is unprogrammed. A dead battery tone is only for a moment, and is usually a medium tone then a low tone, sounding somewhat like beeedeeep.
Dec 06, 2008 | Radio Communications
Motorola gp 63
The GP-63 and the GP-68 uses the same users manual. You can download the user manual which also has programming and cloning information in it from:
http://www.batlabs.com/2way.html and choose GP-63......Good luck
Oct 23, 2008 | Radio Communications
How to program frequences in a radius p110 radio
Aug 17, 2008 | Motorola For RADIUS P110 7.5v 1200mAh NiCd...
Gp 300
Did the radios previously work together? If so, you have one radio in need of repair.
If the radios are new to you, and you do not know if they previously worked together, it could be a simple programming problem. Take it to your local Motorola dealer to check the programming.
One simple test to see if you have one with PL and one CSQ, is to press the monitor button and see if the two radios can communicate when they are in open squelch mode. (The monitor button will be one of the side buttons near the PTT.)
Jul 17, 2008 | Motorola GP300 Compatible 2 Way Radio...
Motorola GP300
The Motorola GP300 needs an external device to program the frequencies assigned to the channels. All other features and functions are also accessed (enable/disabled) in the same fashion.
To start with, you would need programing interface that attaches to the back of the unit once the battery is removed. This also provides the power to the radio as well as the data connections. The interface is called a Radio Interface Box (RIB). Aside from the power leads, it has also a multi wire cable that is terminated with either a 9pin or 25pin serial plug that plugs in to the serial port of a PC.
Likewise required is a specific Radio Service Software (RSS) package(s) that is appropriate for a Motorola Radius GP series. This should be run on a personal computer capable of running pure DOS.
On running the RSS, all parameters can be adjusted and configured to your preference like Ch1 to be set to 456.789 MHz, CTCSS 108, etc. Having said this, then it is just a matter of repeating the programming to all of your radios.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 31, 2008 | Motorola GP300 Compatible 2 Way Radio...
Radio Communications Logo
71 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
bill tarkulich
Level 1 Expert
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
