Question about Health & Beauty
I have a Komfi-Rider 6000D and the diagnostic light flashes 5 times and then stops before starting again, all battery charge lights read full but the scooter does not go. What could be wrong?
  • 118 Answers
SOURCE: Scooter has full charge but still won't go.
It probably means that the connections or wiring from your battery are loose or broken. When you add the extra current required to run the motors, the voltage is being lost. Monitor the battery voltage with a meter while trying to drive the scooter will prove this.
Posted on Nov 27, 2008
  • 103 Answers
SOURCE: sudden stops
Sounds like the brake. Ohm chech the brake (it is attached to the end of the motor). It should be around 35 ohms
Posted on Mar 09, 2009
  • 945 Answers
SOURCE: shoprider cadiz scooter, batteries show full
I think your batteries haven`t been charged properly,or they have been left standing so the charge has leaked out.At a minimum your batteries need to be charged for 12 hrs a day for the first month if not they will not build the capacity and will dwindle and die for example it is at only 25% capacity,but looks like a fullcharge, it says it fully charged but will die
quickly this happens because it is charged to its full capacity but that is only 25% of the batteries true potential
resulting in short battery life.
Unfortunately majority of scooter batteries like this have to be newly replaced.
Posted on Nov 06, 2009
  • 23 Answers
SOURCE: electric mobility scooter says charge is full but won't run
This sounds she has tripped her circuit breaker. It works just like the one on your house, when you ask too much of it it suddenly goes 'pop' and seems to be dead.
Looks like you have the same scooter as mine, it should be a little white button on the back of the base. If you follow this link, it will give you a pdf version of the older model pride victory manual, (Mine is a three, they are up to about 10!) See fig. 8 on page 20 and 'Circuit Breaker' on page 21. Also, Page 33 has the troubleshooting info. Hope this helps.
http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Victory%20Owner's%20Manual.pdf
Posted on May 06, 2010
  • 177 Answers
SOURCE: Golden Companion Scooter not moving - diagnosed via owner manual
Hi. Many scooters will display this fault code if the potentiometer is not exactlly centred when you turn on the key. The pot is not always faulty. Some scooters also have a smaller additional pot to controll the speed. If this pot is faulty it will cause the same fault code. Any other switches such as indoor/ outdoor switches. I have had a few machines fitted with curtis controllers where the fault is in the controller.
Check the wiring and plugs and connectors.
Good luck. Neil.
Posted on May 30, 2010
I have a Pride Sundancer that will usually go forward but not reverse. Green light flashed 3 then 5 blinks. What is the problem
Hi charge batteries & get them load tested ..U can buy a BATTERY LOAD TESTER of E/BAY cost aprox $36 this will give U an accurate reading on there condition,.3 flashe's unplug charger & turn key of & back on ..5 flashe's remove key push freewheel lever into freewheel & back into drive put key back & try it . Cheers
Nov 30, 2016 | Pride Health & Beauty
It cuts out, the light flashes, switch it off and back on it will go again, it seems to be ok on a long run but plays up when you have to keep stopping and starting. Batteries are fully charged.
Ken;
The lights flashing are a flash code, count the number of flashes and consult your owners manual. or you can repost. Make/Model are needed to get the best answer. Or check My app for answers. Scooter Doctor App .
check tire air pressure, make sure the rider is not over the weight capacity.
P.S. hope this helps.
Dec 31, 2015 | Health & Beauty
Chair shows full charge, or most of a charge (depending on how long it sets between looking at it), and has limited mobility for a while, after sitting turned off for several hours.
Hi if the batteries r 5 years old it would be a good idea to replace them ...u can't rely on you're charging circuit giving u a true reading on the condition of you're batteries they have to b tested with a BATTERY LOAD TESTER they put a 100 amp load on them this will give u a true reading on the condition of you're batteries ..cheers
Sep 10, 2015 | Pride Jazzy 614 Hd JAZZY 614HD
Greetings Gurus. I have Makita charger model DC18RC, battery model is 18v BL1815...manual is of limited help. I'm trying to understand what the indicator lights mean, what the time is for charging,
I agree that the pictographs are not very helpful. You probably have one of the new chargers. I have an old one, which is a little easier to figure out.
From top to bottom
1. The flashing green light with the electric plug indicates that the unit is plugged in and ready to go.
2. The flashing red little fan means that the battery is too warm so it is just cooling it and not charging it at that moment.
3. The solid red empty battery outline means that it is charging but hasn't got very far, less than 80% full.
4. The mostly full battery outline with both solid red and green lights at the same time means it is 80% full or more
5. The full battery outline and solid green with the musical notes means it is full up.
6. The broken battery outline with flashing red and green means you've got a broken battery.
7. The yellow light with the wrench means the charger is "conditioning" the battery, whatever that means.
8. The yellow light with the fan means "cooling abnormality."
Hope this helps
Nov 01, 2014 | Drills
TRIED TO START 2002 DYNA LOW RIDER. turned key on,run switch to run and hit satr it turned over and fired once then nothing ,did not click or turn over when hitting start. waited a while and tried again...
Make sure battery has a full charge and both positive and negitave battery connections are clean and tight.Make sure unit is in nuteral and try to crank. If engine wont crank check starter selonid or relay. MAKE SURE BATTERY HAS A FULL CHARGE.
Mar 16, 2014 | 2002 Harley Davidson FXDL Dyna Low Rider
2007 dyna glide low rider with 4000 miles .. I was riding for a hour then stopped and fueled with gas then rode 20 mins more and it just lost power and wouldn't start
Any error codes?
1- Turn Ignition switch to OFF, Run/Stop switch is to Run.
2- Push odometer reset button in and hold.
3- Turn ignition switch to Ignition and release odometer reset button.
Background lighting should illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word "diag" should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module (EFI) / (Ignition Control Module, 'Carbureted')
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC's the code will be displayed or the word "none" will appear if there are no DTC's. If there are codes present, push the odometer reset button again to view additional codes if they
exist.
7 - Record the codes.
8 - If DTC's are not to be cleared, Press and release the odometer
Feb 21, 2014 | Harley Davidson Motorcycles
Orange light flashing, no chargine
A replacement battery must be the EXACT same power spec as the original in DC volts and Milliamps, or you could damage the Mobo components. Some aftermarket batteries do not work well. The connections may be different.
Jan 31, 2013 | Dell Latitude E5500 Laptop
Have a 2006 Heritage Softail - Was running when speedometer & odometer quit working and key light came on - not engine light. Stopped at gas station - when down shifted to stop things started working...
Hi Johnrobindan, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections check negative cable at both ends. (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
For a prime suspect please visit website below and good Luck.
Harley Diagnostic Codes 04 to Present
Aug 24, 2010 | Harley Davidson FLSTCI Heritage Classic...
I have a komfi-rider 6000 i,ve had it on charge all night but it has,nt charged, what could be wrong.
Is your charger light on - i.e. is your charger working? Otherwise you may need new batteries....but take a note of the details on the battery and search around on the net for generic ones - much cheaper than the original make!
Nov 26, 2009 | Pride New Mobility Legend 4 Wheel Scooter
91 chevy 1500 ac light flashing
try disconnecting the negative battery cable for ten minutes to reset the computer.
good luck
Jun 24, 2009 | 1991 Chevrolet K1500
Health & Beauty Logo
576 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
