Question about Kirby Heritage 2 and Legend Vacuum Cleaner Cord 32 ft Black, 192084
Cant get pin in kirby legend 11 handle,the main body seems to have shifted /
The metal tube inside handle aperture appears to have broken and the chassis has moved slightly covering the opening for the handle pin.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 88 Answers
You will need mole grips to pull out handle pin.
Posted on Apr 29, 2014
4 Suggested Answers
SOURCE: I wish to purchase a
Contact www.stevessewandvac.com via email they will be able to help you with the fan.
Posted on Aug 13, 2008
SOURCE: Kirby Legend 2 Vaccum cleaner
Did you ever find a use and care book for this vacuum.  I have one I could scan for you.
Posted on Feb 09, 2009
RockyNR1
  • 324 Answers
SOURCE: G5 Kirby drive problem
There might be a problem with slide assembly. Some free movement is OK but sometimes the slide sticks and Kirby "keeps going".
See THIS article
Rocky
Posted on Sep 19, 2009
Kirby g5d will not shift into drive
check tech drive sensor, where handle connects to main unit, but you need to open cover off and greese handle slider.
May 08, 2010 | Kirby G5 Bagged Upright Vacuum
My Eureka Optima vacuum handle broke right at the metal tube.
I have exactly the same problem. I plan to drill a hole in the handle through plastic and metal, and then pass a metal pin to hold them together. I don't rotate the handle much, so the loss of handle spin functionality will not be a major issue for me.
Aug 05, 2009 | Eureka 431A Optima Bagless Upright Vacuum
Kirby Legend 2 Vacuume cleaner
call Francois Gordon 27 11 476 1235
Rocky
Jan 03, 2009 | Bosch Turbo Jet Bagged Upright Vacuum
I have a kirby legend 11, the long handle is loose, how do I tighten it please?
If it is not staying up the handle falls down then is caused by the handle spring assembly. Replace the assembly and it should do just fine. There about 7 different components inside the shell, it's usually the spring but after so many years the bushing and shaft could be bad as well. Recommend to change the whole assembly and it does require a specialty tool to tension the spring assembly.
Nov 03, 2008 | Vacuums
Gary...
You need to adjust your transmission. Here's a link that may help...
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
Marci
Sep 05, 2008 | Kirby G5 Bagged Upright Vacuum
Hi I am looking for some where to get my kirby legend 11 vacuum cleaner serviced and probably a new brush head for it thanks
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=722285
Generic problem for all Vacuums
Hi I am looking for
Posted by libbit1 on Jun 30, 2008
Hi, I am looking for some where to get my Kirby Legend 11 vacuum cleaner serviced and probably a new brush head for it thanks.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. In most cities there are factory authorizes Kirby Vacuum dealers that also do service in most of the big cities other wise there are your local vacuum cleaner dealers in your area that also do service on the Kirby vacuums. When referring to the brush head are you asking for the bell housing or the brushroll. The brushrolls are very available @ either dealer but the bell housing that the brushroll fits into you probably will need to get that from the factory or the local vac dealers may have a good used one for less money or ½ the cost of a new one. Just a suggestion for you. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 30, 2008 | Vacuums
Kirby generation3 instructions,
Hi there!
If you are talking about the main sweeper attatchment, Lift the light at the front of the upright machine, Make sure the belt inside the sweeper it is over the hook when you turn the handle on the front anti-clockwise to "belt off". Turning handle raises belt.
The hooks at the bottom of sweeper go over the bar at the base of the body. It helps to lift the wheels slightly.
When hooked on, rotate handle clockwise to "belt on" and close the light cover.
Is this solves the problem , please take a moment to rate as Fixya! If you need more help, just ask again on this question.
Thank you.
Jun 19, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Legend 11 Kirby, sometimes will not turn on
Could have a problem with the motor, may need carbon brushes, or other motor related parts. If the light turns on and off with the switch, then the switch is probably ok. There is a speed switch inside the motor casing that could be bad.
Feb 21, 2008 | Vacuums
Kirby Heritage 2 and Legend Vacuum Cleaner Cord 32 ft Black, 192084 Logo
48 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
