Question about Ovens
Modern maid new line
Manual
  • 833 Answers
SOURCE: how do you clean an
Generally, there is a latch which closes the door on some units...on others it is electrically actuated.  Turn the controls to clean.  Generally, there is a function control and a temperature control which must be activated.  This will latch the door electrically.  A two hour cycle is about right for most soil, if you're given a choice.  Ventilate the area...it smells!  The door will unlatch about half an hour or more after the cleaning stops.
Posted on Nov 26, 2008
SOURCE: Modern Maid Wall Oven DGO757 ignitor gets
I have a Modern Maid Wall Oven and the pilot light waant stay lit. What's the best solution?
Posted on Jul 20, 2010
e-Guru
  • 3917 Answers
SOURCE: I do not know how
The self cleaning feature is quite complicated for which you need to follow the owner's manual. If you have problems with this system, call a skilled repair person.
However follow the bellow instruction if it helps:-
First turn off the oven and allow it to cool.Then remove the oven racks, broiler pan and any other items from inside or on top of the oven, and from the storage drawer.Wipe the inside of the oven door edge using a cloth dampened with water. Wipe the inside 1 1/2-inch area around the edge of the oven cavity frame. Don't clean the gasket.Now close the oven door, and press the "Self Clean" button in the control panel.You need to press the "More" or "Less" arrow buttons to choose a cleaning time and level. The options range from 2 hours and 30 minutes to 4 hours and 30 minutes, available in 15-minute increments. You can choose light, medium, or heavy, depending on the amount of soil. The cleaning cycle starts seconds after choosing a level. Choose the time based on the amount of soil. Now press the "Start" button to begin the cleaning cycle. The oven door automatically locks and stays locked until the cycle completes and the oven cools down.
When the auto clean function is finished and the "Lock" message turns off, unlock and open the oven door and wipe out any ashes using a cloth dampened with water. Replace the oven racks and any other items.
Hope this helps
Thank you for contacting Fixya.com
Please get back to us if you have any further query.
Have a nice day.
Posted on Nov 09, 2010
emissionwiz
  • 75822 Answers
SOURCE: Modern Maid model QKU-739 Gas Town House Range and
Hello
Well this is very simple, if the oven won't go on it is not an input problem from you if you set the temperature it goes on automatically, so if it won't light you most likely will need to have the oven tested, it is very likely that one of the following has failed, the Gas Valve or Gas Valve closing coil, the Electronic Igniter (lights the gas burner) or the the Flame sensor, to test these requires a service technician or a high degree of skill of testing procedures for electronic components.
Posted on Nov 25, 2010
Daniel S
  • 4323 Answers
SOURCE: How do I remove the
Hi
Please click on this link to follow the step by step instructions that will help you in removing the door. Hope this helps...please post back for further assistance.
Daniel
Posted on Sep 19, 2011
I have an old Modern Maid double oven. DK 0757. Broiler comes on everytime I try to heat for baking. Any suggestions
It was common for the broil element to come on during the preheat time on older oven controls. When the oven reaches temperature the broil should shut off. If this just started then the points in the broil switch section are welded together and the oven thermostat will need replacing
Mar 20, 2015 | Ovens
HOW DO I KNOW IF MATSUI OVEN IS SELF CLEANING?
If it doesn't come with a little maid type female with a scrubbing brush and rubber gloves, you have to clean it....
Jan 11, 2015 | Ovens
I have a modern maid double wall oven (gas). I set it to clean last night (at 3:00AM). It is now 12:PM the next day and it can't unlock it. What should I do?
Try turning the main power off to the house for 5 mins and turn it back on see if that reset your oven.
Jan 01, 2015 | Ovens
Modern maid toaster kbt 100
thay 2 soi day moi vao
Feb 17, 2014 | Ovens
Euro maid sc1531 oven door dose not close at the top
Did you solve your problem???? Cause I am having the same problem :( I would really appreciate it if you could let me know Thanks
Jul 04, 2010 | Ovens
The electric power to my house was temporarily interrupted, and since it was restored my Modern Maid wall oven has not worked. The timer and griller work, but the wall oven does not. Does the oven need to...
The timer is 110 volt, and the grill may also be . The oven, however, is 220 volt. Suggest you check your main circuit breaker box and reset the breaker set marked "oven" or something similar. This would be the exterior breaker box where power comes into the home.
Nov 14, 2009 | Ovens
Modern Maid Wall Oven DGO757 ignitor gets orange,but does not fire oven.
HI, there are gas valve coils that initiate the opening and closing of the gas valves. these coils will become unstable overtime. if the coils are malfunctioning, it will cause the symptoms you are experiencing with your oven at this time. i recommend replacing the failing gas valve coils asap if possible.
It should be two or maybe three coils that are attached to the valve assembly(burner assembly). they are black and, cylindrical in design. replace these coils.
Jun 10, 2009 | Ovens
How do you clean an oven with the clean control knob. We have a modern maid
Nov 26, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
