Stirling washing machine xqg65-908e door won't open
Andriod Man
  • 271 Answers
SOURCE: does anyone know what an
look in your manual if you have it. also there should be a schematic inside the washer probably with the codes in it. this is mainly sold in Australia so I dont have a way to know.
Posted on Feb 05, 2011
bunnydawg
  • 5158 Answers
SOURCE: My door won't open on
unplug the machine for about ten minutes and then try to open the door after you plug it in. If the plug is not easily accessable, locate the fuse in the fuse panel for it. i may add after you have interupted power to the machine, you may want to try opening the door then.
Posted on Jun 12, 2011
  • 6277 Answers
SOURCE: Our Haus hw50-1010w washing machine
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 03, 2011
Daniel S
  • 4323 Answers
SOURCE: The washing machine goes through
Hi
The issue is with the drain pump that is clogged/kinked, as it won't drain the water the door won't unlock. If this is a front load washer then take the lower access panel out and clean the drain pump assembly. Hope this helps...please post back with its complete model no for further assistance.
Daniel
Posted on Jul 28, 2011
brian83320
  • 3 Answers
SOURCE: The door is jammed on my LG Intellowasher
Slide a paint scraper or similar between the machine and the latch side and push it quite hard and it should open. Mine does and I found the fix on this site!
Posted on Aug 13, 2012
Can i stand my Stirling dryer on top of my Stirling washing machine
Other than marring the finish and having the vent hose being seen, or not being able to use the controls. No.
Mar 28, 2014 | GPS
HNL 6146 door won't open
Has it emptied all water out ??
Jun 18, 2013 | Hoover Washing Machines
GLTF1240ASO Front Door Won't Lock/Close
Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it.
You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
Jun 04, 2013 | Washing Machines
The door on my Hotpoint Washing Machine WT741 won't open even though the programme has ended. We've tried running the programme again and pumping out but still the door won't open.
The door latch may have broken. You can sometimes open the door from the inside. You will know the door latch is broken if the door handle is floppy. If the door handle is not floppy - then the issue is probably with the door interlock. This is the electronic part that prevents the door from being opened during and after the wash has finished.
Either way - you'll need to get the door open.
To do this, unplug the washing machine from the mains and then move it out from where it is. Tip the washing machine to a 45 degree angle. Don't tip it over 45 degrees as you may break internal parts.
You need two people to do this - one person hold the machine at 45 degrees angle, whilst the other person puts their hand up into the machine - you should be able to feel the door catch mechanism and depending on the model, open the door that way. Sometimes the manufacturer has helpfully put a manual release inside - and sometimes they don't.
If you aren't able to open the door using that method. Get a length of strong string and poke the middle section of the string into the gap between the washer door and the machine body - to the right of the door handle. Use a flat headed screw drive to push the string into the gap, all the way around the door, so that you end up with the two ends of the string on the left hand side of the door. Now have someone put the ends of the string whilst the other person pulls the door handle. If the string is pushed in far enough it will release the door latch and the door will open. It takes a bit of persistence to get it right.
Once you have the door opened you can usually replace either the interlock mechanism or the door latch itself. Parts are easily available online from sites like espares and yourspares.
Mar 29, 2013 | Washing Machines
W6444 washing machine door won't close
Try some WD40 spray on the door and lock. Just a bit. Try closing and opening the door. The machine should be in the <off> position.
Mar 16, 2013 | Asko W6021 Front Load Washer
My servis m6011 5kg washing machine door won't
Possible that the door lock has jammed and so is not working.please check this link: door lock
Jul 03, 2012 | Washing Machines
Door won't open and is jammed.
We have an electronic Sears front load model with which that happened. . If this is a Sears machine contact the service number located in your manual and they should be able to talk you through it. For us it ended up being a door switch that had become misaligned. Make sure the machine spins the water out of the tub before you try to open the door if it is a front loader.
Apr 02, 2012 | Amana Washing Machines
Front loader washing machine door won't open
try unplugging the machine to reset it.
Feb 27, 2012 | Samsung Washing Machines
Thor front loading machine door won't open.
Please check the link below to see how the door can be opened. Once this is done the program controller section must be checked for proper cycle of the functions.
http://www.espares.co.uk/advice/washing-machines/a/7/1294/how-to-open-a-washing-machine-door-thats-stuc.html
Aug 22, 2011 | Washing Machines
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
