Question about YouTube Videos
When a 0.998g sample of CuSO4.xH2O was heated strongly,so that the waters of hydration were given off,the mass of the anyhydrous salt remaining was found to be 0.638g.What is the experimental value of
Goes to 88888 no matter what. How do I fix that?
Are you over 330 pounds? If not, remove the batteries and count to 10 and replace them.
Description Item # 00835165000P Model # 4GNC25302 The GNC WirelessWeight GS-7006 Digital Bathroom Scale accurately measures weight, body fat, water hydration, bone and muscle mass. This item features a removable wireless display that can be conveniently mounted on the wall, so you can see the readout clearly. Built with durability in mind, the scale is made from extra-strong tempered safety glass. The GNC bathroom scale also features an energy-saving auto on/off function and auto zero.
  • Removable wireless wall mount readout display
  • Measures weight, body fat, water hydration, bone and muscle mass
  • Energy-saving auto on/off and auto zero
  • Extra-durable tempered safety glass
  • Weight capacity: up to 330 lbs
  • Requires one 9V and 2 AAA batteries (included)
Apr 28, 2016 | GNC Digital Bathroom Scale
What are the measurements and instructions for wormwood, black walnut and cloves?
of digestion, taking and absorption of many vitamins which can be crucial to building muscle. Not being properly hydrated can cause dramatic decreases in power. It's been proven that often little dehydration quantities of 5% can cause up-to strength reduces up to 15%! With dehydration able to have this type of bad impact it pays to become sampling on some water.Tips About How To Build Muscle Mass
http://advancedtrimsite.com/megadrox/
Apr 09, 2016 | Cars & Trucks
The low salt light is on and is not making chlorine. Salt level topped up yesterday as per pool shop sample. Chlorinator stopped sometime yesterday
the salt light indicates more than low salt level. now that you have eliminated that possibility, if the light is still on, there may be several possible causes. the cell may be dirty, or nearing its end of life, there might be restricted water flow or the water is too cold. these are all easy and inexpensive to check
Mar 06, 2016 | Pool & Spa
How do i reset my digial bathroom scale
Remove all the batteries. In ones with memory, there are two sets, a 9 volt and 2 x AA.
Jul 16, 2015 | GNC Digital Bathroom Scale
Can we give gatorade to a dog that has tapeworms
Check with a Vet,but gatorade contains electrolites that serve well to hydrate the dog,,,but other than the added salt,and other minerals,potassium and such ,no different than water
Jun 07, 2012 | Sport & Outdoor - Others
Nokia 6300 dead after falling in water
Don't turn it on! take the battery out.
ok.
now you have a few options.
(1) Put the phone and battery in uncooked rice for two or three days. The rice will absorb all the water and you should be able to just charge it and turn it back on unless it shorted out.
(2) Take the battery out and drop your phone into a Methyl Hydrate or isopropyl alcohol bath. This is what most repair shops will do. it only needs to be in the solution for a minute or so. Take it out and shake out the remaining liquid and dry it with cue tips and paper towel. This method will force any remaining water out of the phone quickly and very effectively wait at least three hours for the remaining methyl hydrate or alcohol to evaporate (be sure before you plug it in). Charge the battery then (if the phone didn't get fried) it should turn on as normal.
Mar 03, 2012 | Nokia Cell Phones
I have recently replace my salt cell after 6 yrs and now I'm getting a "high salt amps reading". The pool is 20,000 gallons and I installed a T-15-Cell. My salt level says 3900ppm but my...
I would first clean the cell according to the manual. If a small amount of conductive material in across the cell plates cleaning may remove it. Then I would use an independent method of testing the salinity. This could be bringing a sample to a pool supply store. I would use this value to determine whether to add or remove salt. One thing that can affect the equipment's indication of "high salt amps reading" is temperature. Many pool owners are having this indication with very high summer temperatures. Using a lower salinity with high temperatures could help. The main thing is to keep the chlorine concentration to between 2 and 4 ppm.so your pool remains sanitary. Make sure the stabilizer level is correct and circulation is good. I hope this helps.
Please vote on this answer. Thank you.
Aug 24, 2011 | Hayward Pool & Spa
We have a water softener and I think the water has too much salt and therefore, our Vicks vaporizer has too much steam. Any suggestion?
If your softener is working properly, you should never get any salt in your water. The salt is used only to reactivate the ionic media in your softener cartridge, and during the backflush cycle, all that salt is removed, down to PPM (Parts Per Million) levels.
In any case, even if you used salt water in your vaporizer, it would not increase the amount of steam that it produces. Salt water has a higher boiling point than fresh water. You would also notice salt buildup inside the tank as the water level goes down.
The Vicks Vaporizer works by using only heat to produce steam- the hotter it gets, the more steam it makes. The only practical way to get too much steam outside of a malfunction that causes your heating element to get abnormally hot would be if you live at a very high altitude where water boils at a lower temperature.
High humidity in your home will make it appear as if your vaporizer is making too much steam since the surrounding air will be less capable of absorbing it.
A slightly "off topic" note- if you chose the Vicks Vaporizer/humidifier and have children, you have made a wise decision. Because it produces water vapor by heating instead of ultrasonics, contaminants and minerals (such as salt, iron, calcium, etc.) remain in the tank and will not enter the vapor stream.
Mar 25, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
We are having trouble with our pt cruiiser.. it will turn over and not hit a lick... we have checked fuses, checked for fire from distributor cap, and we have sprayed ethanol in carbarator and it will not...
You say you have used ethanol. I don't know if you also putit in the gas tank as well as the carb. However, regular of the shelf ethanol from a paint store is not the ethanol to use. hat ethanol is hydrated, ( has water in it ). You need to use anhydrous ethanol or gaslineanti freeze. asfar as what to put down the carb, you should be using quick start. ( Tha is ether and is very flamable!!!! ) only spray that while turning the engine over. To check what that clear fluid is in the tank somehow take a sample of it and try to disolve table salt in it. If is it oil the salt will not disolve. If it is wate it will. Please don't just put the salt anywhere near the carb. or the gas tank.
I suspect it is water because oil and gas mix. water and gas do not. The anhyrous ethanol in the tank will adsorb the residual water and mix with the gas and burn off in the cylinders.
Good Luck!
Jan 16, 2010 | 2006 Chrysler PT Cruiser
YouTube Videos Logo
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
Michael Terence...
Michael Terence...
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
