Question about Thermador M271ES Electric Single Oven
E005 Communication error
Oven will not clear this error message
Got this error this morning and it cleared when I turned off the circuit breaker and turned it back on.
Oven is now working
Posted on Mar 14, 2009
I have Neff double oven the top oven has the fan going and this is displayed in the clock area
This is what was posted on another site, hopefully it will help you.
E005 indicates a communication problem.
Basically, the electronic boards were unable to talk to each other.
If powering off and back on cleared this then it's likely it was a software glitch and "rebooting" sorted the problem out.
If it does happen again and won't clear, you will need to check the wiring between the boards inside the appliance and possibly replace the boards.
You can't prevent spikes in the mains that may cause spurious errors I'm afraid. (which is what I think may have happened in this case).
Hope this is of some help
Let me know how it goes or if you need more help
Thanks
Jan 31, 2017 | Neff Ovens
Have a neff oven U14M42.3gb, tried using the preset operation mode to cook whilst out. But when I set it up the cooling fan stays on, all the videos and instruction say it should switch off.
This was posted years ago on another site, hopefully it will help you too.
Thanks
Jan 29, 2017 | Neff Ovens
Error message F6E6.What does this mean?
Although fault code "F6E6" most often indicates a communication failure between the User Interface and Appliance Manager board (Service Pointer W10538518), it could also indicate an incorrect electrical connection at the customer's home junction box. Sounds like you have some wires crossed!
Oct 18, 2014 | KitchenAid Architect ® II KEBS208S...
Gaggenau oven BO 270 error code E005
We have a Gaggenau BO250/251. It gave error code E005, and after a lot of frustration, we opened the left hand light (NOT the light at the top of the owen) and fiddled a little with the bulb. And voila, the owen worked again.
Stupid design to disable the owen when the light does not work. Bravo, Gaggenau....
May 19, 2012 | Gaggenau EB 270/271 Electric Single Oven
Error message f23
it is a mis-communication between the panel and the timer. You have to turn off the power (throw the breaker) to the oven and leave it off for one minute. When you turn the power back on the oven should reset itself. If you can't turn the oven on then a service call is needed. My oven came on and I was able to use it after that.
Jun 13, 2010 | Electrolux ICON Designer E30SO75ESS Oven
We just plugged in our oven and it has E005 Communication error popping on the screen. Any ideas?
1. Turn the clock selector knob to OFF
2. Tweak the oven control by turning the clock selector knob slightly to the left (counter clockwise).
This may stop the popping message.
Thanks
May 31, 2010 | Bosch HBN5650UC Electric Double Oven
I have an E11 message when i wan to put on clean cycle
Turns heat off on failed oven only, micro not affected. Tweaking clears to "---" for retry.
CT oven; latch switch problem solution:must be cleared by turning off the oven at the circuit breaker and then turning it back on. if the error remains displayed steadily in the off position, after attempting to clear the error then check or replace the latch switch
Mar 31, 2009 | Ovens
Unable to clear error message on panel...oven not operating
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#RET
Nov 25, 2008 | Whirlpool SB160PEE Gas Single Oven
Thermador MEM301- E005 Error
turn off the circuit breaker and turn it on again 30 seconds later... this oven is a total waste of money...never buying another one of these again.
Dec 16, 2007 | Ovens
Thermador M271ES Electric Single Oven Logo
1,290 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
