Question about Konica Minolta magicolor 2430 DL Laser Printer
Printer will not pick up paper from paper tray?
The printer will not pick up paper from paper tray
  • 4 Answers
There is a knurled roller in the back that comes down and grabs the paper. You can visually see this when the printer cycles or / and u can see it if you remove the Drum cartridge (the green handle), it is about 1 inch long and centered on a steel rod. Use some denatured alcohol or rubbing alcohol and clean this using a lint free cloth or a q tip if it will reach. This will soften it and give it some more stick ability!
Posted on Mar 12, 2009
MY PRINTER CAN.T PICK PAPER FRM ALL TRAY
What printer is it? What factory and what model?
How many trays does it have and from how many can it pick paper?
When you try to pick paper from the bad trays what happens? Are there any noises, or what?
Is problem new, or has the printer always behaved that way?
May 19, 2016 | Office Equipment & Supplies
Printer wont pick up paper even though the paper tray is full
There probably is a small piece of paper stuck in the paper path. Please take the ink/toner out of the machine and check the paper path. Please turn off the machine before doing this.
Jul 09, 2015 | Office Equipment & Supplies
OfficeJet Pro 8600 will not pick up glossy photo paper from the tray
I tried everything that was suggested on the HP forum but then tried something not reccommended there and it worked. Not only remove tray 2 from the printer properties but force the print to tray 2, when you this it sets the Quality from normal or Best to Custom. Once I done that it worked... Just disabling the tray 2 is not enough.
Mar 26, 2012 | HP OfficeJet Pro K8600 Printer
I AM USING HP LASERJET PRINTER 2300dn and im experiencing jam, what is wrong with the tray?
I think it not the paper tray. It is the paper pick-up roller. When the rollers get dirty or worn-out, the printer fails to pick the paper, which results in paper jam. So, remove the paper tray and toner cartridge and locate the paper pick up roller in the middle. Clean it with luke-water and lint-free cloth. I hope this would fix the issue
Hope this helps! Good Luck!
CreativeTECH
Jan 07, 2011 | HP LaserJet 2300dn Printer
My printer, HP injet 1410, could not pick up the paper. Can you tell me what the problem is.
I assume the printer is making noises and moving, TRYING to pick up the paper...
If so, there are 3 possible issues:
1) you have too liittle paper in the paper tray. Add more paper so that the tray is full to around 3/4, not less.
2) You may have too much paper on the tray. Remove some paper from the tray untill the tray is around 3/4 full, not more
3) The rubber rolls that pick up the paper may be dirty with paper dust or dirt. Put 2 drops of alcohol on q-tip and carefully clean them. Let dry 30 mins. before trying to use the printer.
Mar 26, 2010 | HP PSC 1410 All-In-One InkJet Printer
The printer will not pick the paper from the lower tray. It tries to pick the paper from the upper tray even though it is set to auto pick the source but will not pick from the lower tray.
Hello, just clear paper pick up roller.
Open front cover, remove toner cartridge and you will find paper pick up...use wet cloth or alcohol to clear it... Good luck!
Oct 29, 2009 | HP LaserJet 1020 Printer
Printer will not pick paper
As a test, please try to print something using paper in the manual feed bin.
If that works, remove the tray, take all the paper out, verify the springs on the tray are working again then reinsert the paper and tray and try again.
Thank you.
Oct 04, 2009 | HP LaserJet 1320 Printer
Tray will not pick up paper when i press print to do anything
If this is an older unit you may need to check the rollers for wear. After awhile rollers can wear down too smooth to pick up paper.
Jul 17, 2009 | HP Office Equipment & Supplies
Unexpected message: 6B22
That is a pre heater fault.
Preheater exit sensor in unexpected state during fault.
Preheater exit sensor in unexpected state during stage.
  1. Check system grounds.
  2. Check the Drum Maintenance Kit NVRAM contacts during oiling for continuity.
  3. Check the waste tray.
  4. Replace the Preheater ( REP 2.0.17).
B2M
B2N
B2P
B2Q
The preheat flag tripped unexpectedly while picking paper from Tray 2.
The preheat flag tripped unexpectedly while picking paper from Tray 3.
The preheat flag tripped unexpectedly while picking paper from Tray 4.
The preheat flag tripped unexpectedly while picking paper from Tray 1.
  1. Test the Preheater Sensor using Service Diagnostics.
  2. Check system grounds.
B3M
B3N
B3P
B3Q
B3S
B3T
The preheat flag timed out waiting for the paper picked from Tray 2.
The preheat flag timed out waiting for the paper picked from Tray 3.
The preheat flag timed out waiting for the paper picked from Tray 4.
The preheat flag timed out waiting for the paper picked from Tray 1.
Preheater sensor timed out during stage.
Apr 17, 2008 | Xerox Phaser 8200 Laser Printer
Konica Minolta magicolor 2430 DL Laser Printer Logo
148 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
