Question about Garden
Assembly instructions for YUKON 52cc BACKPACK LINE TRIMMER
2 Suggested Answers
SOURCE: Replacing trimmer line with blade for stihl fs 90r trimmer
If you bought the trimmer new there should be a rod about 6" long and 1/8" thick. Above the trimmer head below the trimmer gearbox there is a hole. You have to put the rod in that hole and turn the head until that locks it from turning.
From there you can screw the trimmer head off by hand, or a strap wrench if it's really tight. It may be left hand threads.
Posted on May 24, 2010
How to order gas line for chainsaw blue max 45cc model 6595
MAN, you MAY be in luck!
Checkout THIS obscure link!!
Chinese Chainsaw Parts
#75339 D24
GREY MARKET CHINESE 52CC - 58CC CHAINSAW FUEL LINE 75339 D24 NEW
Molded rubber gas line - NEW - Fits many Off-Brand Chainsaws made in China 45cc, 52cc, 58cc, SL4500, SL5200, SL5800, SL 4500 5200 5800 Falcon Pro, Forester, Kraftech, King Saw, Silverline, Blue Max, Yard Dog, Gio, Raiden, Talon, Powerhorse and...
75339 D24 75339 D24
Hope this is it!
Anthony
Apr 15, 2018 | Garden
What is the proper configuration of the ryobi p2200 string trimmer head assembly?
Ryobi P2200 18 Volt Hybird String Trimmer Parts
Find Part By Symptom on right side
Select "Trimmer line feeds too much / continuous"
Will show you list of parts to hopefully fix you problem
Jul 22, 2017 | Ryobi Garden
Where can i buy a new complete line trimmer assembly for a Ryobi grass scorpion RTC2500 trimmer?
Hi Gary,
You may already have found what you are looking for but if not, here's a site that will help:
http://www.ereplacementparts.com/ryobi-trimmer-parts-c-7931_15633.html
Good Luck!
Jim
Feb 09, 2016 | Ryobi Garden
How do I remove the clutch plate from a Yukon 52cc chainsaw
You turn the clutch clockwise. There should be an arrow on the plate. As always be gentle. GOOD LUCK FRIEND.
Sep 21, 2014 | Garden
Main throttle adjust for MB3202 gas backpack blower?
You'll probably need to contact your local service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Jul 28, 2013 | McCulloch 26cc Backpack Blower with Dual...
Replace trimmer line
The steps for replacing line in a single line trimmer head are virtually the same for many trimmer head types, like double line trimmer heads.
1. Remove the Trimmer Head Spool
Removing the spool is the first step in replacing trimmer line in any conventional trimmer head, but trimmer head spools can disassemble in different ways.
The trimmer head pictured above and below disassembles by simply unscrewing the knob around its arbor bolt. Other trimmer heads can use press tab and other twisting styles for disassembly.
2. Insert Trimmer Line and Wind the Line
Single line trimmer heads have just one channel in their spools for winding line. The channel will have a hole in it somewhere that keeps the line in place as it is wound around the spool. Insert one end of the trimmer line in the hole.
Depending on the trimmer head, it might be helpful to bend a small portion of the cutting line at an angle before inserting it in the starter hole. Also, cutting the line at an angle can help this first step on some trimmer heads.
Of course, it is also important to make sure that the replacement line matches the diameter specification of the trimmer head before beginning. Once the line is started correctly in the channel hole, you're ready to wind. Most trimmer heads will indicated the correct winding direction right on the spool somewhere.
It's also important to wind the line carefully, keeping it in neat rows as much as possible. The line will have a much higher chance to feed incorrectly during trimmer use if it suffers from sloppy winding.
3. Snap the Line into its Retaining Notch
A conventional trimmer head will have a retainer on its spool. Snap the end of the trimmer line into the retainer after it is wound around the spool. The retainer will hold the line in place as the spool is replaced in the trimmer head assembly.
4. Replace the Trimmer Head Spool
With the cutting line held in place, the spool is ready to be replaced in the trimmer head assembly.
First feed the extra trimmer line through the trimmer head eyelet. Make sure to release the line from the retainer before completely securing the spool into position.
Replace any knobs, bolts, or other trimmer head pieces removed during disassembly.
Your single line trimmer line is now reloaded, and your trimmer should be ready to get back to work.
Although there are many steps to reloading line the conventional way, a little practice and familiarity with your trimmer will speed the process up a great deal. Once you're up to speed, reloading trimmer line this way can take less than five minutes.
If you want to know about the double line replacement, please click this
Thanks.
Apr 01, 2012 | Garden
How do change the line? can not get head off Craftsman 25cc Gas Line Trimmer
should be a button on side of head assembly. press in and top should come off
Jul 05, 2010 | Craftsman 25cc Gas Line Trimmer
NEED INSTRUCTION SHEET FOR LINE INSTALLATION
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer: Then just wind a single piece of string clockwise onto spool. This may need to be longer than 7ft.
Jim
Oct 25, 2009 | Garden
Motor spins, shaft does not...
I'm in a similar situation with my GH1000, except that it was a part that comes with whole motor assembly. I could sell you the shaft assembly of my trimmer, or I'll buy your motor assembly. Yes?
Jul 26, 2009 | Black & Decker 14" Grass Hog Xp...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
