Question about Irons
Quigg steam iron 2200 manual - Irons
  • 79 Answers
SOURCE: Won't steam
The steam irons I have see have a separate button to allow water from the reservoir to enter the steam chamber. This button latches down for steam and you unlatch it for dry. Also, there is a temperature range on the temp dial for steam.
The reservoir must have water in it for the iron to make steam. If calcium from the water has built up on the reservoir valve, it may prevent the water from entering the steam chamber. Straight white vinegar instead of water may help.
Posted on Mar 16, 2008
SOURCE: Russell Hobbs Steam Glide 2200 won't produce steam.
I had a problem and tracked it down to the pump. If you take the iron apart, the pump sits towards the front of the iron and has 3 tubes connected to it. Remove the srew-down bracket and free the pump from the plastic clasps on the base. Disconnect tubes and wires (remembering where they go.
Remove the circular securing spring from the front of the pump and drop the metal barrel from the housing. Unscrew the rear plastic assembly and set aside. there is a joint inside where the plastic assembly was - this is has an o-ring and is simply a pull-apart. It deos not need screwing. Pull the metal barrel apart, taking care to note the sequence for reassembly. Inside the barel is a larger rubber washer. Pull on the metal tube that goes through the centre of the washer using a pair of pliers - it will come free.
You will then see the problem - the spring inside the metal barrel will have broken. Take care, because at the other end of the spring is a small plastic washer that must be retained. Find a pen that has a short spring inside and use this as a replacement. If necessary, you can trim the spring to make it the right lenght. Ensure you have removed all broken pieces of spring, and reassemble. Try it out before finally attaching the pump inside the iron. It took me 2-3 attempts to get the spring tension right. If you can find a 'PENAC RB-085B BA1002' pen, the spring is perfect.
Once you have got it right, reassemble.
I have to replace the spring approx every 6 months as the replacement is obviously not meant for the job and wears or rusts or breaks. However, I am getting extended use from my otherwise broken iron.
Take care - things inside get HOT!!
Hope this helps.
Posted on Dec 17, 2008
bozcro
  • 867 Answers
SOURCE: Russell Hobbs Steamglide 2200.Iron and steam
is the water in your area heavy? it may have clogged your iron with stone. soak plate in something like clr .
Posted on Aug 10, 2009
SOURCE: my steam station russel hobbs iron 2200 is
You need to descale, use weak water and Vinegar solution.
www.theanswerbank.co.uk/Home-and.../Question127676.html
Posted on Mar 19, 2010
ercupa190
  • 12223 Answers
SOURCE: steam boiler iron
you can download instr. manual from www. fitness.manualsonline.com or www.retrevo.com or www.manualsfactory.com
service manual go www.pdfservicemanual.com
God bless you. However see the diagram is universal for repair small appliances.
Posted on Jul 26, 2012
My Iron heats up but no steam comes out and no noise please help !! Russell Hobbs steam 2200
If the water used is hard it will build up with shale, and block the steam vents, best to flush with clean water after every second use . Best to take to the dealer and have it serviced .
Jul 10, 2015 | Russell Hobbs Irons
Iron blows electrics
Check the cord for any kinks or cuts before checking the cord connection to the appliance itself for loose or touching wires. What is decalc the iron ?
Nov 23, 2013 | Tefal Superglide Fv3680g1 Anti-Scale Steam...
Filter light flashing what do I need to do no manual available
Breville VIN170 Extreme Steam Digital Steam Generator Iron
unplug the iron from the mains , keep both the power and keep the steam release button on the iron depressed and then plug in and switch on
Aug 07, 2013 | Breville Vin170 Extreme Steam Digital...
It leaks water when I iron sometimes staining my clothes with black streaks or water stains.
Hello :
1:Clean your steam iron according to the manufacturer's instructions. Your iron is more likely to leak when it has not been cleaned properly. Plus, the water that leaks from a steam iron that hasn't been cleaned will likely be dirty and stain your fabric. Every steam iron brand is different, so be sure to check the manual that came with your iron or browse the manufacturer's website for instructions on keeping your steam iron in good working order.
2:Use your steam iron on a rigid surface like an ironing board. In a rush, you might be tempted to quickly iron a blouse or pants on the nearest available surface like a bed, carpet or even on a table with a towel draped over it. However, these surfaces may not provide the proper amount of level padding for successful steam ironing, and leaks are more likely to occur. Take the time to set up your ironing board for smooth steam ironing to reduce water leaks on a bumpy surface.
3:Allow your steam iron to heat fully in the upright position before ironing. Because your steam iron is designed to convert water into steam that will easily smooth out wrinkles on bulky fabrics, you can avoid leaks by ensuring your iron has time to get the water to the correct temperature. If you lay your steam iron in the horizontal position too quickly, water that is not hot enough to convert to steam will leak. Give the iron a chance to heat up, and then test your steam function on your ironing board cover or spare fabric swatch before tacking your favorite blouse.
4:Turn off the steam function on your iron when ironing at lower temperatures. Since your iron's steam function is designed to convert the water in your iron to steam at the right temperature, lower iron temperatures can cause water to leak if your steam setting is still activated. For ironing more delicate fabrics, turn off the steam to avoid water leaks.
PLEASE RATE !
Apr 18, 2010 | Euro-Pro Shark GI490 Iron
My steam station russel hobbs iron 2200 is spitting out grey sandy substance with the steam....not very convenient when ironing whites!!!
Mar 19, 2010 | Irons
Russell Hobbs Steamglide 2200.Iron and steam station seem to be heating correctly, but will not dispense steam when trigger on iron pressed.
Aug 10, 2009 | Irons
Russell Hobbs Steamglide 2200 - no steam
Same with mine! What you have to do is keep taking the water cannister off and pushing back on until its lined up correctley. Also have the whole unit at the same height as the ironing board, that should do it! Can you help with filters? I cant find them anywhere.
Mar 23, 2009 | Irons
Won't steam
Nov 02, 2007 | Toastmaster 3302 Iron
Irons Logo
321 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
