Question about Canon PIXMA MP150 All-In-One InkJet Printer
Canon MP145:Stop error E5 , use scanner only
It's a Canon Pixma MP145 ,
I urgently need to use the scanner only
I've no color ink , only black
The Printer/scanner is stuck at maintainence cuz theres no color ink
Computer get errors trying to print
Can i disable error E5 ( no color ink ) and only use the scanner ?
  • zaini08 Apr 07, 2009
    canon mp145 errors E 5 1
THIS SOLUTION FOR PEOPLE WHO CANNOT RESET THEIR OWN PRINTER LIKE ME
hi, now i got a solution how to SCAN if your printer have E-5 error or something. First u must remove the both cartridge from your printer and make sure u connect your printer to your computer, after that, do this
With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
And then you will see no error in your printer (the LED shows number 1,and the alarm is in green)
NOW U CAN SCAN USING MP NAVIGATOR!
Posted on Apr 28, 2010
  • 4 more comments
  • duque_marin Mar 11, 2011
    thank you very much for the very useful solution.
  • pranab_web Jun 01, 2011
    Thanx dude, Now I am using only the SCANNER.
  • Murali Elisetti Nov 28, 2011
    i made it but i am getting "0" on led and alarm in "Orange" instead of "1" and "Green" respectively. plz help me out
  • sharjeel Apr 10, 2012
    does it work for canon Mp287....
  • hulkgow
    hulkgow Nov 08, 2012
    no light in alarm and '0' in display pls help...
  • Rahul Chakraborty
    Rahul Chakraborty Mar 25, 2014
    it is not working .....
I want software
Posted on May 02, 2009
I got this from another thread
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Dec 06, 2009
    New Friend:
Use only scanner or reset the Canon MP150,MP145 after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer's power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
7) Press the power button, the color button then the Reset button in order. The Canon will print some stripped lines and some numbers and letters ( all black if colored ink is empty).
[done just turn off by power button then on agin now its working !]
[Till Here for MP145 only]
[For MP150 You Have To continue ... ]
When you print this sheet the value in the display returns to zero.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid, re-connect the printer to the power outlet and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
Guyz This is 100% WORK Trust Me !
Posted on Apr 15, 2013
  • 2 more comments
  •  jitz
    jitz Apr 15, 2013
    Refill Total Sollution .. . [][]
  •  jitz
    jitz Apr 15, 2013
    Plz Like it If you Agree with me !
  • Mahender Pal Thakur
    Mahender Pal Thakur Jan 10, 2014
    Thanks a million bro............ it really works.................
  • Hegel Joseph Feb 18, 2017
    Thanks a billion friend..This really helped
Service error 5100 on MP145
Posted on Jul 06, 2009
    New Friend:
1. Remove Both The Cartridges.
2. Turn On The Power Supply. But Keep The Printer Off.
3. Press and hold the Reset Button (the one with the red triangle inside the circle) and then press and hold the Power Button.
4. Now while holding the power button. Release the Reset button and then Press the Reset button twice and then release the power button.
5. The printer will start turning on. After around 10 seconds the display will show '0'
6. Press the + Button once and then Press the Color Button.
7. Press the Power Button twice. You'll notice that both the A4 Plain Paper and A4 Photo Paper LEDs will now be on and the display will show 1.
(I don't remember the exact sequence i followed to turn the display from 0 to 1 but it's easy. You can always hit and try. The one thing i remember was that you have to press the power button twice in the end or only pressing the power button twice helps.)
8. Open the printer cover (not the scanner cover). Let the cartridge tray move to the left. With the printer still open, remove the power lead from the back of the printer.
9. Close the printer cover.
10. Replace the power lead and press the Power Button to turn the printer back on.
11. Insert the cartridges now.
12. Turn Off the printer and then On again.
You should be able to use the scanner now.
Posted on Jan 20, 2013
Not working for me...
Posted on Apr 10, 2012
Hi.... all
anny one who know how to use mp145 about scan only
now when i turn it on it show E8 ... all the tine...
how can i solve this problem......
thank alot...
Posted on Aug 26, 2011
Error 19
Hi there-
Below are a list of the error codes for this model.
E16-E19 = Failed to scan head alignment sheet.
You can find this information at http://www.usa.canon.com/cusa/home
CANON MP140, MP145, MP150, MP160 RESET ERROR CODES
[Info140] pixel_trans.gif RESET ERROR CODES CANON MP140, MP145, MP150, MP160
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge
is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera
Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Nov 29, 2013 | Canon PIXMA MP150 All-In-One InkJet...
My canon pixma mp145 keeps showing error 5, i need to use this printer urgently, what should i do?
my canon pixma mp145 keeps showing error 5, i need to use this printer urgently, what should i do?
Sep 28, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Code E4
A Canon MP145 E4 Error Code means that your Printer didn't detect the Ink Cartrigde. It sometimes happen when you're using a non-original cartridge or infusing it. When Canon Printer detect this abnormality, the first Canon self defense system is by Stop Printing. And then displaying some messages on your Computer Screen, indicating that your ink cartridge have to be replaced because it's EMPTY.
Below are the manual way to correct this problem :
  1. Turn On Your Printer.
  2. Wait Till The Printer Led Screen Show The Error Code ( E4).
  3. Then Press and Hold Black & Color Button for about 5 - 10 seconds.
Hope that your problem is solved.
Aug 16, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I have a problem on my canon mp145 with an error code E4. But I already change it to a new cartridge but still the error code still appears. I also reinstall the drivers but still the same.
Hi, I found this answer on the net. Let me know if this helps
A Canon MP145 E4 Error Code means that your Printer didn't detect the Ink Cartrigde. It sometimes happen when you're using a non-original cartridge or infusing it. When Canon Printer detect this abnormality, the first Canon self defense system is by Stop Printing. And then displaying some messages on your Computer Screen, indicating that your ink cartridge have to be replaced because it's EMPTY. Below are the manual way to correct this problem : Turn On Your Printer. Wait Till The Printer Led Screen Show The Error Code ( E4). Then Press and Hold Black & Color Button for about 5 - 10 seconds.
Thanks
Ranjit
Aug 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My canon pixma MP145 showed E5 and wont print anymore
I have been using black and color ink refills for sometime now, but am unable to use my printer since last week. It shows E5 and on the dialogue box is stated that it cannot recognize the COLOR.
Aug 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Error code E-5
Found this, it may help you Procedure to reset Printer canon MP145 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Error Code :
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E16 -E19 = Failed to scan head alignment sheet
E29 = EEPROM error
May 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon MP145 printer can not recognise replaced Black cartridge
When you got Error 4 on your printer canon MP145 It’s means one of your cartridge color/black has detected no ink. It happened maybe the printer MP145 is not used for long time. Don’t thinking your Cartridge is damaged. We can not do resetting procedure MP145 to resolve this I have tried it and failed.
When it happened to me I don’ want to go to the service center. We can guest what they say about that “your printer cartridge need to be changed” don’t believe. I go to Search Engine, browse and browse again finally today I found the guide for resolving the canon MP145 Error 4.
how to resolving error 4 on printer canon MP145 Press Reset/Stop Button about 5 second or more until the error 4 disapper. It worked! Save your money for newcartridges.
Jan 18, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Mp145 ink
Canon PG-40 Black
High Capacity Canon PG-40 Black Ink Cartridge
Pixma Series: iP1600/ iP1700/ iP1800/ iP1180/ iP1200/ iP1300/ iP1880/ iP2200/ iP2500/ iP2580/ iP2600/ MP150/ MP160/ MP170/ MP180/ MP450/ MP460/ MP470/ MP470SE/ MP140/ >>>>MP145<<<<
MP210/ MX300/ MX308/ MX310/ MX318/ iP6310D
Canon CL-41 Color
High Capacity Canon CL-41 COLOR Ink Cartridge
Pixma Series:
Jan 08, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Mp 145
How to reset the e27 for canon mp145 printer?
May 04, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon printer mp160 error msg 16 (e16) after replace catridge
try this PRESS STOP BUTTON FOR 5 SEC CAN FIX THIS PROBLEM
after that will adicated light alarm blinking them you can print if can't try turn off printer and turn on again.
Apr 17, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
15,644 people viewed this question
old marine
old marine
