Question about Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5570 power on but no display.
My Acer Aspire 5570 got problem. Power can turn on but no display. i dont think it LCD problem coz same problem when i connect with the another monitor. need some solution.
  • 1 more comment
  • ucuiede77 Mar 16, 2009
    yeah... i've heard fan noise when the starting on and the unit was hot...
  • Anonymous Apr 17, 2009
    hi Joed911, can u tell me what to do?
  • JDTec
    JDTec May 11, 2010
    Have you heard fan noise recently? Has the unit been hot?
  • 60 Answers
SOURCE: acer LCD fault
Definetly not an inverter issue. you would do well to replace the screen.
Posted on Mar 29, 2007
issy2
  • 460 Answers
SOURCE: acer aspire 5570 no power
Try turning it on with the battery but without power cord connected, if it turns ON.. then it looks like ur power section on the mother board has problems and u need to take it to the service centre. Also make sure your getting the desired output in the power cable.
Thankyou
Posted on Feb 10, 2008
SOURCE: Acer Aspire 5570z
i need audio driver and display driver of acer aspire 5570Z
Posted on Feb 12, 2008
  • 7 Answers
SOURCE: acer not work
Acer Aspire One BIOS Recovery The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
Download WIN98BOOT.ZIP and HPUSBFORMATTER from the internet normal bootable like a diskette won't work with a usb stick
I had mine 2 months it's a common problem with the notebook.
The onely thing that you have to do is download these programs with someone with a internet connection.
Good luck
Posted on May 25, 2009
Geekman
  • 32281 Answers
SOURCE: Acer Aspire 5735 LCD changes bight-dim-bright, etc.
You could have a faulty inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Posted on Jun 25, 2009
Acer 5570z wont boot to bios. LCD screen lights up. Hard drive is spinning, but nothing happens. Have two different motherboards and it does the same thing with both.
OK. So when you power the Laptop on, what display do you receive? What do you mean when you say, the LCD lights up? Do you recognize a backlight to the LCD or is there any information being displayed? What key are you pressing to load the BIOS settings?
Sep 19, 2011 | Acer Aspire 5500 5570-2609 Laptop
My Acer Aspire 5570 Laptop is not displaying anything.The laptop is on and HD and fan is working.System is booting and I can hear the Windows sound.It was fine till today morning.Please help me.How I can...
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 15, 2010 | Acer Aspire 5500 5570-2609 Laptop
I have acer aspire 5520. When I try to turn it on, I can hear disk drive spinning but then it turns off again, no image on the screen.
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
7. If still no display, connect an external monitor, check if display is comming.
8. If Display is coming then your LCD need to replace.
Aug 21, 2010 | Acer Aspire 5500 5570-2609 Laptop
I have an Acer Aspire 5570, when i turn it on the yellow led turned on but there is no display. can you help me?
This could be an LCD problem if your computer is turning on. You can actually feel the computer is running once you pressedf the power button. If this is the case, then try this troubleshooting steps.
Take out the battery
Unplugged the power adapter
Press and hold the power button for 30 secs
Put the battery back in
Plugged in the power adapter
Turn ON the computer
If same thing will happen. You need to call your manufacturers tech support for possible repair of LCD.
Jun 13, 2010 | Acer Aspire 5570-2758 Notebook
My Acer aspire 5500 don't power on, it bip continously after centrino logo display
If it is making beeps during the startup (called post for Power On Self Test) this is usually a memory error. You can try reseating the memory chips.
Apr 13, 2009 | Acer Aspire 5500 5570-4421 Laptop
Acer Aspire 7520 turns off and on repeatedly
Mine does this but what I found was that if you hold the power button down for about 10 seconds when you are turning it on, it works.
Dec 06, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5570z
usally bad motherbord u can try using anther power pack but i dought will help seell it on ebay for parts
Jan 19, 2008 | Acer Aspire 5500 5570-2609 Laptop
Black screen
Try plugging a seperate monitor to the computer if it goes then your problem is a stuffed LCD.
Aug 31, 2007 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5500 5570-2609 Laptop Logo
215 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
