Question about Brother MFC 7420 All-In-One Laser Printer
Lost connection from Mac G5 to Brother printer
I have an MFC-7420. The other day, I was printing and the current draw (apparently on the UPS) zapped my Mac and modem and shut them down. Since then, I haven't been able connect to printer. I've restarted it but to no avail. Any thoughts as to why the Mac isn't seeing the printer? Could a driver have been corrupted by the shutdown? Thx.
  • 3 more comments
  • benecke Mar 12, 2009
    BTW, I am using OSX 10.5.6
    Reinstalled the driver (Twain) per one suggestion and that didn't help. Still can't find the printer…
    The Print Utility shows a print progress like 24% and then stops and the window displays:
    "GenericClass: waiting for device" while it's trying to connect.
    Could I go back into Time Machine and replace some folder or file and get back to the previous state?
    The power cycling worked. I had turned off the switch earlier thinking I was doing essentially the same thing. Thanks much.
  • 716 Answers
Turn The Printer Off And Then Hold Down Its Power Button For 15 Seconds This Should Print A Diagnostic Page And Confirm There Is Nothing Wrong With The Printer. If That Test Passes Then Try Another Usb Port On Your Computer. If This Still Fails Unplug The Printer Completely From Your Computer Uninstall The Hardware Again And Then Reinstall It And Once Done Installing The Hardware Reboot And Once You Reach Your Desktop Plug In The Printer Again.
I Hope This Helps
Sincerely,
Michael Scott
Posted on Mar 12, 2009
  • 564 Answers
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
  • 527 Answers
Sir,
  • Verify that the Brother machine is connected with a USB cable and is not on a network.
  • Verify the power cord and USB cable are securely connected.  If the USB cable is loose on either end, disconnect and reconnect the cable securely.  Test the machine by trying to print.  If the machine does not print, go to STEP3.
  • Cycle the power of the Brother machine by unplugging the power cord from power outlet, wait approximately one minute and plug back in.  Once the Brother machine displays the date and time after plugging it back in, test the machine by trying to print.  If the machine does not print, to Step 4.
  • Reboot the computer connect to the Brother machine and then try to print again.
  • If it is not worked let me know
    Thanks Good Luck
    Appreciate to rate as "Fixya"
      Sergeant:
    • 254 Answers
    Yes the driver of the printer needs to reinstalled again.
    click the link for new latest drivers for your printer  http://www.brother.com/E-ftp/info/index.html
    also 1 more link for drivers  http://www.printcountry.com/drivers/BROTHER_MFC_7420_DRIVER_DOWNLOAD.htm
    • 4,472 Answers
    I would uninstall the printer/software, and reinstall then see if it recognizes the printer at all. Download the latest software from here:
    http://www.brother.com/E-ftp/softwin1.html
    If you need further assistance please let me know.
    Thank you,
    Lee
    • Brother Master
    • 13,433 Answers
    Could you tell me the version of mac os that your mac has. Try reconnecting it to another usb port and also try unpluging the printer in the middle. I do have a software that maybe helpful ones I know what version of mac you got there.
    • Ekse Mar 12, 2009
      Heres the software
      http://www.fixamacsoftware.com/software/...
      you don't need to buy it, just download it and use the trial. Perform maintenance with it, as in reset the printing system. Its been a while since I used it I don't remember exactly what options there where.
      Okay, I found a picture of it
      Perform a reset on the printing system with the software and also try the verify and repair permissions.
      if the problem is still not solved, you can uninstall the printer from the computer. The printer drivers page can be used to delete the drivers. you may also try the uninstall that came with the printer software when it was installed instead.
      if you need the drivers and software for the printer again, they are available on this brother page
    Works perfectly but will not print at all. Copies fine.
    Hello Michelle,
    The fact the pages are only coming out blank when you print from the computer points to either the driver or the cable connection.
    We’ll start by addressing the drivers.
    Let’s remove the printer first.
    1. Click on the apple icon in the top left.
    2. Select “system preferences”
    3. Select “print and fax”
    4. Highlight the MFC-7420 and press the “-“ icon.
    Now we need to remove the driver package.
    1. Open your Macintosh HD (in the finder)
    2. Go to Libraryè printer
    3. Drag the brother folder into the trash bin.
    4. Empty the trash bin
      NOTE: you may need to restart your computer before you can empty the trash bin
    5. Restart your computer after the trash bin has been emptied
      NOTE: You have to restart even if you had to restart once before.
    Now you will want to install new fresh drivers.
    Please choose the link for your OS
    Mac 10.6 (snow leopard)
    http://www.apple.com/downloads/macosx/apple/firmware_hardware/brotherprinterdriversformacosxv106.html
    Mac 10.5 (Leopard)
    http://www.apple.com/downloads/macosx/apple/firmware_hardware/brotherprinterdriver11.html
    For versions of Mac 10.4 or earlier, you do not need these drivers, they will be installed automatically.
    Now you need to install the brother drivers for printing.
    Use this link, choose your version of Mac then click on “search”
    On the next page, you want to use the CUPS driver download.
    http://welcome.solutions.brother.com/bsc/public/us/ca/en/dlf/download_top.html?reg=us&c=ca&lang=en&prod=mfc7420_all
    Please come back and vote or leave some feedback, it will let me know whether it helped so I can improve and it will encourage me to keep on helping.
    Thanks,
    Pat
    Apr 07, 2010 | Brother MFC 7420 All-In-One Laser Printer
    Scanning images onto mac
    The scanner driver is separate from the printer driver. This link will take you to the downloads page of Brother-usa.com, where you select the machine family, then the specific model. Click the downloads link at the bottom, then, and you'll get to a page to select what you want and for what OS. Brother lists Mac os's from 9.x to 10.6.
    Even if you have a driver on CD, the website usually has a newer version.
    Jan 21, 2010 | Brother MFC 7420 All-In-One Laser Printer
    PowerMac G5 will not boot up fully, it makes it past the chime and acts like it is going to boot then restarts. Similar to when you zap the pram. It or may not eventually boot. When it does finally boot...
    Do you have your G5 hooked up to a UPS? The symptoms are consistent with drive-spin-up current load temporarily overloading a marginal/failing UPS.
    Nov 02, 2009 | Apple Power Mac G5 Desktop
    Brother printer model MFC-7420 is not printing!! wants to send all request into que, have tried shutting down and restarting computer but no luck, printer is plugged in with Mac pc. not sure what is...
    " Unplug the printer cable from the computer.
    " Unistall the printer drivers from Device manager and also unistall the all the printer appications
    " restart the computer
    " try to download drivers from the website
    " after installing drivers and software it will ask you to connect the printer.
    " then you can connect the printer and and try to Print the test page.
    Thanks
    Thiru
    Jun 17, 2009 | Brother MFC-7420 Printer
    7420 won't scan with my Mac G5 (OS 10.5.5).
    you must have paper port to use the scan part of the machine. if you have the original cd that came with machine it has paper port in it. may be if you go to brother.com you could download this software let me know brother tech
    Nov 30, 2008 | Brother MFC 7420 All-In-One Laser Printer
    How to print fax confirmation sheet - MFC-7420
    first print out the help sheet, might be in reports then u have all the information at hand
    Nov 21, 2008 | Brother MFC 7420 All-In-One Laser Printer
    Connecting Brother MFC 7420 thru Dlink DP301P Print Server to home network with ONLY dynamic addressing
    I went and got static IP addresses from internet provider...Must of caught them on a good day
    Apr 24, 2008 | Brother MFC 7420 All-In-One Laser Printer
    Brother MFC 7420 all in one Scanner not working
    sorry but is the 7420 compatible with Vista? what does the box say?
    Nov 08, 2007 | Brother MFC 7420 All-In-One Laser Printer
    Brother MFC-7420
    I need to down load driver for Brother MFC-7420
    Sep 03, 2007 | Brother MFC 7420 All-In-One Laser Printer
    Brother MFC 7420 All-In-One Laser Printer Logo
    124 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Jim Keysor
