I am using ultrasurf since 1 year in my pc 8440 but due to unknown reason it dosn't work anymore so, what will be the reason and how can fix this
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 75 Answers
Did you reload the software? Try that first, check for updates. If it was recently updated then, roll back the update to the previous version.
Posted on Jun 11, 2013
2 Suggested Answers
PhenixSoft
  • 109 Answers
SOURCE: shuts down for unknown reasons
- Check your system and CPU temperature.
- Check your system for viruses.
- Try to boot in Safe mode.
Posted on Sep 13, 2012
Does't work anymore
I would call the phone company back, if what you say was caused by them..
May 24, 2013 | IBM USB Portable Diskette Drive (05K9276)...
Shuts down for unknown reasons
Dec 19, 2011 | Acer Aspire 5315 Notebook
Hey my toshiba laptop pad mouse dosn't work it's frozen ,,i only bought it before 10 days ..and i can't use another mouse help me plz
This problem may occurs due to hardware fault or due to some setting changes doesn't matter that you did or not but sometimes it happened because of some other programs.
Here is the solution if it's not a hardware fault:
* Click on Start button
* Then select Control Panel
* Now select the Mouse option
* Under Mouse option window click on Device Settings and in that window touch-pad should be listed...
* Enable it.
Hope this will solve your problem.
Sep 10, 2011 | Acer Aspire 5610-4648 Notebook
I cant hear any sound on my packard bell easynote laptop
You just need to download the appropriate audio driver for your laptop. Go to the Device Manager and install all missing drivers for "Unknown Devices". Either connect to the internet or use the driver disc which came with the laptop of the computer.
For those who doesn't know how to access Device Manager, please follow the steps below.
For Windows XP:
Start -> Run -> Type devmgmt.msc (in the box) -> Right click Unknown device -> Properties -> Driver tab -> Update driver
For Windows Vista and Windows 7
Start -> Type devmgmt.msc (in the start search box) -> Right click Unknown device -> Properties -> Driver tab -> Update driver
Hope this helps.
Jun 26, 2011 | Computers & Internet
Model 0304y will not hold battery charge very long
2 possible reasons for this.
First, if you've had the rechargeable razor for a long time, after awhile lithium ion batteries eventually don't hold their charge as long and you'll be forced to replace it. It's not anything wrong with the product. These things just happen.
Another possible reason could be due to the outlet your using needs to be reset. This is pretty common. Just hit the reset button and the output power will increase drastically.
And last but not least it could be defective in which if you have had it for a year or less, normally on the higher quality products they offer a 1 year warranty. They'll replace it or fix it in order to keep you as a loyal customer. Just call their service department and they'll be able to help.
Their service number is 1-800-211-9611
Hope this helped!
Jun 18, 2011 | Conair 14 Beard & Mustache Trimmer
The left side of my toaster dosn't work
It's probably one of two things:1) They pressure contacts that engage the electromagnet may have burnt carbon deposits similar to spark plugs. One needs to clean in between the contact (two on each side) while putting slight pressure as the contacts meet.2) The spring mechanism that engages these contacts has snapped at the securing point, thus not able to put enough pressure to engage these contacts that power the electromagnet.
For some reason it's always the left side.
If the toaster is more than 5 years old I would suggest buying a new on , even though these toasters are very reliable. As the crumbs that left inside are so powdery and coats every surface inside, as well.
May 22, 2011 | Tefal TT744115 4Slice Toaster
When i turn on my brother mfc 8440 it is saying
For the error code "7a" to be fixed permanently, you need to ensure that the main PCB is fine and is working in good condition.
If the error code is caused due to malfunctioning of the main motor, then you need to check the whole setup by connecting it with another motor.
In this case, make sure that there is no mechanical load present on the main board.
While fixing this error code, you will notice that the motor runs slowly initially and then picks up the speed later.
http://www.fixya.com/support/t5660619-7a_error
Oct 01, 2009 | Brother MFC-8440 All-In-One Laser Printer
Firefox refuses connection with ultrasurf's proxy
Well Ultrasurf obviously does not want to work with your internet connection (like mine)
For now you need to remove Ultrasurf. Go to Tools>>Add-ons>>UltraSurf Firefox Tool>>Disable OR Uninstall.
That should at least get your internet working...
As for a working proxy, try using a "Web based proxy"
Google it.
Thanks,
Ted
Mar 17, 2009 | Toshiba Equium 6200M (PV1026U-01A) PC...
Fax modem 56k 2.9 audio dosn`t work when connect to internt with win vista
well if ur using vista u need to check if da modem ur trying to install is vista compatible or not if not den just let me know ur modem name + model number so i'll find ur modem driver if ur modem manufacturer released their vista drivers if not then buy a vista compatible or vista certified modem or simple solution is that go back to windows xp coz its a fine window n u can wait for windows vista for some 1/2 years so that vista have some problems n errors which in computer language is called bugz so let microsoft team to fix that bugz n may be ur modem manufacturer might releases ur modem driver too!
peace!
Oct 16, 2007 | Intel Motherboard
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
