Question about Dell Vostro 1000 Notebook
I have a Dell Vostro 1000 that my kids dumped a full cup of water on.
I knew I would need to replace the MOBO and I did but since doing so the computer is still not working. I sent the computer back for testing and they assured me the MOBO was fine and it had to be other components that were failing. I did upgrade the RAM some time ago and put the old sticks in to see if the RAM was the problem and it did the same thing, nothing. When I push the power button in the 3 lights next to the button light up and then go off. The power on indicator lights up and stays on. I have tried powering on with just the power cord alone, battery alone and then both of the together. You hear the disk drive engage and then nothing, it does not try to boot. When this happened I pulled the HD, let it dry and them proceeded to download the files onto my desktop computer and this worked fine. Could the power board under the button be bad? Any information you can provide would be welcome at this point.
  • Dell Master
  • 2,072 Answers
That would be my best guess. Even with a partially bad CPU, memory or HDD you should at least get to the BIOS screen.
Posted on Apr 26, 2013
frcs68
  • 1605 Answers
SOURCE: Inspiron 1501 won't turn on
do you have the dell diagnostic CD??
if you have it may help you to figure what is wrong??
here is th link to the troubleshooting steps.
http://support.dell.com/support/edocs/systems/ins1501/en/om_en/html/trouble.htm#wp1062918
I suspect the hard drive may be on its way out. unfortunately you can't see the screen.
Posted on Nov 06, 2008
techprogrami
  • 57 Answers
SOURCE: orange blinking power light on Latitude D820 laptop
sounds to me like when u lost power it surged and froze your battery and now your battery has dead cells honestly the best thing to do is get a new battery
Posted on May 28, 2009
mrstan
  • 242 Answers
SOURCE: Dell Vostro 1000 shut down and won't turn back on
nope, it is your dc power regulator board. you will note this happens if the battery is in or out of the laptop. that is the key test. some regulators are on the main board and some are seperate for this reason. I think the vostro though is on the main board. A little board re-work will resolve this issue after replacing some components, but this is way beyond a home user's ability.. trust me on this. Sorry for the bad news. Thanks!
mrstan
Posted on Aug 29, 2009
Testimonial: "Thanks for your answer. I guess I will check what the repair costs may be, and if too much, just get a new machine."
SOURCE: My dell vostro 1000 won't turn on the green light
Try to do this: (Draining flea power)
1. Unplug the ac adapter (if connected)
2. Remove the battery
3. Press and hold the power button for at least 10sec.
4. Put back the battery and ac adapter
5. Turn it on
- check if you can now boot to windows, if not there could be a hardware problem and next step would be running some diagnostic test on the computer for hardware problem.
Posted on Dec 09, 2009
bob_computer
  • 3153 Answers
SOURCE: Dell D620 power light comes on when pushed but goes out 5 sec lat
There are two common causes for this and both relate to the power supply.
First is that the connector on the main board is loose or has a bad connection
If you are proficient with a soldering iron this is an easy fix for approx $10
http://www.insidemylaptop.com/category/4-dell-laptops/
They have some very good step by step guides for replacing power sockets.
It could also be a dying power supply which is the second most common cause.
Replacements are easy to obtain and cost between $20 to $60.
If it is the PSU either get an original replacement (EBAY is best bet) or get one of the many multi laptop PSU's available but if you get the latter please make sure it carries enough or preferably MORE amperage than you need.
The old supply will have the details of both the voltage and current on it and you need to match the voltage exactly and keep the same or better current rating eg 1000 Mw or 1A or whatever it says.
Bob
Posted on Jul 31, 2010
Can dell vostro 1000 be repaired if hdd password unknown
when a password for a laptop is forgotten there is no need to loose hope and format the laptop since it will mean losing all the data .more info http://opencertify.blogspot.com/p/how-to_26.html
Jul 26, 2015 | Dell Vostro 1000 Laptop
How can I fixed a defective motherboard of my dell vostro 1000 laptop? where can I order the exact type of my vostro 1000 motherboard laptop?
Only Dell will be able to supply a replacement Dell motherboard.
Telephone Dell, and ask for Technical Support, to find the part-number and the (HIGH!) cost.
Jul 18, 2011 | Dell Vostro 1000 Notebook
After reading various forums online and trying everything I can think of, I find myself at a loose end. I have a Dell Vostro 200 with a solid orange light that comes on as soon as the pc has power and...
You cannot... The motherboard is bad. That is what the light indicators are for. If it is under warranty, call Dell to get a service tech dispatched. If not, start planning on a mobo replacement/PC replacement.
Jun 01, 2011 | Dell Vostro 200 Desktop Computer
I had two lines in my dell vostro 1000 series laptop...what i have to do for that
Sounds like your LCD inverter has gone out.Sounds like you may need to replace it.
Apr 04, 2010 | Dell Vostro 1000
What about this Dell Vostro 1000 battery
the seller looks ok ...the things to look for is first to be new..no refurbished ,,second try to buy it not formated and do it yourself by charging it for about 12 hours ..and completely empty it for a few times...than see that for the same model of laptop can be more than one model of battery ..different on tha size and so with charge life time bigger or smaller....I will go for a midle size if available ...and use two of them ...to increse independence from the sourse..a much to big one might be inconvenient ...and of course one original is to be prefered on a copy or one that just fits...
the UK site is an excelent choice ...stay away from chinese stuff and cheap deals..
Nov 08, 2009 | Dell Vostro 1000
My dell vostro 1000 laptop's display ain
if i read this right, when you power up the laptop you get fan spin but no display ?, if you just get fan spin and the green power light and nothing else the you have a motherboard failure, if you get LED activity and it seems to be working but you only have no display the its more likely LCD failure, if you DO get activity try this : power off the system, press power button while holding down the D key, this will run the LCD BIST SELF TEST which will run through full colour screens if fails this test you will et a beep code, please bear in mind you will only be able to run that test if you get LED activity, if you dont have activity then the motherboard needs replacing
Oct 27, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
I need to download a network controller driver for the dell vostro 1000 laptop
Contact Dell Customer Care Toll-free phone number 1 (844) 395-2200 to get instant support to download a network controller driver for dell vostro laptop by expert dell technicians.
Oct 07, 2009 | Dell Vostro 1000
Missing F11 key on Vostro 1000 laptop
ebay will be the best place to get replacement keys for the laptop without having to buy a replacement keyboard, the Dell Vostro 1000 replacement keyboard key repair kit is fairly cheap at around $7/£3, check this out >>>>>>>>>>>>>>>>>>>>>>>>
http://cgi.ebay.com/Dell-Vostro-1000-replacement-keyboard-key-repair-kit_W0QQitemZ160344889363QQcmdZViewItemQQimsxZ20090627?IMSfp=TL090627143006r26034
Good luck.
Jul 09, 2009 | Dell Computers & Internet
Dell Vostro 1000 Notebook Logo
44 people viewed this question
Alun Cox
