Question about Philips PET710 Portable DVD Player
Dvd player is unable to read cd showing NO DISC
It was playing alright but i tried to play a cd which had all scratch marks, the player got stuck after that it is unable to read any cd even the one that it played previously - pl help
  • 814 Answers
You can try resetting the setting to the factory specifications. To do this on your remote push the setup button. Use the up and down arrows to find highlight preferences. Press ok to enter the sub-menu. Once in the sub-menu use the up and down arrows to find default. highlight this and press ok. Then press the setup button to exit. This will restore the factory setting and hopefully the full use of your player. If this fails to restore the operation of you dvd player, you can try using a lens cleaner and see if the dvd compartment needs cleaning. You can do this with a can of compressed air. If you need to clean the dvd lense use a cotton swab and a small amount of isopropyl alcohol.Apply a small amount of the alcohol to the tip of the swab and gently rub it back and forth until the lense looks bright and shines. Use the other end of the swab to dry excess moisture from the lense. Also check the transport and see if it needs to have dust and debris from the tracks or gears removed. Use the same process with cotton swabs a small amounts of alcohol to clean it up. Once clean try playing a dvd. It should work fine. If not you may have another problem with the lense or motor. You can call Phillips customer support at this telephone number. 1-888-744-5477 they will be able to help you with getting service for you dvd player. I hope this information help you with your problem.
Posted on May 31, 2009
The player will read dvd but will not play cd
Richard: This is what said: "
  • Turn on the DVD player. It generally takes a few seconds to get going. Take out the DVD if there's one in the drive already.
  • 2 Make sure the disc isn't scratched or dirty. Use a soft rag to clean the disc if you see any smudges. Insert the CD into the DVD player's disc drive and close it.
  • 3 Press the "Play" button on the DVD player or remote control. Some DVD players will begin reading the disc automatically. Pushing the button works just as well.
  • 4 Use the "Scene Selection" buttons on your remote to select a track. Some DVD players have odd ways of ordering the buttons on the remote. You might have to play around a bit before you find all the right buttons to work the CD playing function of your machine.
  • 5 Crank it up and enjoy your music. The DVD player will act just like a CD player and play the tracks of the CD through the TV.
  • Read more :
    May 28, 2015 | Televison & Video
    DVD will not play on any dvd player in the house after playing it in the SONY BDP S270 Blu-ray player purchased from Walmart. After playing the DVD in the Sony blu-ray, I can't play it in any or my...
    did you mean your DVD disc can not play in some dvd players,if so then my answer to your querry would be that some dvd players have more powerful lens to read bulky data in a disc that some machines can not read. also note that some machines are very sensitive such that they do not play discs with viruses,with scratches or any other defects. this is to safeguard the lens from being damaged due to the same though some machines will play barely all discs no matter the scratches.
    Sep 25, 2011 | Sony BDP-S270 Blu-Ray Player
    Disc won't play
    As the Wii uses discs that can be scratched, dirty, or otherwise damaged -- it's important to first check the disc.
    Look for fingerprints or other smudge marks. If you have dirty marks on the disc, you can wash it off with regular dish soap and water. Not too much soap though. Make sure you dry it off with something very soft [like a microfiber cloth] before you put it back into your Wii.
    Second -- scratches will stop a disc from playing... or the disc will play until it gets to the scrached section then give you an error. Check and make sure there are not too many -- or deep scraches.
    If a scratched game won't play through but other games play just fine -- chances are the disc is bad. However, if nothing is playing through on your Wii, not even a new game, there is a problem with the Wii's DVD drive. There is a laser in the drive that reads discs -- and many other moving parts in there. The following website sells the Wii DVD drives. It's not too difficult to replace yourself:
    Sep 06, 2010 | Nintendo Rock Band for Wii
    Disc cannot be read or played
    Hi, from the posted question above, you have a very weak lens that cannot play any kind of cd/dvd.
    You have to change the lens of the dvd player in other for it to work properly..
    Take care
    Apr 09, 2010 | Sony DVP-NS575P DVD Player
    DVD Player stops reading disc Error message :
    usually this happens when lens cannot read the the disc. Due to few reason 1 Your disk is scratched 2 Your DVD lens is covered with dust 3 You need to replace DVD lens
    Try another few CD/DVD to rectify whether there is any problem with dvd you are trying to play
    if this error occurs on all the dvd you played then the most likely proble is with your DVD lens either its coverd with dust use Disk cleaner if not you got to replace a new DVD lense as per model
    Feb 18, 2010 | Samsung DVD-V9800 DVD Player/VCR
    Daewoo DV-6T955B DVD Player Problem
    If your DVD is less than a year old, still under manufacturers warranty.
    The problem you have "no Disk" is because the laser is not reading the DVDs.
    Call the Main support number at 800-323-9668
    Support FAX 973-384-9250
    Email support
    Mar 06, 2008 | Daewoo DV-6T955B DVD Player/VCR
    Cd player reads disc error
    maybe you need to change the optical eye now.
    but first try to adjust the variable resistor/trimpot resistor.
    try this options to your player.
    if using a cd/vcd/dvd products, we only should play a cd/vcd/dvd dics without a bad scratches. the scratches are making the optical eye worn-out easily.
    Jan 28, 2008 | Tascam CD-A500 CD Player
    No Disc
    Stumpy, I think the first step could be to find out between the DVD player and the disc which one has a problem.If the DVD Player is able to play other discs then it is possible the problem is with the disc only. If that disc can be played quite alright in other DVD players then the problem is with your DVD Player. I suggest you trial that first. I think the indication of " No disc insert disc" could be that your DVD Player is failing to load or read the disc either because the disc has some scratches or because your DVD Player lens are not powerful enough. I am, Letsthank.
    Jan 29, 2007 | Sony DAV-S400 System
    DVDs & CDs will not play
    If you are playing STANDARD CD or regular DVD that you have purchase and you are having this problem,your dvd player is malfunction;however,if you are playing DVD burner disc or a different dvd region disc(we are region 1 in U.S.) that is no going to work.Same thing for your CD burner disc,it might not work.
    If you are using a rental dvd disc,check and see if there is scratches?If so,try to get one without that many scratches!
    Jan 07, 2007 | Philips DVD Micro Theater Shelf System...
    Philips PET710 Portable DVD Player Logo
    159 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
