Question about GE DCXR463EA Dryer
When the dryer is running it has started to make a clanking noise
It has begun a few weeks ago and it sounds like something on the drum is rubbing because it is a very regular beat, like every revolution of the drum. I can't find my manual, so I am not sure how to get the top off to see inside and try to find out what is wrong....
    Problem Solver:
  • 16 Answers
The top on most dryers are hinged from the back and snaps in, in the front. You may have to use a flat screwdriver and carefully pry up on each front corner to get it to "un-snap". Once the top is lifted, you will have access to the front panel which usually has screws that attach it to the sides. The drum will have a narrow belt on it towards the rear. You will have to "work" the belt off and the drum basically just sits on rollers.
Posted on Mar 12, 2009
Maytag LDE412 Drum Roller keeps breaking
perhaps your dryer vent pipe is plugged with lint and causing the inner parts to overheat .
Feb 15, 2016 | Maytag Dryers
My bosch Nexxt WTMC 3300 dryer makes a squeaking sound when the load is light -- drying a larger/wetter load less likely to make the noise.
I had a similar problem with a different model Bosch dryer. First I made sure the dryer was unplugged. I found, after taking the front and rear panels off, that one of the front wheels that supports the drum was broken. I replaced the wheel and it works fine with no squeaks.
Jan 01, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
I turn my dryer on after cleaning the filter. out of the sudden i hear like a metal clanking noise, and form then on , it wont start, it makes a sound when i try to turn on, but it doesn't start
you got some loose change or something through the drum. You may have actually gotten something wedged around the rim of the drum . Unplug the dryer , open the door, and inspect around the rim of the drum. Try to turn the drum and see if it is free.
Apr 07, 2011 | Whirlpool Dryers
My Maytag Dependable Care dryer, model MDE9206AYW has begun sueaking very loudly when running. The noise sounds like it may be a rubbing-type of a noise, or possibly a belt. I have not tried to take...
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.Here is a link to the part in case you need it.
Dec 31, 2010 | Maytag Dryers
Kenmore Dryer 110 is making a loud squeaking noise.
Only a few things will make that noise. The squeaking is caused by a moving part having trouble turning while rubbing against a fixed part.
  1. The idler pulley is worn
  2. The drum support rollers are hard turning on their shafts
  3. The felt seals at the front or back of the drum is worn allowing metal to metal contact while turning
  4. An article has fallen into the housing around the blower wheel and the wheel is rubbing on it.
Listen for the frequency of the sound. The drum rollers and drum felts will squeak at the frequency of the tub turning. The idler pulley turns much faster as does the blower wheel. Knowing this will help pin down the cause.
The following link has valuable information on taking apart your style of dryer:
Sears Dryer Disassembly
Sep 20, 2009 | Kenmore Dryers
Noise in brand new GE dryer
HI not the gas line that should be fine there is something stuck in your blower fan i would say if it went wrong after one hour they should come right back to fix it
Jul 13, 2009 | GE DCVH515GF Gas Dryer
Whirlpool Dryer making a rubbing or jingle noise when running
there are wheels under the drum to support it take the front panel off and check those
Jun 24, 2009 | Whirlpool GEW9200L Electric Dryer
Noisy "rubbing" sound...
it may need a good lubrication job. look for all rolling parts metal or plastics and give a good dose of WD-40 and observe. ba particular to the bushing of the drive motor, the roller and the center bearing that hold the drum.
Feb 17, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
76 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
