Question about Garden
Bht 430 hedge trimmer - Garden
boscia
  • 163 Answers
SOURCE: Black and Decker 16 in Hedge Trimmer
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Posted on Nov 28, 2008
SOURCE: Ryobi 18V Hedge Trimmer Blade Question
Just buy a file and push 3 or 4 down strokes down the same slope of the cutter toward the sharp edge. Never file on the flat top of the cutter, only on the slope. Support the frame using a saw horse or pick-up bed. The support makes the file cut the metal better. You can do the same thing with chain saws. You just need the file that fits the cutter. You just hold a consistant angle and count out the same number of strokes. Also, clean out junk between the moving parts, tighten any loose screws, and drop a few drops of 3 in 1 oil between the moving parts. Having things sharpened at a shop is inconvenient and expensive.
Posted on May 24, 2009
rogrrabbit
  • 986 Answers
SOURCE: Expand-It Hedge Trimmer Parts
Belive it or not there is a nice selection at Homedepot.com
Posted on Jun 17, 2009
  • 41 Answers
SOURCE: gas won't pump through the hedge trimmer
carb may need to be rebult. sounds like a bad diafram hope this helps
Posted on Jul 11, 2009
  • 279 Answers
SOURCE: Describe your Black & Decker Hedge Hog
You may have a piece of metal between the moving blade and the stationary one. Also the motor may have been at the top of the stroke when it stopped. You may be able to "force" the blade to move a little. This may free it enough to work.
Posted on Jul 14, 2009
The blades won't move on my black And decker 40 volt hedge trimmers. It sounds like the gears are not turning
How To Repair Jammed Hedge Trimmers - SelfGrowth.com
www.selfgrowth.com > Articles > Spirituality > Self Knowledge
The frequent use of powered hedge trimmers poses the risk of the blades becomingjammed (and it is highly likely that this will happen to your model at least ...
Fixing a Hedge Trimmer - YouTube
? 3:15
https://www.youtube.com/watch?v=aMddbl9B0iE
Jul 23, 2011 - Uploaded by Joby F. Randrup
Ever had a hedge trimmer break because you hit a fence or something ... HEDGE TRIMMER REPAIR "how to sharpen hedge trimmer blades" ...
Nov 04, 2015 | Garden
How do I put the blade back
Husqvarna Hedge Trimmers 122HD60
www.husqvarna.com/.../hedge-trimmers/122hd60/966...
Husqvarna GroupHusqvarna 122HD60 is a low noised and light weight hedge trimmer for domestic ... 23 inch. Weight. 10.8 lbs. Add to wish list Find a dealer near you. Manuals.
Oct 13, 2015 | Husqvarna 122HD60 Hedge Trimmer
Weedeater Excaliber Gas Hedge Trimmer. Is it possible to sharpen these blades? If yes, do you know the procedure?
You should be able to sharpen your hedge trimmer blades. There is a good video on how to sharpen hedge trimmer blades on youtube by ereplacementparts. He explains how to do it with a file or a grinder.
Aug 24, 2011 | Weedeater Excalibur Gas Hedge 22" Trimmer...
I have a 14 in. electric chain saw I bought last year and need to download a manual
A hedge trimmer is a type of agricultural or garden tool. And as the name suggests, it is used to trim hedges. There are mainly two types of hedge trimmers - manual and electrical. Amongst these there are some below mentioned variations.
Stand Alone: A stand alone hedge trimmer could be either power driven or manual. The power driven stand alone hedge trimmer uses gasoline or electricity to operate. However, the manual or hedge trimmer driven by human force is best when you consider environmental factors. They are cheaper and easy to operate. Generally gas powered hedge trimmers or electrically powered hedge trimmers are equipped with safety devices. The mechanism is such that they operate only when the operator has both his hands on the handles.
Tractor Mounted: This type of a hedge trimmer is more suitable for pruning of plants and crops. Tractor mounted hedge trimmers either have a movable arm or they do not have a movable arm. The ones without movable arms depend only on rotating blades on a couple of central pivots placed on the tractor's side. Now, these hedge trimmers are best for growing grapes, more specifically for making wine. Small tractors driving between the grape vines are mounted with these type of hedge trimmers, without a movable arm.
Well, this was about hedge trimmers in general. Now lets get down to business. Here's a low down on a few best hedge trimmers. The following is an overview of electrical hedge trimmers comparison.
Hedge Trimmer Reviews
Stihl Hedge Trimmer HS81T: Well, this one is surely up for grabs. Stihl HS81T is a great option for keeping your hedges in a perfect shape. Stihl HS81T is lightweight with balanced design and low vibration levels. It has 24 inch or 30 inch double sided blade length. It's also equipped with rear swivel handle for enhanced comfort at different speeds. The engine power is 0.7 kW and this hedge trimmer weighs between 5.2 kg and 5.4 kg, depending on the blade size. It is good especially for shaping and sculpting your hedge. It does not start on the first pull sometimes, still Stihl is a good option for hedge trimming.
Black & Decker NHT518: Now you would perhaps love this, if you do not want the whole baggage of fuel and electric wires and so on. It is cordless and runs on a battery and 22 inch blades that give a smooth and level cut. It does a neat job of branches less than 1/2 inch thick and you get optional extra battery packs. However, it gets a thumbs down from users with regards to poor battery life. On the other hand the users like the cordless design. Again, they say that it is not as powerful as corded trimmers. Nevertheless, it is lightweight and makes minimum noise. So you can go for it.
Echo HC-150 Petrol Commercial Grade Hedge Trimmer: Well, hopefully most of the users would echo my statement that, Echo is a very efficient hedge trimmer. This is a high performing, commercial grade hedge trimmer powered by petrol. It is a smooth and **** free hedge trimmer and is great for pruning and trimming. Durability is apparently the forte of this Echo hedge trimmer. Superb double reciprocating blades cut on their return and forward strokes, which give a smooth, uniform finish to your hedges. Not a bad choice either!
Makita UH6350 Electric Hedge Trimmer: This is a well designed tool with a great cutting action, according to a magazine on mechanical products. It is light weight and can deal very well with branches upto ½ inch of diameter. Although one of the disadvantage is that you have to bear with a cord and has a single blade operation. A fairly good option if you are thinking of buying a hedge trimmer.
Well, there you go, this was a small list of best hedge trimmers. I hope the hedge trimmers comparison was useful for you.
Take your pick according to your requirements and any hedge trimmer is good so far as it helps you keep your plants in good shape! What say!
for mannual download go to
http://www.stihl.de/safety_manuals/en/heckenschere_englisch.pdf
Jun 15, 2011 | Homelite Garden
My hedge trimmer blades do not move when I turn it on
Check the power wires that connect to the motor. My 18 inch B&D hedge trimmers both had loose wires at the motor that had to be re-soldered. You will need to open the trimmer casing to get to the loose wires, if that is the problem.
Jul 09, 2010 | Black & Decker Hedge Hog 20-Inch 2.8-AMP...
Parts list tanaka hedge trimmer
You can get the service manual on link below.
http://tanakapowerequipment.com/pdf/serv/Tanaka_HT_Service_Manual.pdf
On this link below is the parts list.
http://www.tanaka-usa.com/pdf/dpl/hedge_trimmers/THT-2100dpl.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Jun 27, 2010 | Tanaka Hedge Trimmers: 20" Dual - Sided...
Craftsman hedge trimmer fuel line replacementa craftsman
My Sovereign SHT 26 hedge trimmer has a damaged fuel pipe which needs replacing; please advise
Jun 12, 2010 | RTO Weed Eater Hedge Trimmer 20cc,...
Garden Logo
52 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
