Question about Dell Inspiron Computers & Internet
Can I replace the bezel (front and back) on Dell Inspiron 1520 WITHOUT cam port with a new bezel WITH a cam port?
I don't want to use the cam port as my computer did not come with it, I just need to replace the bezels as they are cracked and found one but it has the cam port.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 112 Answers
Yes, the screw holes are the same on both. If you are adding a camera to the laptop - the ribbon cable plug is below the keyboard off to one side of the ribbon for the screen connection.
Posted on Nov 21, 2013
  • 5 Answers
SOURCE: Replacing LCD screen
Here is a uk site selling this screen with instructions. http://www.laptop-lcd-screen.co.uk/laptopparts/ACER-ASPIRE-6920-6920G-16.0-LAPTOP_410.asp
It looks like you have to remove the bezel from the keyboard first to access the screws for the screen bezel.
Posted on May 22, 2009
wbwill
  • 68 Answers
SOURCE: removing the LCD from a Compaq CQ60-215DX
I have a CQ60-220US HP Compaq and access to the LCD screen was different than others I have disassembled and replaced the display. The bezel is snapped on, the lid does not lay back flat to access the two hinge screws, but there are 2 screws with rubber covers down by the hinges, not all the way around.
I used a right angle phillips screw driver and was able to remove the bottom screws, popped off the bezel the remainder of the way around the screen, it is different, but don't be fooled there are a few screws just not the amount you might be used to, and then gaining access to one of the hinge screws on each side can be an issue as the lid did not lay back flat, but with a good right angle screw driver you can get it done, I did. I am not sure if the proper method is to not just remove the entire top cover and hinges, but the right angle screw driver and finding that this model had only a couple bezel screws made it much easier to tackle.
Posted on Jul 18, 2009
  • 154 Answers
SOURCE: hp pavillion dv6-1030us just order my new screen
The procedure to replace the display is outlined in the maintenance and service guide.
Refer to the Display Assembly beginning on page 81 for the "complete" disassembly instructions.
http://h10032.www1.hp.com/ctg/Manual/c01758220.pdf
The maintenance guide gives you step by step procedures to remove the monitor and most importantly... how to remove the bezel "properly".
Posted on Jul 21, 2009
joecoolvette
  • 5660 Answers
SOURCE: need instructions to replace the bezel on a gateway 7330gz
Just like any other laptop LCD screen, edtechservic. Remove the rubber caps that cover the Philips head screws, remove the screws, and work around the bezel to pop it loose, a little at a time.
Top cover up, you are looking at the LCD screen. Look at the top Left and Right corners of the screen bezel. Look in-between. Now look along the bottom of the screen bezel. See those small rubber caps? G-E-N-T-L-Y pry them loose with a 60 or 90 degree pick. (In your computer repair kit)
Use care, and finesse! You don't want to scratch the clients laptop!
Now loosen, and remove the screws underneath.
Use a Jewelers flat tip screwdriver, (No.2), and ease it in the parting line, that you will see between the bezel, and top cover. Don't go more than a 1/4 inch in! You could be up against the LCD screen metal frame, if you go too far in. (Which could break the LCD screen)
Won't ease in there? Move over an inch or so. You could be hitting the plastic part of the bezel, that snaps down into the Top Cover.
There are several of these plastic protrusions, that stick down from the bezel, and snap into place in the Top Cover. Every few inches or so.
After you start easing one of these plastic snaps out, (Plastic protrusion I spoke of above), move along the edge, pick another place, and start easing it up. Keep bringing the edge up a little at a time. (Bring the back of the flat tip jewelers screwdriver down)
When you have gone along, and raised a large portion of the bezel, you should hear a distinct Click, as one of the plastic snaps come out of the Top Cover.
If not, move back to the first plastic snap that started to come out, and place your flat tip Jewelers screwdriver next to it. Bring the back of the screwdriver down to pop that plastic snap up, and out.
Hearing it your first time might make you a little stomach sick. You'll think you broke something! If you go along, and raise the bezel up a little at a time, you'll be okay. The bezel is made of space age plastic, and is VERY tough! You can't get crazy with it though!
When you have gone almost all the way around the bezel, the last few inches may just pop up, and out.
This link shows you with photos, and information, for a Gateway MT6704 Notebook PC,
http://www.insidemylaptop.com/remove-lcd-screen-from-gateway-mt6704-model-ma7/
This guide is to completely replace the LCD screen. You can just use the information under the first five photos, for bezel replacement.
Posted on Aug 20, 2009
  • 98 Answers
SOURCE: how to replace Dell inspiron 1520 inverter
Have to call Dell technical support.
Posted on Oct 07, 2009
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
Looking for circuit for Dell inspiron 1520 to trace power from psu, it isnt reaching the computer or battery could be protection diode ( if there is one)
I'm not sure how you checked the PSU but it is often the case that the voltages measure correctly but the PSU still will not work in the computer. I had one recently.
I would buy a new PSU and replace it. If it still does not work, you can return the PSU. Unless you have a complex PSU tester, I would put my money on the PSU being defective.
Sep 02, 2012 | Dell Inspiron 1520 Motherboard
My dell inspiron 1520 does not work at all, power
no this is not a defect this would indicate that the power supply has failed on your pc.. look at the back of the unit if the power supply light is amber in color or blinking thne there is your issue.
May 13, 2010 | Dell Inspiron 1520 Motherboard
Usb and webcam problem with a Dell Inspiron 1520
http://www.driverdownloadcentral.com/top.php?csvkeyword=USB-2.0-Drivers try downloading some drivers so that your usb ports connect wth the software on your computer. Really hope this helps.
Jun 24, 2009 | Dell Inspiron 2200 Notebook
Solution for ''the power light for dell inspiron 1520 turns on for about 5 seconds and goes out
If there is a yellow light on the front panel, indicates a faulty AC adapter. If you know someone with an Inspiron 1520, test with their adapter.
Jun 13, 2009 | Dell Computers & Internet
Dell batteries.
Its time change ur batteries
Aug 16, 2008 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
73 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
