Question about Philips 190B6CB/27 19" LCD
Main control problem
A box keeps popping up on screen - sometimes says "OSD Main Controls locked" and then "OSD Main Controls Unlocked". I've had this problem before which someone in your organisation helped me to fix but unfortuntely I can't find that message to check to see what we did. That was back mid-January.
    Genius:
  • 1,239 Answers
Hi  These are the solutions i found check these and try i think your problem will be solved 1.Reset the OSDThe easiest solution to try is to reset the on screen display in the menu. Hold down the Menu button (it is probably marked Ok) for at least a minute. A menu list will appear on your monitor screen. Using the adjust button, press the arrows to enter the menu. Scroll down to the Reset section. On the right side of your screen, you will see an alternating Yes/No choice. When the Yes message flashes, press the Ok button. The menu should be reset and the flashing OSD control message should disappear.
2.Fix the Menu Button
If resetting the OSD doesn’t work, then you probably have a physical problem with your Menu button. Sometimes, particularly on older machines, the connections to the circuit board are dirty or failing. Because you have to actually get into the monitor itself, you will probably void any remaining warranty by attempting this fix. If your monitor is still under warranty, contact the manufacturer to see if there is a local repair shop that can help you.
If you want to tackle this issue yourself, grab a screwdriver and take the plunge. Remove the casing on the monitor itself and locate the contact switch for the menu button on the circuit board. Sometimes, just working it with your fingers or a screwdriver is enough to unstick it - you can try to clean off any dust or grime that has accumulated around it to see if that is the cause.
3.Disconnect the Menu Button
If this doesn’t work, disconnect the button all together. This will definitely solve the problem, but you will no longer have access to your menu options. Given how many times over the lifetime of a monitor you actually access your OSD settings, this may not be such a hardship. You need to weigh the inconvenience of not being able to access the menu with not having that annoying OSD message flashing in your face.
Posted on Mar 12, 2009
    Brigadier General:
  • 8,619 Answers
Press the Menu button (marked OK) for one minute, or more then a blue/red menu list will appear on the screen.
Then go to the Reset section and reset it. This will resolve the issue.
Please let me know for further clarification.
Thanks
Rylee
    Sergeant:
  • 320 Answers
  • 4,472 Answers
To unlock the OSD Controls press the “MENU(OK)” button for more than 10 seconds while there is video input from PC.
If this doesn't work let me know and I can assist you further. Please take a moment to accept and rate my solution accordingly.
Thank you,
Lee
    Sergeant:
    Champion:
  • 289 Answers
Hi..To unlock the OSD Controls press the ?MENU(OK)? button for more than 10 seconds while there is video input from PC. try this out.. thank u..
  • Hariharanath V Mar 12, 2009
    hi..If you still come across the problem unscrew the stand,
    remove two small philips head screws and manage to free the
    case on three sides using a using a pen knife to release the clips
    this is enough to bend it out of the way and see a narrow circuit board
    containing all the push button switches behind the front panel. This is
    easy to remove by unclipping it from the chassis and unplugging the cable.
    There was no visible dirt, dust, dead cockroaches or anything like that but
    give the switches a good scrub using an old toothbrush dipped in metho
    paying particular attention to the suspect menu button.
    check this out..
    it will work out..
    thank u..
  • Philips Master
  • 13,433 Answers
It sounds like the buttons are locked and then they get unlocked. You can find your previous solutions and sessions by opening my profile from the top right corner then scroll down to your problems and sessions you can open the sessions by clicking on the name or view session button.
I would suggest to check that no buttons are stuck.
  • Ekse Mar 12, 2009
    i see you have had two chat sessions, you can view them in your profile. Also I found this solution offered to you
    This type of monitor has problems with the switches. The switches behind the push buttons malfunction after two or three year of use.
    If the "OSD main control lock" and unlock appear, you have to change the ok push button switch. The switch it self is only 25 cents. However if you never used a soldering gun you should ask an experienced repairman to fix it.
    All other problems are related to malfunctioning swithes with the other controls such as volume or brithness. I fixed the problem in 15 minutes and 25 cents
    Sergeant:
  • 254 Answers
Unplug all the connections for 1 hour from main power ouutlet and reconnect it again.
Osd main controls locked
Press the OK button for 15 seconds. That should unlock it.
Apr 25, 2010 | Philips 170B4MG 17" LCD Monitor
I have a monitor philips 190S and the osd main control is locked. how i can unlock?
23 Oct 2008 ... There are a few things you can do to solve the problem, ... The menu should be reset and the flashing OSD control message should disappear. ... controls locked, then it comes up again saying OSD main controls unlocked. ... I have a Philips 190S monitor. I do have a button to enter the onscreen menu. ...
filetonic.com/blog/2008/10/23/osd-main-controls-blocked/
Dec 06, 2009 | Philips 190S7FB 19 inch LCD Monitor
Osd main controls locked/unlocked pops up every 5 seconds
Estava também com o mesmo problema de voces, já estava irritado, então abri o monitor e desconectei a ligação com a placa de controle dos comandos dos botoes do menu. é fácil fazer. Só que não vai funcionar mais os botoes. pelo menos essas mesagens não vão mais incomodar.
Mar 28, 2009 | Philips 170S7FS 17" LCD Monitor
Problem with OSD Main Contorls unlocked/locked
Philips say "To unlock the OSD Controls press the “MENU(OK)” button for more than 10 seconds while there is video input from PC."
Jan 29, 2009 | Philips 190B6CB/27 19" LCD
Every few seconds a box pops up on my screen saying Attention OSD Main Controls Locked and sometimes the same message saying Unlocked Pls help me to deal with this problem
Philips say "To unlock the OSD Controls press the “MENU(OK)” button for more than 10 seconds while there is video input from PC"
Jan 15, 2009 | Philips 190B6CB/27 19" LCD
Hold the "OK" button for about 20 seconds
It will initialy come up with the message "OSD Locked" and then after the 20 seconds a ne message will appear "OSD Unlocked"
Dec 20, 2008 | Philips 150S4FB 15" LCD Monitor
Help with my 190S monitor
I have Philips 19C monitor. From today, every 5 secs an attention message
"osd main controls locked and unlocked"
The AUTO(OK) bottons for 10 sec not give nothink
What i can to do with this?
Gregory
my mail - communar@agry.gov.il
Thanks
Aug 22, 2008 | Computers & Internet
Philips monitor 190b6cb/175
Same problem OSD main controls locked the 5 seconds later OSD main controls unlocked then system closes down sayingproblem with atkdisp, what does all this mean? Can still operate my computer but thid damned flashing OSD message continues.
Aug 10, 2008 | Philips 150S4FB 15" LCD Monitor
OSD lock
All buttons can be locked or unlocked when the 'Menu' button is pushed and held for over 15 seconds.
May 12, 2008 | Dell E152FP 15" Flat Panel LCD Monitor
Press the Menu button ( marked OK) for one minute, or more, and a blue/red menu list should appear on screen.
Using the adjust button (immediately to the left of the OK button) by pressing the arrows at each end up or down as required you can enter the menu and select an action by scrolling.
At the end of the list of possible adjustments on the left of the screen (brightness, contrast, etc) is the Reset section.
On the righthand side of the screen is a flashing Yes No choice which automatically alternates.
The trick is to select the Reset choice on the left and while selected press the OK button when the Yes alternative on the right of the screen is flashing.
You VDU should then Reset and all will be well.
Mar 26, 2008 | Philips 190B6CB/27 19" LCD
Philips 190B6CB/27 19" LCD Logo
98 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
