Question about Konica Minolta bizhub 350 All-In-One Laser Printer
My bizhub 350 is starting to make " dirties copies"
I´m having problem with my biz six months old and 90000 copies made.
Often I get copies unclean.
    President:
  • Konica Minolta Expert
  • 347 Answers
Proper service and periodic maintenance is required for your Biz.its drum unit's life is 1 lac copies.
Posted on Nov 16, 2010
Hi. i have bizhub 350. my problem is the toner hopper is not spinning/rotating. hv already changed the developer,the toner replenishing box and the drum assy, whole unit. what seems to be my problem here....
Sir, the toner bottle motor assy. needs to be replaced. will take quite a bit of work to get to, recommended a service tech qualified on Biz hub 350. This series is well known for the toner bottle assy. fault as is the di3510 series prior to the Bizhub 200/300 series.
Mar 25, 2015 | Minolta bizhub 350 Black and White Copier
Wanted suitable konica minolta black and white copier to be installed in a school
First for a school you will need to know the volume of copies you are going to use per month.Then go from there, there so many segments.For example 30k to 40k per month would put you in a segment 4 something like a konica Minolta Biz Hub 601 or Biz Hub 750
Sep 07, 2010 | Konica Minolta Bizhub 222 Black and White...
Printing PDF to Bizhub c252 issue
I had this once. We simply deleted the Printer Driver and reinstalled it. Also, when reinstalling the Printer Driver we chose the PS (PostScript version).
Try that - hope it helps
Kind regards
m-press.biz
Apr 26, 2010 | Konica Minolta bizhub C250 All-In-One...
Optional Fax Kit FK-503 Installation
yes there is a manual, but it required certified technician by konica to install this for you or authorized dealer.
Jun 10, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica/Minolta biz 350 C2557 after replacing DV unit and drum F8
tha minolta di3510 developer unit looks the same as the unit for the konica minolta bizhub 350 but the toner sensor in the minolta unit uses a different voltage range for the toner sensor and it will throw this code make sure you have the correct unit for this machine also you can try this
go back into tech rep mode and change these settings:
select tech rep choice mode
select printer tab
select atdc sensor gain
set the value to about 165
then back all the way out to the ready screen and power the machine off then back on and replenish toner in the user management screen.
Apr 22, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Bizhub C650 (Minolta printer, copier)
setup for adf if is new machine u have the setup **** for adf
the setup **** (A4 page) with black border
Oct 13, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
271 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
