2004 BMW M3. Radio/CD player just stopped working. GPS works. The power button is on. Won't turn off. Seems that the left side of the radio is frozen. All the GPS buttons work on the rightside of the player. CD's and Radio won't work. Please help. What is the deal? Is it a quick fix or do I need to buy a whole new radio?
MArch 16 2009 I have an 04 m3..Everything worked fine except until this morning.exact same thing.cd doesnt work and radio, noir the buttons for them???
AnonymousMar 21, 2009
Same thing. I have an 05 M3 and the radio just stopped working. GPS works fine, but the radio and CD wont turn onSame thing. I have an 05 M3 and the radio just stopped working. GPS works fine, but the radio and CD wont turn on
AnonymousApr 24, 2009
Same problems this morning - any ideas guys? Same problems this morning - any ideas guys?
AnonymousMay 07, 2009
Same problem! '02 325i Same problem! '02 325i
You can't post conmments that contain an email address.
Check your relays the accessory relay right hand upper corner and the run relay middle left side if they are the same relay switch them and see if that works if not could be the body control module. Realys under hood to the right of the battery
One of the buttons has got stuck, so when you press the button you want to, its not getting the message to start / stop playing. This is also why the eject won't work. Either a new button, or replacement board would make it happen for you :)
DOES THE RADIO PLAY? HERE ARE THE FACTORY WIRING COLORS FOR THE RADIO HARNESS, RECHECK YOUR WORK. IF U FIND NOTHING THEN IF THE RADIO PLAYS THE CD PLAYER IS DEFECTIVE, IT HAPPENS BELIEVE ME.
2001 Chrysler 300M Car Stereo Wiring Diagram Car Radio Battery Constant 12v+ Wire: Pink Car Radio Accessory Switched 12v+ Wire: Red/White Car Radio Ground Wire: Chassis or Strap Car Radio Illumination Wire: N/A Car Stereo Dimmer Wire: Orange Car Stereo Antenna Trigger Wire: Orange/Red Car Stereo Cell Phone Mute Wire: N/A Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: Located under the rear deck in the trunk. Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Dark Green Left Front Speaker Negative Wire (-): Brown/Red Right Front Speaker Positive Wire (+): Violet Right Front Speaker Negative Wire (-): Dark Blue/Red Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Brown/Yellow Left Rear Speaker Negative Wire (-): Brown/Light Blue Right Rear Speaker Positive Wire (+): Dark Blue/White Right Rear Speaker Negative Wire (-): Dark Blue/Orange
