SOURCE: Kenmore Ultra Wash Dishwasher; Model 665.17539
I have a Kenmore 665 about 3 years old
Over the last couple months the touch pads have stopped working and I am now down to one control the water miser!
Do I need a new control pad and is that easy to install ?
Thank you for any sudgetstions
KC
SOURCE: Neff S5433 Dishwasher - Detergent tablet not dissolving
Hi!
Please run the machine without detergent for 2-3 washes. Also try using a little hot water. Also, don't used cleaner and softener together but add softener on the last rinse.
SOURCE: Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
SOURCE: Does not cleans dishes
Hi
Thanks for using
FixYa. First of all please check the Water temperature by using a thermometer
inside the dishwasher to measure the water temp. It should be as close to 125
degree F to 140 degree F as possible. Now try using the temperature boost feature
if your dishwasher is equipped with this cycle feature and check if this will
help your wash ability issues.
Now check the
Powder soap by making sure that you store your soap in a dry environment and it
is not stale and clumping together. Possibly try a different detergent like a
liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is
not overloaded.
To check the
proper filling dishwasher will fill with water up to and around the heating
element. If water is more below the heating element, you may have low water
pressure or a problem with the fill valve. Try & listen if it sounds like
it is spraying the water around with enough pressure.
For low water
pressure, try to clean the screen at the entrance of the fill valve, sometimes
the fill valve can fail and not allow the proper water into the dishwasher and
may need to be replaced. And, check the spray arm and pump cover for
splits or leaks. Also make sure that the water is draining and is
not accumulated in the dishwasher, if it is in dishwasher then check
for clogged drain hoses and drain pump.
Low water fills
are a very common trouble maker with today's dishwasher.
Please do rate this solution and
revert for further assistance.
Thanks
Rylee
SOURCE: Detergent Packets not dissolving
Check your heating element..
Dishwasher Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
