Question about Nikon D50 Digital Camera with 18-55mm Lens
Sb 600 i have nikon d 50 with nikon flash sb 600. sometime ago when i wanted to shoot a picture, i insert the batteries in sb 600, there was something wrong and it not flashed and its display blinks which not stopped yet how can i fix it and what's the problem please tell me....
    Genius:
  • 2,985 Answers
Switch camera off and remove batteries. Leave for half an hour. Re insert batteries switch on set to flask and hold to ear. Can hear a whistling [This is the Flash charging up] If you cannot -assume the flash unit has failed. Now go to the Manual - A full version is in a PDF file on the Disc. Check through that you are doing every thing correctly. If still no lick Nikon customer support will advise your next move. The likely hood will be that if the camera is over a year old they may offer a discount on a replacement. A repair is not likely or very pricey.
Posted on Aug 03, 2007
Won't turn on
Ric DonatoSorry to hear that with fresh batteries it will not turn on. If it used to turn on, then now there is something wrong with the flash. Other than using different batteries, making sure they are in the correct order, and still it does not flash it will need to go to Nikon repair. Yes, I would not want to hear that answer, but that may be the only solution.
Nov 28, 2013 | Nikon Speedlight SB-600 TTL Flash
NIKON SB800 IN SOFTBOX
Hello..
Sporadic off camera flashes triggered with pocket wizards will not be as obtrusive as you may think. IMP, It's just as obtrusive as the onslaught of small digi cam flashes that usually occur..Cheerss!!....
Jul 24, 2008 | Nikon Speedlight SB-800 TTL Flash
Bought a Nikon Speedlight SB-600 in August. Tested the flash and it fired ok. I took out the flash a few days ago to use at a graduation and the "ready" light did not come on. Consequently it did...
Hi grwcamp, Sorry to hear about it not working at the graduation. Are in the correct position (I am sure you did but, we must start someplace). Look inside, see if there is battery acid in there.
If with new/fresh batteries it still does not work call Nikon. You have a warranty on it so it should be covered.
Nikon digital 1-800-645-6689
Dec 04, 2010 | Nikon Speedlight SB-600 TTL Flash
Nikon Speedlight SB-600 keeps firing
I believe that there is a safety feature built in that if the voltage in the capacitor gets too large the flash will fire, to prevent damage, could be this that is faulty, if it is a new main circuit board is required.
Aug 31, 2009 | Nikon Speedlight SB-600 TTL Flash
SB-600 Flash will not charge/everything else works.
check wire connection to capacitor measure voltage on it/
Be carefull high voltage!!!
May 12, 2009 | Nikon Speedlight SB-600 TTL Flash
Nikon SB-600
seems like the batteries have gone dead. Replace the batteries. Get a set of good capacity rechargeable NiMH batteries (I recommend Sanyo Eneloop). Also try cleaning the battery and flash contact points with an eraser.
Feb 03, 2009 | Nikon Speedlight SB-600 TTL Flash
SB-800 -3EV message after about 50 shots or so
IN THE INSTRUCTION MANUAL USING THE FLASH IN SHOOTING FAST CAUSES IT TO HEAT UP .
TRY USING THE FLASH IN MANUAL AND CUT THE RATIO POWER AND USE AS A FILL AND NOT A MAIN .
YOU COULD ALSO USE TWO NIKON SB800 FLASHES IN ITTL AND WITH TWO THE FLASH IS USING HAVE THE OUTPUT AND RECYCLE TIME IS INCREASED .
DAVE BLACK A WELL KNOWN PHOTOGRAPHER DOES THIS IN HIS SHOOTING .
BERRIE SMITH CAMERA REPAIR
bbmw@bellsouth.net
Nov 13, 2008 | Nikon Speedlight SB-800 TTL Flash
Nikon sb-600
Sounds like your camera is on "Slow synch" or "rear curtain" mode..
Nov 15, 2007 | Nikon Speedlight SB-600 TTL Flash
Nikon D50 Digital Camera with 18-55mm Lens Logo
89 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
