Question about Stihl Garden
My stihl 015 AV chain saw has no spark to the spark plug how do I fix this?
New spark plug.
SOURCE: Chain Saw, Stihl Model 011, cutting off
I've been messin with my poulan 2150 that was doing the same thing. Good, fresh gas, good spark,etc. I noticed whenever I loosened the fuel cap it would literally spray gas out! alas, I removed the muiffler assy and the darn thing fired up the first pull! I've got the muffler parts soaking in gas right now and I'm sure this the problem. It just makes sense especially if you use the same 'mixed fuel' can for weed eater, blower,etc. Check your's out, it could very well be your problem too! GOOD LUCK
Posted on Apr 29, 2009
  • 583 Answers
SOURCE: Stihl ms 250 chain saw won't start, doesn't seem to catch spark.
dry the plug asmall squirt of aerostart in the top of carbywith air cleaner off full throttle pull the rope and she should fire up make sure the on/off switch is in the correct position. no don`t laugh ican remember nearly completely stripping amotor years ago before ichecked it put it all back together and it started first go try the aerostart and switch
Posted on Aug 04, 2009
dontbother10
  • 2220 Answers
SOURCE: owners manual for a Stihl 034 AV Chain saw
Stihl Manuals
http://www.stihlusa.com/information/info_product2.html
For an IPL you must contact them.
HTH
Lou
Posted on Oct 19, 2009
dontbother10
  • 2220 Answers
SOURCE: I need a repair manual for stihl ms192t chain saw for down load
Stihl considers ALL IPLs and shop manuals proprietary.
Every time Stihl becomes aware of an on line source they force its removal.
Rules here prohibit any expert from providing you an e-mail address, if I had what you seek I cannot provide a link where you can get it.
You can go here:
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
A large international collection of chainsaw enthusiasts, sellers and mechanics. Not only can you find what you seek you can find someone that has already done it, experienced the pitfalls you will meet, and overcome them. Please do a few searches before posting any question. Joining an existing thread is almost always more fruitful than posting the 4th, 5th, 6th question all asking the same question. HTH
Lou
There are many threads pertaining to Stihl, many also discuss overhaul of different Stihl models. Good Luck
Posted on Feb 04, 2010
Testimonial: "I THANK YOU FOR THE EXCELENT ANSWER. I WILL TRY YOUR SUGGESTION TO SEE WHAT HAPPENS SEEMS LIKE A POOR WAY TO RUN A BUSSINES. GEORGE"
lindsay836
  • 677 Answers
SOURCE: i have stihl chain saw it runes full throttle
After you let off of the throttle it dies instantly or just kind of quits slowly ?
It could be :
- 1 ) Your clutch is hanging up and not allowing the engine to idle while the chain is not moving.
- 2 ) You need to set the idle higher. You will need to remove the air cleaner, and find the small idle adjustment screw, and turn the screw clockwise, until it idles.
Please let me know.
Posted on Feb 08, 2010
I need a choke lever for a Stihl 015 AV chainsaw. Could you tell me where I might find one?
Many parts for these saws are obsolete due to age. If not available at local Stihl dealer check online for Ron's saw shop. He does a lot of obsolete parts.
Dec 28, 2016 | Stihl Garden
Need sparkplug wire for ms180c chainsaw
Robert, spark plug wire for Stihl MS 180C. Check the attached links, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Ignition Coil Spark Plug Wire Fits Stihl 017 018 Ms170 Ms180...
New Ignition Coil Spark plug wires for Stihl 017 018 MS170 MS180 Chainsaw...
Amazon com IGNITION COIL MODULE FITS STIHL MS170 MS180 017 018 ENGINE...
Jul 30, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
What brands chain can i use on an 025
well im sure stihl wants you to use there's , but Oregon makes nice ones too
its allways a good idea to have two chains and 1 spare spark plug for your saw , these are a sort of "must haves!!" for saws , oh and a wrench that fits the spark plug and the chain bar too , Oregon makes one of those combo wrenches 4 that too
Sep 18, 2015 | Stihl Garden
Air gap and spark plug gap 025stihl chain saw
the air gap is about a business card thick and the plug gap is .020. Stihl has a special tool to measure exact air gaps so the business card is close
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Mar 20, 2013 | Stihl Garden
How to remove the clutch assembly on a stihl 015 AV
Remove spark plug.
Use a piston block to stop the piston rising.
Remove the chain sproclet cover.
Turn the clutch with a socket clockwise to undo.
Dec 11, 2012 | Stihl Chainsaw Hedge Trimmer Clutch 015 Av...
Can not start the ms180 chain saw, tried new plug, new gas, starting fluid etc. suggestions ran this morning, and now will not start. only been used twice
Remove the plug and then plug into plug wire. With the spark plug laying on top of engine pull the recoil a couple times and you should see spark at the plug. If all is good and there is the proper mixture of gas/oil ratio in saw then >>With trigger depressed fully and choke on, pull until it fires and then shove the choke in. /////If no spark and the saw is new, I would return to retailer.
Sep 25, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
The starter rope doesnt pull, and when the saw is
sounds abit like it ,but remove the spark plug and you should be able to rock the flywheel back and forth. sounds a bit like no oil in the gas or at least insuficient oil and may have grabbed, (i assume you have the chain and bar off the powerhead,if not then remove them ,and then try ) it could also be the centrifgal clutch jammed up.
Dec 29, 2009 | RTO Spur Sprocket For Stihl 017, 021...
Length of bar on a Stihl 015 chain saw
measure from the very front edge of the bar back to the gripper teeth
May 16, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Garden Logo
187 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
