I have just bought a ditto calculator and do not understand the memory functions or the MU
WHAT IS THE FUNCTION OF MU BOTTON IN CALCULATOR CASIO MJ-120D?
It is used for calculating markup. For example, if you have an item at $100 and have a 20% markup, you get $120.
http://support.casio.com/storage/en/manual/pdf/EN/004/MJ-100D_MJ-120D_EN.pdf
Sep 20, 2015 | Casio Office Equipment & Supplies
CITIZEN CT-512
MU is probably Mark Up key.
Nov 14, 2013 | Casio HR-100TMPlus Calculator
Memory Error
Exactly what were you trying to do? It helps to understand the problem you are having. Usually it means that the result exceeds the capacity of the memory (Too big). The upper limit for the calculator is 9.9999999.. *10^(99) or 10^100.
Nov 14, 2013 | Casio FX-9860G Graphic Calculator
What do RM/CM MU GT RV STAND FOR ON MY CANON AS1200
MU markup, GT Grand Total, RV reverse function
Apr 24, 2012 | Office Equipment & Supplies
What do the following keys signify? Or do? GT MU MRC AC, CE ON/C 00 +/-
Hi, here are some of the answers to your questions.
GT:- Grand Total: It shows the cumulative total of your calculations
MU:- Mark Up: It is used to calculate the CROSS PROFIT MARGIN in business environment.
MRC:- If pressed once, it shows the number stored in the memory. If pressed twice it clears the memory.
AC:- All Clear: It clears everything
CE:- Clear Entry: Clears the last entry of calculations.
ON/C: If the calculator is off, it turns it on. If the calculator is on it clears all entries.
If you have any more questions you can visit this site: http://www.aurora-ltd.co.uk/OpInst/FunctionsGuide.htm it has almost everything covering the calculator buttons.
Lujaina96
Feb 12, 2011 | Office Equipment & Supplies
I tried graphing 1/(1+3e^(-2x)) and it said mem error. I tried deleting some stuff on my memory and it still won't graph.
At first, I though that the numbers could be groeing too much for the memory. But if you rewrite the function you see that it is one of the best behaved ones you can get
e^(2x)/(3 +e^(2x))
As x increases the function tends to 1.
The only reason why you are running out of memory may be due to some old graphics that are stored. You should get rid of them, even resetting the RAM if need be.
I understand your frustration at not being able to draw it. To alleviate this frustration, I am enclosing a picture of this function.
Hope it helps. Thanks for using FixYa.
Nov 18, 2009 | Casio FX-9750GPlus Calculator
INSTRUCTIONS FOR THE KEYS ON THE CALCULATOR
To get a subtotal when adding, finish entering the last number before the subtotal, hit the +, then hit the diamond/pound sign key (just above the 7)
To get a grand total when adding, finish entering the last number in your list, hit the +, then hit the *.
Jan 14, 2009 | Casio HR-100TMPlus Calculator
Memory
when you press the keypad the calculator scanline translate and encode this function to digital formula(1&0)which the brain can understand(microprocessor)and this digital formula stored in a store called register which can easily called out to go to display where you can see it.
Nov 03, 2007 | Casio FX-115W Plus Calculator
69 people viewed this question
jasbo
jasbo
