Question about AEG Lavamat 74640 Front Load Washer
HOW TO CHANGE CARBON BRUSHES IN AEG LAVAMAT
CODE C9
SOURCE: Washing Machine Fault Code
The recommendation to get a new motor may be overkill and a very expensive option. Also on this site I found an alternative solution which was to just replace the motor brushes. This we did and it fixed the problem, coasting us just £20.15, rather than the £199 quoted for a new motor!
A reasonably competent person needs to remove the motor, identify the brushes and remove - just involves two hex-head screws. When new the brushes will be around 2.5cm long. They need to be around 1 - 1.5cm long to work. Alternatively the spring(s) may be sticking, preventing the brushes from being pushed against the rotor.
When calling suppliers to enquire as to availability I needed not just the product description, but also the PNC and serial numbers (located inside the front door), as types of brushes have varied during the production period. However the outlet I went to still did not have the correct bush - housings were different. The chap serviing very kindly swapped new brushes into the existing housings - this is something you could do yourself if you cannot get the exact same ones - just a little fiddly.
Hope this helps!
Posted on Sep 25, 2008
SOURCE: My AEG OKO-Lavamat 72600 shows error code C9 what
My ariston aqualtic has finnish as language how to change to for ex english
Posted on Oct 30, 2009
SOURCE: AEG Oko-Lavamat 86820 Update Error code C9
Hello. I got error code C9 on a LAVAMAT 86800. It pumped in water, and it pumps out water. You can select pump in or out....But the motor dont turn. It will not sentrifuge. So I bought new carbon brush'es on the net. One of them were totally wore down. Now it works. They lasted for 10 years.
Posted on Feb 05, 2010
taran_2005
  • 10515 Answers
SOURCE: What means error code
C9 Indicates Motor Fault. It seems that the Carbon Brushes have Worn out.
Replace it and more likely it would Fix the Problem.Once you replace that, you need to put the machine into Service Mode to Reset the Error.
Steps for Reset the Error Code
1. Press and Hold the Prewash and Soaking Buttons Together.
2. Whilst Holding them, Turn the Dial from Off one Click Anti Clockwise
Note - If problem persists, Check the motor plug for broken wires and check the state of the carbon brushes.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 28, 2010
  • 174 Answers
SOURCE: What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
Posted on Jul 16, 2010
How to reset aeg 88840 update ? Have c9 error, don't know reset combination, please help!
Error code C9 means tachometer impulses are missing so you could check carbon brushes (mostly), motor drive, tachogenerator, wiring.
Dado
Feb 22, 2015 | AEG Washing Machines
AEG Lavamat 72 620 What does error code C9?
c9 means the electronics is not detecting any drum movement. check the carbon brushes in the motor this is usual culprit.
Aug 29, 2010 | AEG Lavamat 72640 Front Load Washer
Jul 14, 2010 | AEG Lavamat 72640 Front Load Washer
C9 error? how can i fix it? thanks
check the carbon brushes in the motor.
Jun 16, 2010 | AEG Lavamat 72640 Front Load Washer
What means error code "C9" ? AEG Lavamat 76669
Hope i helped you.
Feb 28, 2010 | AEG Lavamat 88840 Front Load Washer
Jul 04, 2009 | AEG Washing Machines
AEG Lavamat washing macine C9 error code
C9 is a motor fault.
Normally it's worn out carbon brushes so you'll need to check them first.
If worn out or broken, replace them.
Then, you need to erase the code (reset the machine).
To do this, turn the dial to off.
Press and hold together, prewash and soaking buttons.
While holding them, turn the dial 1 click anti clockwise.
Release the buttons.
Turn the dial to off, to any program and back to off.
This should get rid of the C9 code.
It will come back if you don't repair the motor fault.
Dec 10, 2017 | AEG Lavamat 88840 Front Load Washer
Aeg oko lawamat
c9 means the motor is not turning the drum. check carbon brushes in the motor.
Oct 29, 2008 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat 74640 Front Load Washer Logo
205 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
