Question about Lemax Village Collection Belmont Carousel, With 4.5v Adapter
Lemax carousel has stopped rotating
My carousel has stopped rotating. I could get it going before by starting it off but now it won't. Is there a way it can get it going without pulling it apart?
3 Suggested Answers
SOURCE: Where can I get my Lemax Belmont Carousel fixed?
Hi
There is nor repair service for Lemax
I started in januarie 2010 a repair service on my own'
But have a difficulty with spare parts
sometimes i make spare parts on my own but this takes lots of ours to make it
And if the owner wants a chepa deal it is not possibel
most of the time it is cheaper to buy a new one.
But
Sometimes it is also a loose wire that is the problem
I made today two carousels
and one of the two is already ok
the other one needs a new spare part so i can not fix it at the moment til a have a donor carousel
Here in the netherlands all of the broken lemax items that are going back to the seller are being demoilisht or crached under a walz
I phone them if they would sel these items to me
but that is'n't possibel
so they make it hard for us repair nerds to help people like you
If you are living in the netherlands i ill thake a look at your carousel
if i can fix it it will cost you 20 euro/s
if not 10 for taking time with it
If you are living in england maybe you can send it to me by mail
I hope to here from you
John Bogers
The Lemax Doktor
Posted on Feb 25, 2010
jimfire1
looking for a motor for santa hot air ballon...9 volts...lemax
Posted on Dec 15, 2014
MR. CHRISTMAS CAROUSEL WON'T TURN
I realize this post is way old, but wanted to thank LtJim for his description on how to take it apart.
It turns out the reason mine was not spinning is that one of the plastic mechanisms that make the horses go up and down (located under the main piece that comes off with LtJim's directions) had partially broken and that horse would go all the way to the bottom and then the carousel would stop spinning.. There was no way to fix the plastic, but by holding the horse up with zip ties hidden under the top got the thing to work again. Thanks again!
Dec 12, 2012 | Toys
I PUSH THE START BUTTON THE GAME KEEPS ROTATING SCORING POINTS AND WON'T STOP
You might want to repost this in a different section, even video games.
Jul 26, 2012 | Cars & Trucks
Sharp R-520KS - When the door is opened, the light and fan comes on and the carousel rotates. I don't know if microwaves are emitted. How can I stop the fan from coming on and the carousel from...
You can tell if microwaves are being emitted if you get warm standing in front of it (seriously). But I wouldn't recommend that unless you want to cook yourself.
First thing that comes to mind is the door interlocks are out of adjustment or bad. Home microwave ovens are not supposed to operate like that. Some commercial models start the fan right away and run it after the cooking cycle is completed but I've never heard of a consumer model that does that.
Find your closest servicer here and have them take a look.
Sep 04, 2011 | Sharp R-520KS Microwave Oven
My Kodak Carousel 650H has a stuck slide and the tray won't move. The stuck slide is lined up with the "gate index." I tried releasing the tray but only one side of the tray releases. The...
Two steps.
1) Look down into the center of the carousel. There should be a round, flat silver knob with an elongated notch in it. Take a coin (US 5-cent piece or similar) and use it to turn the knob. This releases the catch on the metal plate under the projector. You should then be able to lift the carousel off. Be careful: some slides will fall out as the slot is not aligned with the carousel body properly once you do this.
2) Make sure the locking ring on top of the carousel is in place (or else take out all your slides. Turn the carousel over and gently rotate the metal plate covering the bottom of the carousel into position. You will hear/feel a "click" when it's in place.
The projector may have jammed because there are two slides stuck in the viewing slot--check for this before you put the carousel back on the projector. If it jams a lot the metal plate under the carousel may be bent.
Jul 17, 2011 | Kodak Carousel 4600 Slide Projector
I have a Konica Minolta Magicolor 1650en. When replacing color toner, I managed to install magenta and yellow, following menu prompts, but when I try to install Cyan, the cartridge doesn't...
I had a similar problem in that after changing one of the cartridges (I bought a whole set), the message "cannot rotate cartridge" appeared. I tried pressing the cartridge in more firmly and may have caused the carousel to rotate a little in the process. I cycled the power which seemed to clear the error message and allowed me to select the next cartridge to change, but upon opening the door to change it, was unable to remove the old one as it was positioned a little too high. I eventually cleared the problem by manually rotating the carousel by pressing in and holding the carousel release (see arrow) mmgazette.jpgwhile rotating the carousel downward slightly, to line the cartridge up as it appears in this picture. Then powered it back up and was able to do the normal cartridge replacement procedure for the remaining cartridges without further error messages.
Jun 11, 2011 | Computers & Internet
2550L carousel won' t rotate when I push the button. Need to get the cartridges out to put in a newer one that I bought.
This is usually caused by generic toner cartridges. The only way to turn the carousel is to take the top cover off and then manipulate the solenoide on the top right hand side of the printer. This allows the carousel to turn to where you want it.
Jun 09, 2011 | HP LaserJet 2550L Printer
Microwave lights, clock, and everything works except when you press start, it just counts down like its cooking, but the microwave is actually not on. No hum as usual or plate rotating. It just counts...
Hi, one of the most common reasons why the turntable won't rotate is that the microwave isn't clean. The turntable guide and carousel can get sticky, preventing the turntable from properly moving. If you have built-on food particles or liquids, fill a bowl with 2 or 3 cups of water and 1 tsp. of liquid detergent and lemon. Run the microwave for about 3 minutes. Clean the microwave with a cloth, including the base of the turntable, guide, carousel grooves and microwave base. Your microwave turntable won't rotate if the grooves on the base of the turntable do not sit right on the carousel. Also, check the position of the turntable guide. Place the guide directly under the turntable. Remove the turntable, and then reposition it into the carousel grooves.
Motor The carousel motor is located beneath the base plate of the microwave. If the carousel isn't turning at all, check the motor. Disconnect the microwave from the power source, and remove the turntable, guide and base plate. Try turning the motor to see if it's just stuck. If it doesn't turn freely after a few seconds, examine the motor to see if it's burned out or corroded. Use an ohmmeter to see if the motor has continuity. If not, you must replace the motor.
Bushings The drive bushings are plastic components that sit underneath the cooking plate. Remove the plate, and examine the bushings. Use a magnifying glass if necessary to see if any debris is caught in the plastic. Clean the bushings, and reinsert the plate. Turn the microwave on to see if it rotates. If the bushings are extremely worn or if some of the plastic is broken off, you need to replace it, which is a complicated repair for consumers. Contact a service technician for assistance.
May 07, 2011 | Amana Radarange Microwave Oven
Sharp R209ak, the carousel stopped rotating. Is there an easy fix?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;'
Apr 16, 2011 | Microwave Ovens
Where can I get my Lemax Belmont Carousel fixed? I've only had it for two seasons and it is not working.
Hi
But
John Bogers
The Lemax Doktor
Dec 28, 2009 | Lemax Toys
Lemax Village Collection Belmont Carousel, With 4.5v Adapter Logo
150 people viewed this question
Top Lemax Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Lemax Toy Expert? Answer questions, earn points and help others
