Question about Refrigerators
I like to now were the abs relay is on 2004c230. Compressor
    New Friend:
    Problem Solver:
  • 9 Answers
What kind of brand some are intact withe the PC board and some are in the starting relay are in the compressor.
Posted on Apr 21, 2013
Where is the location of 06 Saturn Ion 2 compressor relay?
Connector 1:
Fuse Block - Underhood Label (2.2L, 2.4L)
Connector 2:
Fuse Block - Underhood Top View (2.2L, 2.4L)
Connector 3:
Fuse Block - Underhood Bottom View (2.2L, 2.4L)
Connector 4:
Fuse Block - Underhood C1 (2.2L, 2.4L)
Connector 5:
Fuse Block - Underhood C2 (2.2L, 2.4L)
Connector 6:
Fuse Block - Underhood C3 (2.2L, 2.4L)
Connector 7:
Fuse Block - Underhood Label (2.0L)
Connector 8:
Fuse Block - Underhood Top View (2.0L)
Connector 9:
Fuse Block - Underhood Bottom View (2.0L)
Connector 10:
Fuse Block - Underhood C1 (2.0L)
Connector 11:
Fuse Block - Underhood C2 (2.0L)
Connector 12:
Fuse Block - Underhood C3 (2.0L)
Connector 13:
Body Control Module (BCM) Label
Connector 14:
Body Control Module (BCM) Top View
Connector 15:
Body Control Module (BCM) Bottom View
Connector 16:
Body Control Module (BCM) C1
Connector 17:
Body Control Module (BCM) C2
Connector 18:
Body Control Module (BCM) C3
Connector 19:
Body Control Module (BCM) C4
Connector 20:
Body Control Module (BCM) C5 (UE1)
2.2L
alt="Object Number: 1438995 Size: MF">
alt="Click here for detailed picture of above image.">
2.4L
alt="Object Number: 1583009 Size: MF">
Fuse Block - Underhood Label Usage (2.2L, 2.4L)
No.
Device
Rating
Description
ECM (2.4L)/TCM Fuse
10A
ECM (2.4L)/TCM
2-3
Not Used
RH HDLP Fuse
15A
Headlamp - Right
5
A/C Fuse
10A
A/C CLUTCH Relay
6-7
Not Used
8
ABS Fuse
10A
EBCM (JM4)
9
ECM/ETC Fuse
15A
ECM
10
EMISS Fuse
15A
EVAP Canister Purge Solenoid, Coolant Level Switch, MAF Sensor, HO2S 1, and HO2S 2
11
IGN Fuse
10A
ICM and PNP Switch (A/T)
12
Not Used
13
TRANS2 Fuse
10A
ECM, Automatic Transmission
14
TRANS1 Fuse
10A
TCM (MN5)
15
BACK UP Fuse
10A
PNP Switch (A/T) or Backup Lamp Switch (M/T)
16
INJECTORS Fuse
10A
Fuel Injectors 1-4
17
FOG LP Fuse
10A
FOG LAMP Relay (T37)
FOG LP Fuse
15A
FOG LAMP Relay (T96)
18
LH HDLP Fuse
15A
Headlamp - Left
19
WIPER Fuse
25A
WIPER 1 Relay
20
HORN Fuse
10A
HORN Relay
21
RADIO Fuse
20A
Audio Amplifier (UZ6)
22
ABS Fuse
20A
EBCM (JM4)
23
RR DEFOG Fuse
30A
REAR DEFOG Relay
24
A/C CLUTCH Relay
A/C Compressor Clutch
Jul 17, 2015 | 2006 Saturn ION 2
What do the fuse relays under the hood of a 1998 oldsmobile 88 ls control
You have fuses and relays . The fuses are or should br labled inside each cover if still there as well as on the fuse block itself, If not I can look under the hood of mine and tell you. The relays from left to right thats passenger to driver and numbered including the empty spaces as mine hase three on the right and two on the left with three emty slots in between. Now Olds seems to have kept this araingement for some time also my '98 88 has ABS as part of TCS but no relays there and diferent climate controls over the years it is posible you have more or less than are presnt on mine the complete list is as follows
#1 - AC compressor control for the compressors clutch
#2 - Horn relay
#3 - AC blower fan motor on, at low speed on the '98
#4 - AC blower motor off or high speed depending on year, not present on my "98
#5 - ABS pump relay ,not present on my '98
#6 - ABS Main relay also labled as pump relay for some years, not present on '98
#7 - High speed cooling or radiator fan
#8 - Low speed cooling or radiator fan
Feb 22, 2015 | 1998 Oldsmobile Eighty Eight
Abs control module on honda cr-v 2007
ok about the abs is possible that the abs cable that goes the the brake caliper is not good.about the brake light check brake fluid level filled up also check the sensor on the brake fluid container also check any malfuntioning wire connection corosive plugs.about the ac check compressor ad freon in order to kick on check the relay or fuses or the compressor is no good
Jul 13, 2012 | 2007 Honda CR-V
What on the land rover 3.9 (1996) does the 60amp circuit operate, on mine the fused area wiring etc has burnt out. Wether there is a connection, but I now have no heated sceen, no interior lidht and no...
RL1 Front Wiper Control Relay RL2 ABS Power Relay RL3 Air Suspension Power Relay RL4 Right Heated Front Screen Relay RL5 Left Heated Front Screen Relay RL6 Auxiliary Power 1 Relay RL7 Auxiliary Power 2 Relay RL8 Front Wiper Interval Relay RL9 Horn Relay RL10 Spare Relay RL11 Headlamps Wash/Wipe Relay RL12 Fuel Pump Relay RL13 A/C Condenser Fan 1 Relay RL14 A/C Condenser Fan 2 Relay RL15 Ignition Relay RL16 Starter Relay RL17 ABS Pump Relay RL18 A/C Control Relay RL19 Engine Main Control Relay RL20 Air Suspension Compressor Relay
Aug 23, 2011 | Land Rover Discovery Cars & Trucks
All relays and what there for
Looking over the fender at the fuse box, you see three rows of relays. The first row, closest to the engine, has three relays. Below that are two rows of six relays each. Counting from the left:
Row One 1) Fuel Pump Relay 2) Main Relay 3) Oxygen Sensor Heater
Row Two 4) Horn 5) Tail/Fog Lights 6) Low Beam 7) High Beam 8) Emergency Flasher 9) Heater/AC Blower
Row Three 10) Rear Defogger 11) ABS System 12) ABS Pump 13) Radiator Fan High Speed 14) A/C Compressor 15) Radiator Fan Low Speed
#15 in the lower right corner of the fuse box is the one that seems to take the most grief and fail the most often.
Mar 05, 2011 | 1990 BMW 3 Series
The compressor does not switch on there are electrisity if i test is can it be the black unit that fit on the compressor it is an hot point hd 250 ab serial no dehfoi 058 237l
Thats call the compressor relay most likley thats gonna be your problem unless you have a control board on the back of the ref.
Aug 22, 2010 | Hotpoint Refrigerators
2001 silverado abs pump wont stop running . runs with motor off. 227000 miles
swap out abs relay with a similar known good relay it's possibly a sticking abs relay
Nov 07, 2009 | 2001 Chevrolet Silverado 1500
Abs light illuminated
DTC C0121 will set if the valve relay voltage is low or if the relay supply line is at 12 volts when the ABS control module is not requesting it. This DTC will also set if the ABS control module detects three or more solenoid
valve circuits are open or shorted during the self-test.
Cause(s)
A connector terminal is corroded.
The wiring harness is damaged.
The ground terminal is not conducting properly.
The EBCM is defective.
the relay is internal to ABS unit.
Jun 13, 2009 | 2000 Daewoo Lanos
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
