Question about Cisco 2691 Series IOS
Hi all. Now i'm lose IOS of cisco 2691. help me! and give me how to load IOS to Cisco 2691 by tftp. thanks alot
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 80 Answers
Recovering Cisco IOS Software imagesIf your Cisco router experiences difficulties and no longer contains avalid Cisco IOS software image in flash memory, you can download a newCisco IOS image using one of the following ROM monitor commands:
Hi all. - blank.gifxmodem—(AllCisco 2600 series routers) Use this command to copy a Cisco IOS imagefrom the console, if the computer attached to your console has aterminal emulator with Xmodem capability. See the "Copying an Image from the Console Using the xmodem Command" procedure.
Note blank.gifDownloadinga Cisco IOS image from a console is very slow. This procedure should beused only in an emergency and is not recommended for normal Cisco IOSimage upgrades.
For the fastest possible download from a console, set the console speed to 115200 bps by using the confreg ROM monitor command. See the "Configuration Register Commands" procedure.
blank.giftftpdnld—(ExceptCisco 2691) Use this command to copy a Cisco IOS image from a TFTPserver that is accessible through the FastEthernet 0/0, Ethernet 0/0,or Token Ring 0/0 port. See the "Copying an Image from a TFTP Server Using the tftpdnld Command" procedure.
note.gif Note blank.gifThetftpdnld command is not available on the Cisco 2691 router. Therecommended method for installing a Cisco IOS image on a Cisco 2691router is from a CompactFlash memory card loaded in the externalCompactFlash memory card slot. See the "Entering Boot Commands" procedure.
P.S.: If this information was helpful, please rate this solution.
Posted on Mar 12, 2009
2 ios present on router
Hi Ian,
Current flash has the capacity to store multiple IOS files. You shall keep different versions of IOS into the flash and using boot var you shall configure the router to boot from specific IOS version Something like dual boot OS in your Laptop. You shall use Cisco IOS 15.3 (M,T,ST) for your CCNP Security certification preparation. For furhter details regarding IOS selection you shall use cisco ios selector tool share in link section. http://cfn.cloudapps.cisco.com/ITDIT/CFN/jsp/index.jsp
Nov 21, 2017 | Cisco Computers & Internet
Auto backup IOS of router.
If you want to back up your Configuration on any Cisco Router, You can just use RANCID (http://adi-sunardy.net/2008/12/24/how-to-automating-cisco-router-switch-firewall-backups-on-fedora/).
Or, some other solution:
  • ciscowork
  • ziptie
  • solarwind
  • cirrusmanager
Or follow these instruction: http://www.techexams.net/forums/ccna-ccent/22447-how-setup-tftp-server-backup-restore-2500-ios.html
Or You can read this: http://blogs.techrepublic.com.com/networking/?p=532
Hope it'll help
Mar 11, 2009 | 2wire HomePortal® 1800HW Router...
I have a problem with a cisco catalyst 2948G-L3. A have erase of mistake the bootflash. I have tried in some way to download a new IOS, i have the IOS bu i cannot download it in the flash because the...
Two ways to do that are xmodem (slow) or Tftp from rommon mode. (fast)
Place the IOS image in your tftp server directory and start tftp server.
Then enter the following in the switch exactly as below as all are case sensative:
rommon 1> IP_ADDRESS=xxx.xxx.xxx.xxx
rommon 2> IP_SUBNET_MASK=xxx.xxx.xxx.xxx
rommon 3> DEFAULT_GATEWAY=xxx.xxx.xxx.xxx
rommon 4> TFTP_SERVER=xxx.xxx.xxx.xxx
rommon 5> TFTP_FILE=full file name of ios as it reads
rommon 6> TFTP_CHECKSUM=0
this one is in lower case
rommon 7> tftpdnld
If you dont have a tftp server below is a link to a free one
http://www.solarwinds.net/Tools/Free_tools/TFTP_Server/
You will need the .bin IOS image for this and not the .tar file. The .tar file contains router cluster management files that you must issue the archive tar command to load all of the files. Can do that if needed after router is back online.
Feb 24, 2009 | Cisco Catalyst 2948G-L3 Networking Switch
ICMP packets not working on Dell Latitude D620
With vista I had the same problem, but when I enabled network fileshareing and set up some network drives it started to answer on ping requests, so it should be one of the networking protocols to enable.
Jan 14, 2009 | Dell Latitude D600 Notebook
Export and import all configuration in Cisco ASA 5510
Hello ,
the Steps which u want to export and import configuration in Cisco ASA5510
1- connect yourself to your Cisco gateway by IP
2- Get TFTP server to your PC like( solarwind , Tftp server , ... ) any tftp download and upload program
3- now u need to copy running configuration to your pc by order
#copy run tftp , then follow the steps
NOTE: u should be in the same network or u need your pc and cisco box both have publick IP
4- if u want to put prepair config files to your gateway , you will need to type order
#copy tftp run , then foloow the steps
If u need anything else please let us know by leave your completely request or join us with www.fixya.com
Regards,
Samer
Dec 17, 2008 | Cisco ASA 5510 Firewall
FAIL UPGRADE
run wireshark,  if you see it trying to access 10.0.0.1 via TFTP, IOS was wiped,  just set a tftp server on that address and it will download the dfault image.  search cisco to find out the name of the file it is looking for, or look through the wireshark packets
Oct 07, 2007 | Aironet 1100 802.11a/b/g LWAPP...
Upgrade firmware on a cisco ASA 5500 firewall
This is for the pixes, I haven't upgraded an asa yet...should be close or the same
* find latest version of code, these are usually *.bin files located on http://www.cisco.com/cgi-bin/tablebuild.pl/pix
* confirm the flash and RAM requirements of the PIX OS software versus what the PIX has (”sho ver”)
* make sure you have a backup of the old PIX OS and PDM to the tftp server (or at least confirm the software is there)
Note: You cannot back them up from the PIX, so you will need to download them and put them on the tftp server * put in a change control form
* once change controls confirms date/time do the upgrade:
wri mem*** only if you save your configs via tftp wri net conf t ca save all copy tftp://your tftp server ip/pix635.bin flash:imageskip this if you don't use pdm copy tftp://your tftp server ip/pdm-304.bin flash:pdm *** if this is a failover pair, upgrade the other pair reboot
Sep 06, 2007 | Cisco ASA 5500 Firewall
Erasing the flash....
Toast...looks like you killed your entire IOS installation...it will have to be reloaded to the flash...
Aug 21, 2007 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Cisco 2691 Series IOS Logo
440 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
