Question about Cuisinart Thermal DGB-600 Grinder
DGB 600 Grind & Brew
Our Coffepot doesn't finish the brewing cycle. We have to start it at least 3 times for all the water to completely brew through it. I've changed the filter, cleaned it with vinegar accorading to the owner's manual and it still does this. ANy suggestions?
  • 6 more comments
  • Anonymous Nov 03, 2007
    I'm having the same problem.
  • Anonymous Dec 07, 2007
    Brewing turns off before complete. We have to restart brewing to finish the cycle.
  • Anonymous Dec 12, 2007
    I am having the same problem. I will set the timer to brew in the morning, the brew will shut off and beep that it is complete and I will have to press the brew button at least two more times to get the complete pot. I have changed the filter and also run cleaner through the cyle and it did not help. I am getting really frustrated with this. Does anyone have a solution?
  • Anonymous Dec 24, 2007
    Same problem, mine seems to have gotten worse, it will brew about two cups before it turns off on me. I have accidentally dropped the coffee maker during a move, and walla it started working properly again for a brief time. I may toss it on the ground to see if that works again, unless of course someone has a more civilized fix.
  • Anonymous Jan 02, 2008
    Same problem here brews about half the water and beeps like its finished. sometimes restarting wont work either HELP!!!!!!!
  • Anonymous Jan 21, 2008
    I have to restart the machine at least 2 to 3 times each morning.... solutions please?
  • Anonymous Mar 26, 2008
    SAME EXACT PROBLEM. Brews partial and shuts off. We can
    turn it on again and it will finish. Sometimes takes a couple of
    time.
    Help!
  • Anonymous Sep 24, 2008
    Same prob--brews two cups at a time pretty consistently now. Gee, I only have to start the machine 5 times to get a full 10-cup pot! Tried vinegar, didn't help.
I just talked to the company--very helpful. The guy said they have the same machine in their office, and you just need to unplug it for an hour. It has an hour memory for the clock and programming. Anyway, the reason is, it's most likely stuck on the 1-4 cup brewing option, even though the light for that feature isn't on, it's still set to only brew so much at a time. I've got mine unplugged right now. If that doesn't work I'll be back!
Posted on Sep 24, 2008
I had the same problems, I just used straight vinegar a few times through and it worked out for me.
Posted on Jan 15, 2008
Had the same problem, I used coffee pot cleaning solution a couple times through and it woks fine. Had to do this a few times now. Cleaning solution is the type bought at local retail store.
Posted on Jan 13, 2008
SOURCE:
Doesn't always brew all the water, stops early
All coffee makers do this over time from calcium, lime, and mineral deposits building up inside the tubes and heating coil. Fill the reservoir with a 50/50 mixture of water and white vinegar and run a normal brew cycle, turning it off and on if necessary to completely empty the reservoir. Repeat this 2 or 3 times with fresh mixture of vinegar and water until it brews the reservoir empty without the need to cycle the power. Follow this procedure with plain water 2 or 3 times to clean the vinegar out. This should get it working like new again. It's best to use distilled water for brewing coffee as distilled water does not have the minerals that regular tap water has and therefore will not clog up the machine.
Mar 02, 2014 | Cuisinart Grind and Brew 10 Cup Coffee...
Why does my DGB-300 grind coffee but doesn't brew?
having no idea where it get water from does not help us figure it out , would suggest checking with the manufacturer's website for technical support .but 15 years is a good long life . some burn out in only 3 or 4 yrs
Sep 17, 2017 | Cuisinart DGB-300 Coffee Maker
We need to restart our grind and brew 5 or more times to complete a brew cycle/ get all of the water to go through. Is there a way to fix this?
That was happening to me as well. I just ran a mixture of 1/3 vinegar and 2/3 water through a cycle. Worked great. It's the first time in a year that it completely drained the water. Make sure you follow the vinegar+water cycle with another cycle of just water.
Apr 27, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
My Cuisinart 10 cup Grind & Brew does not finish the brew cycle. After brewing 2 cups of coffee, it beeps 5 times as if the brew cycle has ended. Then it continues to drip very very slowly. It's only...
you need to run a few pots of straight white vinegar through the machine to clean out the lime build up in the tubes. the first time you do it, after it starts to pump the water, shut it off for a few hours and let the vinegar sit in the tubes. after doing this run a few pots of cold water through before making coffee.
Nov 07, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Need instructions to operate DGB-600BC
Thanks for the reply. Got rid of the coffee maker. Its a dud. No more information required.
Jun 18, 2009 | Cuisinart Thermal DGB-600 Grinder
DGB-900 Grind and Brew grinder
One idea to try. I noticed with my grind & brew that the moisture never evaporated from the inside top of the machine. Since that cannot be good over a long term, I have started leaving the top open during the day after I clean the machine in the morning. Your problem is why I started doing that. Why don't you try leaving the top open for a couple of days and see if drying the machine out doesn't cause some of that gunk to dry out?
Feb 22, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
WARMING PLATE DGB 300
The Automatic Shutoff Time can be programmed
anywhere from immediate shutoff
after completion of the brew cycle up to four
hours. When the coffeemaker shuts itself off,
two tones will sound. Four hours is the default
time. The 0:00 setting shuts the unit off immediately
after brewing is complete. To check the
current setting, press the “On/Off” button and
the Automatic Shutoff Time will be displayed.
To change the preset time, press and hold the
“On/Off” button until the red “power” light
begins to flash. This signals that you have
entered the “Set Automatic Shutoff” mode.
Press the “Hours” and “Minutes” buttons
to scroll forward through the digits until
desired time appears. The first setting which
appears is preset at “4:00” and the next
display will be “0:00”, since four hours is the
maximum Automatic Shutoff setting. Pressing
and holding either button will allow you to
scroll continuously, slowly at first, and then to
accelerate to the rate of about three digits per
second. As the desired time setting approaches,
release the button and then press repeatedly
to advance one digit at a time.
The Automatic Shutoff Time (ASO) may be
programmed either before or during coffee
brewing. You may also re-program the ASO
time when brewing has been completed. If you
do so, the Automatic Grind & Brew™ will automatically
account for any time that has already
elapsed after brewing.
Feb 01, 2009 | Cuisinart Grind and Brew DGB-300BK 10-Cup...
I have a dgb600bc grind and brew. It will initially grind and brew the coffee hot, but as soon as the brewing is done the heating element shuts off causing the coffe to slowly get cold.
When the cycle is finished, the coffeemaker will beep 5 times, indicating that the coffee is ready. The unit will turn off automatically.
The insulated carafe keeps the coffee warm for four hours. The aroma of the coffee is preserved thanks to the hermatic cover. It is not necessary to remove the cover to pour coffee.
Hope this will help you.
/Mirran
Jul 24, 2008 | Cuisinart DGB-600 Coffee Maker
Cuisinart grind & brew coffeemaker DGB-500C
Could be electrical, but I would unplug for 20 minutes or longer and then clean with vinegar/water soltuion (2 cups vinegar, 2 cups water).
-Tha Mp3 Doctor
Jun 16, 2008 | Cuisinart DGB-500 Coffee Maker
Cuisinart Thermal DGB-600 Grinder Logo
239 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Pierre Laplante
Norman Worley
Ekse
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
