Question about Starbucks Coffee Makers & Espresso Machines
I have a 2002 model starbucks barista - not electronic. stainless steel. has Rapporto filter for groung coffee. adjustable steam wand- pump driven system- cup warmer- top fill water reservoir. Ive lost all paperwork for this machine. ?ant find a model number anywhere on the machine. all i have on original box is SKU# - 131714, original price was $399/US. can anyone help me with the model number or manual
  • 14 Answers
SOURCE: Starbucks Barista Espresso Maker
This is a general comment for people having problems with leaks and pressure in their espresso machines. If you do not used filtered water, the minerals and other materials suspended in the water will bond to the moving parts and tubes of your machine (e.g.: scale). The problem will be worse if you live in an area with particularly hard water. In some cases the pressure pipes can get completely blocked and if the pump is powerful enough, the pipes can rupture, otherwise, the pump will simply not put out any water. The solution is to regularly flush out the system with descaler. The frequency of cleaning depends upon how often you use the machine. You can get descaler from any decent coffe place (like Starbucks), an appliance repair place, or the hardware store. I use CLR which is sold at hardware stores. CLR stands for Calcium-Lime-Rust, and it effectively cleans all of these and is cheaper than specialty scale removers. Simply dilute some in water and pour the mixture in the machine, then cycle the pump and run it through. Collect the spent liquid and run it through again 4 or 5 times (or more if you've never cleaned your machine before...) Allow the liquid to sit for 10-15 minutes between flushes so that the solution has a chance to eat away at the scale. Once you have done this a few times, flush out the machine thoroughly with clean water 4 or 5 times, using CLEAN water each time you rinse. If you want to get an idea of the scale that has been removed, keep a small amount of the original clean solution in a glass and then compare the spend cleaning liquid with unused cleaning liquid to see the difference. The spent liquid should be foggy/muddy compared to the clean stuff and if you let it sit, the scale will settle to the bottom of the glass and will be clearly visible. You can prevent some of the buildup in your machine by using filtered water as they do at Starbucks.
Posted on Jun 05, 2009
  • 7 Answers
SOURCE: Starbuck's Barista steam wand leak
DPcurry is right. You may have to plug it in to get a "feel" for which way and to what degree to rotate the shaft, but works like a charm.
Posted on Jul 08, 2009
SOURCE: I need a replacement lid for the thermal carafe
In your manual there should be a number for parts ordering. I had the same problem. The part apparently costs $30 but because I live in Vancouver, Canada, the kind gentleman at Starbucks offered to send it to me free of charge as the duties at our border/customs would inflate the cost big time. I was very surprised that he was so willing to do this. Keep in mind though, I bought the machine and it was near $200. Very expensive for a drip coffee maker.
Hope this helps.
Posted on Jan 20, 2010
SOURCE: where to buy Starbucks(Bodum)Barista Utopia coffee maker filters
The coffee maker is made by Bodum. You can get the filters at their web site (www.bodumusa.com) 4.95 each. Bodum calles the Utopia coffee maker Santo and is the copany Starbucks sourced them from. Just click on spare parts and you willl be taken to a page that has the filter.
mike
Posted on Jan 21, 2010
SOURCE: looking for replacement parts
Starbucks no longer offers replacement parts nor any form of support for the Barista (Solo or Grande) coffee makers...eBay is your best bet!
Posted on Feb 12, 2010
What are the features of Breville BES870XL Barista Express Coffee maker for my home. Where can I buy it in good discounted rate?
FEATURES OF bes870xl_barista is as follows -
  • 15 Bar Italian Pump and 1600W Thermo coil heating system
  • Purge Function: Automatically adjusts water temperature after steam for optimal espresso extraction temperature
  • Stainless steel conical burr grinder with 1/2 lb. sealed bean hopper
  • 67 fl.oz (2L) removable water tank with handle
  • Newer model of the Breville BES860XL Barista Express
It has stainless steel color. And you can order it great discounted rate from where I purchased it after comparing all the other brands and prices also. Best Espresso Machine is one of the best site to compare and get best detailed knowledge of every brand....
Oct 07, 2016 | Breville Coffee Makers & Espresso Machines
Starbucks Saeco Italia Digital Barista Fully Automatic Coffee Machine will not prime!
Here is what is said in the manual:
"Direct the steam arm on the drip tray.
Open the steam/hot water knob until a
steady stream of water is dispensed. Close
the knob. Insert the filter holder into the
brew head to pre-heat the filter holder.
The machine is now ready to dispense
coffee."
Apr 26, 2017 | Starbucks Saeco Italia Digital Barista...
My Saeco Digital Italia stream/hot water wand quit working. When I press stean and turn the knob it pops out (not off) and nothing comes out. Hot water also want come out.
Push in on the knob when it pops out if that works then the steam valve assembly needs to be replaced, ask for the stainless steel valve replacement.
Mar 11, 2011 | Starbucks Saeco Italia Digital Barista...
I have a starbucks barista athena that has a vapor lock. How do I fix this?
It's easy to break the vaporlock on an Athena.
  1. Power the machine off and let it cool (20-30 minutes is plenty)
  2. Place a mug under the steam wand and open the steam valve all the way. If there's residual pressure, let it release the pressure before proceeding
  3. Power on the machine and wait for a steady stream of water from the steam wand.
  4. Close the steam valve and you should be good to go!
Jan 14, 2011 | Estro Barista Athena
Cannot prime pump.
I had the same problem, found the steam wand was plugged. You can screw the wand off (the crome metal tube) and then open the water valve. If you have flow take a wire and clean out the wand and your good to go.
Dec 08, 2010 | Starbucks Saeco Italia Digital Barista...
No water flowing through steam wand
You might want to try draining the machine and filling it back up. There could be a number of different things wrong with your machine.
Mar 21, 2009 | Starbucks Barista Utopia
Water leaking from steam wand when brewing shots
Try this from another post. It should help.
The steam wand began to seriously leak but a call to Starbucks Customer Service line and I was talked through how to adjust it so that the leaking stopped. It requires taking off the top/back panel of the machine (6 philips screws) then using a small allen key (1.5 mm I believe) to loosen and adjust a plastic oblong donut-shaped thing (a "cam" actually) on the shaft of the steam knob... no more drips.
The key to prevent dripping is to open the steam knob without putting pressure on it when it gets to the full-open stop position. Cranking it too hard when it comes to a stop in the full-open position will slowly move the cam out of position. Then the shaft doesn't fully seat inside the machine anymore and won't fully shut off the water to the steam wand. Then, no matter how hard you crank the knob in the shut-off position it will still drip. The purpose of the cam is to stop the knob from complete unscrewing and it also turns the pump on and off for the steam wand. The cam adjustment is very small but completely solves the dripping problem. Seeing inside the machine made me realize how easy it would be to repair problems as long as I can get the parts from Starbucks or perhaps Saeco.
Dec 21, 2008 | Starbucks Saeco Italia Digital Barista...
Barista Zia Espresso Machine
file:///Users/Julie/Downloads/Barista_Final_011305.pdf
I had the same problem. The Barista Zia is the same as the Barista Athena on the inside, the only diffrence between the two is the plastic shell on the Zia, and the steaming wand is on the opposite side. This is the instruction manuel for the barista athena, so its basically the same. Thanks! good luck!
Nov 10, 2008 | Starbucks Coffee Makers & Espresso...
Coffee Makers & Espresso Machines Logo
162 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
eyecam
ray gallant
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
