Question about LG WM-2277HW Front Load Washer
My lg intellowasher 7kg WD-8013F will not pump - not error message just won't pump
I will do a all the other stuff but when it comes to pumping it stops. On the pump function it just does nothing. And I really would like to get the water out soon
5 Suggested Answers
SOURCE: my lg intellowasher 7kg WD-1059 FB will not pump
Pump motor is probally shot, Mine is 4 years old I'm replacing mine again. Yes I've replaced it twice
Posted on Feb 23, 2009
SOURCE: HOW DO i REPLACE THE LARGER RUBBER SEAL ON A lg
I have this problem and have been told the following.
You have to take 2 Cir clips off. one on the front which is achievable by opening up the spring that holds it in place. The second one is behind the front panel.
You need to take the top off first. Undo two screws on the back top. Then you can take the top off. Then take any detergent tray our and also the front control panel. Then you gain access to some screws which hold the front panel onto the chassis.
After you take the front panel off you can apparently access the rear cir clip and spring.
once this is removed you can remove the front seal for replacement.
Posted on Sep 25, 2009
  • 4 Answers
SOURCE: my washing machine turns on but will not start. It will only make a click sound then another click sound. Please help
Your timer swicth is defective or fuse inside but check first the cord if it not broken before you go to fuse and timer
Posted on Jun 15, 2012
richroth
  • 9472 Answers
SOURCE: LG Intellowasher 7kg WD-14125RD shows DE error
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
Posted on Dec 07, 2012
LG intellowasher 7kg wd-8015c
SURE VINEGER IS VERY GOOD ON CLEANING WASHER
May 02, 2014 | Washing Machines
Dec 07, 2012 | LG WD-12126RD Front Load Washer / Dryer
My washing machine turns on but will not start. It will only make a click sound then another click sound. Please help
Jun 15, 2012 | LG Washing Machines
LG Intellowasher (Model WD-1023C)
The water pump can be blocked and thus stop the machine from finishing the wash cycle. In front on the bottom there is as hatch that can be opened with a flat screwdriver, the small black rubber pipe can be used to first drain all the water before the opening the filter. Small objects such as coins coluld be found in here, blocking the pump. Clean the pump by removing these, optionally blowing into the outlet (yuck!), to dislodge anything. If that does not help to fix the problem, you can clean that actual water pump, but this requires you to use a screwdriver to remove the pump.
Tilt the machine on its side, the pump is attached with 3 self-tapping screws. (if you can't figure out what the pump is you should probably let a technician do this). The pump has 2 parts to it, take it apart carefully and clean out all the dirt that has accumulated in there. Plastic friendly, waterproof grease can be applied to the pump spindle and bearing if available.
If the problem still persists a new pump is available from LG at a reasonable cost.
Jul 30, 2010 | LG Washing Machines
Lg intellowasher wd-8013f is very noisy
it will definitely be the bearings and possibly the spider as well. the spider is attached to the bowl. the spider is made of aluminum and they corrode all the time. open the door to the machine and grab hold of the steel bowl, has it got movement on it. if it has then the spider and bearings are faulty, also the main shaft seal will need replacing.nearly every time i went to an LG 8013f that was noisy it was the bearings and or spider. hope this helps. please reply 4 more help. good luck.
May 09, 2010 | Washing Machines
You suspect right.
It is a complete strip down job. I have just finished mine.
taking apart and reassembling is not too dificult.but you need to make up a tool to remove and replace the bearings which are two different sizes. It consists of a lenghth of studding, bolts and washers.
Download the manual from LG.
Good Luck
Mar 17, 2010 | Washing Machines
It doesn't let me choose a cycle - doesn't work
the control pannel faulty needs replace ment. press the cancel/pause button and clean button together to reset the board.check it if gets reset then it will work orther wise replace control board.
Mar 07, 2009 | LG Washing Machines
LG WM-2277HW Front Load Washer Logo
151 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
