Question about SI-TEX ColorMax 6 GPS Receiver
Hook up wire diagram to antenna
Connect wire to gps and antenna
Navman 1220a antenna wiring diagram
Hi, I needed this myself, found your post but no solution so after further... here you are. I tried it mated to a lowrance NMEA & it worked fine. Mine had a busted plug so the wires were already exposed with the pins handy to connect straight into a screw connecting block!
Nov 28, 2010 | GPS
I got a raytheon sl70 pathfinder gps that wont get a fixed signal the antenna is wired right but there dosent seen to be power comeing out of the cord that leads to the antenna. what should i do ????? i...
If you're using a raystar 125 antenna, you will have to power the red wire + and the shield wire - separately. Sl70's don't provide power over seatalk. Also make sure your green and brown wires are properly connected. If it's a 120 just power the red and sheild(black) and leave off the all except the yellow that's your data. If you still have nothing may probably have a problem in the antenna itself.
Jan 20, 2010 | Raymarine RL70CRC GPS Receiver
Nuvi 350 I got it from someone else, already used, it does not connect with the GPS or the antenna. Is the antenna in it or in another car?
the antenna is on the back of the unit. it needs to be flipped up in order for live gps tracking to work. when it is flipped down, it will only work in simulated mode.
Dec 07, 2009 | Garmin Nuvi 350 Car GPS Receiver
Cut antenna wire raymarine 300waas gps
That unit uses a TNC connector. Just have someone install a new one on the end of the cable. IT's a little more difficult than a F connector for a TV but not rocket science. You can also send it in to Mid-Shore Electronics. Just google them and get their number. They have alot of experience with the older stuff.
Oct 27, 2009 | Raymarine Raynav 300 GPS Receiver
Power to Lowrance GPS
Yes you have to hook up the red wires together to the + and both black ones to the negative, otherwise the antenna won't be supply in current , and don't forget to insert behind the red wire a fuse and a switch to avoid to discharge your battery .
Bernard.
Jan 25, 2009 | Lowrance LGC-2000 GPS Unit GPS Receiver
Plenio vxa-2000 antenna pinout
If you are looking at the external connection end with it in a "V" position, on the right - the upper one is green & the lower one is red. On the left - the upper one is yellow & the lower one is black (or the big bunch of copper wires). Be sure you are reconnecting an exact pin set up - an s-video is not the same (unfortunately). If you found a replacement antenna or a correct replacement part, please let me know where. I have to repair mine too.
Oct 27, 2008 | Digital Video Systems Plenio VXA-2000 GPS...
Which wires to connect when connecting a marine antenna to a raycraft gps
Hi. I have G series Raymarine and I listen the noise when swtich on I am not shure , may be from the ventilation (the fan).
I not find troubleshooting to G raymarine, I hope find the soulatoin thanks.
regard
kareem
Aug 03, 2008 | Raymarine RL70CRC GPS Receiver
I have purchased a Garmine 4008 on ebay only to discover the GPS unit wires were cut. Which wires do i need to connect back up.
There are quite a few variables involved depending on what antenna and accessories you have, and where the antenna is mounted. Your best bet would be to download the installation guide at this link:
4008 installation guide
Jul 22, 2008 | GPS
GPS antenna
If it is an RS 120 or an RS112 antenna you do not need to change it.These are both active antennas in other words they do all the gps computing in the unit itself. You need to look at the wire from the antenna. If it is a coax cable(2 wire) it will not work.If it is 3 or 4 wires it will work. If 3 wire (red ,silver yellow) just hook up color for color.If 4 wire you are going to have to figure out the wiring for it from the units wiring diagram.That could be a big enough pain that you might be inclined to change to the new antenna. If you wire the new RS125 antenna you must wire it to the seatalk buss. The seatalk wires are Red Silver and Yellow.The wire from the RS125 are red yellow silver green and brown.Wire as follow to your sea talk cable.Yellow to Yellow, red to red , silver to silver, green to red, brown to silver.
Hope this helps.
Jun 04, 2008 | Raymarine C80 GPS Receiver
GPS Module not responding
i just got it back from Lowrance and they replaced antenna and it works, but for how long is anybody's guess. The technician at Lowrance told me the antenna should be at least 3 feet from base unit and he thinks that is problem, because mine is only 2 feet. Why doesn't it say that in manual, if true and why doesn't MarineMax install it properly. MarineMax just gave up trying to help me, even though it was under their warranty. They just care about the sale and their installation was shoddy at best with wires hangiing all over the place. I decided to take care of it myself, so we will see.
Nov 11, 2007 | Lowrance LMS-332C GPS Receiver
SI-TEX ColorMax 6 GPS Receiver Logo
55 people viewed this question
Top SI-TEX GPS Experts
Will Halftowaite
Are you a SI-TEX GPS Expert? Answer questions, earn points and help others
