Question about Sony PSP (Piano Black)
Psp: power light is on.. but screen is black..
After its on for a few seconds . .kicks itself off again.. still no screen
  • meaninzyde Mar 14, 2009
    i am listening to the music on my psp then suddenly all of my music are corrupted, but when you turn it off its already ok but it will take me 6-8 times to turn it on and off because it is blank or no screen...
gilgamer01
  • 135 Answers
SOURCE: psp black screen
What happened to your PSP before this occured or have you done anything to it e.g. upgrading it to a newer firmware?it probably has gone bricked...
Posted on Aug 29, 2008
benwabnick
  • 2404 Answers
SOURCE: PSP Power light is green but screen is black
BIOS is corrupted on the mainboard inside of the PSP. Unplug the battery and also unplug the ac adapter.
After about 5 minutes plug up just the ac adapter and turn on the psp and see if you get video of any kind. If you can't get into any menus or any video to come up then your motherboard is corrupted and would need to be replaced. Hopefully if your psp is still convered under warranty you can get a replacement.
Posted on Jun 29, 2009
SOURCE: psp 2001 powering on with grean light but black screen.
you bricked your psp when you downloaded your custom firmware. google pandora and look for batterys i cant tell you where exactly because sony has a copyright.
they should have a pandora battery and magic memory stick order the kit they offer and follow the instructions it comes with. that should install your firmware correctly
Posted on Jun 30, 2009
reeccoo
  • 55 Answers
SOURCE: my psp is shut down cause low battery, it did'nt on again.
So you're having with power of your PSP?
Try this:
1. Try to plug your AC adapter to your PSP without the battery. If the PSP successfully turned on, it means you're having with battery issue.
2. If you're having with battery issue, keep in mind that you need to clean between the battery and the socket connector.
Hope this help! Any questions? Feel free to ask me =]
Posted on Jul 08, 2009
dehnn08
  • 13 Answers
SOURCE: my PSP shuts down by itself
go to a technician.....
they know what to do on ur problem..
Posted on Sep 06, 2009
Older-model Toshiba TV shuts off by itself
There is a large sand filled resistor on the main board close to where the power cord attaches that cracks. This will stop power until it cools enough to make the connection then heats up rapidly to open it again. It may be worth the trouble if you're handy with a soldering gun and can get the back off the TV. If not then I'd consider getting a flat screen.
Aug 21, 2014 | Televison & Video
My son dropped his psp at the barbershop he says the only thing it does know is play music.
  1. I would try removing the battery for a full minute and then reinsert the battery and light reset it.
  2. Should that not work I would try a different game and see how that responds, maybe the game itself might have suffered damage.
  3. If that reset does not work then a hard factory reset can be tried. This will erase all stats and everything and restore it to new out of the box status. Save any data on a USB drive before doing this if you want to keep it. The steps for this are -
  • Power off the game for at least 5 seconds.
  • Now hold down these buttons "select,start, the "square" button, and the "triangle" button all at the same time and then start the PSP up (while still holding them 4 buttons down.
  • At this time the screen will be black for a few seconds while it resets. This is normal, wait for the PSP to light up.
  • When the PSP lights up the hard reset has been performed.
If non of this helps the PSP come to normal then I recommend contacting Sony as it would be possible, at this point, that the PSP has suffered internal damage.
Regards, Tony
May 01, 2011 | Sony Video Game Consoles & Games
Psp power up green lights on black screen after a few seconds shuts down psp slim
it sounds like you bricked you psp, if it's not a 3000 or psp go you can probably fix it by buying a pandora battery and magic memory stick.  you can buy them from here http://pandorasales.com/?gclid=CNLk1fzUzqgCFcO8KgodAzI2lA , if you are running a psp 3000 and up, you could try to format your memory stick but it probably won't work.
Apr 25, 2011 | Sony PlayStation Portable (PSP) Console
My sony psp not work at all even screen also not display but battery charging ok
Just to be clear.
What happens when you turn the PSP on?
Green light come son for a few seconds then goes off?
Or no green light at all?
Oct 01, 2010 | Sony PSP (Piano Black)
Screen stays black green light comes on for a few seconds.
This sounds like you have "bricked" your psp... there are a few things that can cause this: first would be that you have bricked it trying to install Custom Firmware, another would be that the battery died or it was shut off during an update. You can buy what is called a Pandora Battery and a "magic" memory stick which will reset your PSPs firmware to the original 1.5, or if you still have warranty you can send it in to Sony to get fixed. Pandora batteries and Magic Memory Sticks are sold in a package for about $10-15 on the internet. Good Luck, hope you fix it.
Please Rate, thanks!
Jan 16, 2010 | Sony PlayStation Portable (PSP) Console
My PSP shuts down by itself
take it to the shop it came from it's faulty
Apr 03, 2009 | Sony PlayStation Portable (PSP) Slim...
Update fail.. and when turn on the screen is black
You need to call sony tech support, the psp cannot start because the update process was iinterupted.
Dec 12, 2008 | Sony PlayStation Portable (PSP) Slim...
Green light but nothing comes on
It seems that inside your PSP the LCD Screen Connection cable (The broad One) which is connected to the motherboard is being loose contact so if you can open the PSP try it by re-fixing the cable again otherwise you better go for a technician who will do the same job for you.
Sep 10, 2008 | Sony PlayStation Portable (PSP) Console
PSP comes on and plays fine then the screen goes black?
I am having the same problem.  The screen will intermittently come on as blurry.  Like all the text and graphics are doubled, but off by a few pixels.  Doing a sleep and turning it back on usually fixes it.  But I can not operate my PSP for more than like 10 seconds to a minute (varying) until the screen freezes and fades to black from right to left.  This usually occurs by pressing any of the buttons on the front panel.  If I am reading the news in the browser for instance and it is just sitting there, it is fine, then the second I hit a button, fades to black.  After it fades to black, sound and buttons continue to work.  I figured it was a bad LCD, so I purchased a brand new OEM LCD screen and installed it, however, the problem still persists with the new LCD screen, so it is not the screen itself.
Jul 21, 2008 | Sony PlayStation Portable (PSP) Console
Sony PSP (Piano Black) Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
