Firstly, make sure the actual time is correct. Set the oven (if it's a double oven the clock function will only work on the main oven) to the setting and temp required. The first timer setting you put in is the cooking duration (not the start time) ie if it's a casserole that you want on low for a couple of hours, adjust the first setting to 2:00, when you press for the next setting you will see the the timer has already added 2hrs to the current time, adjust this to the time you want the item to finish (eg, You want it ready for 6pm, adjust to 18:00). Don't press anything else, give it a second or two and the oven will switch off. The oven will switch on 2hrs (or whatever time you have set) before the end time. Whilst the oven is waiting to switch back on, on some models the cooling fan will run continually, this is normal. If you are a little slow enter the times the clock will time ut and return to the actual time. Hope this helps
Just restore the phone by using *#7780#.Or Restore it by selecting "Restore Only" from Setting.I think this will surely help you.Good luck Thanks for visiting fixya.
Depending on your OS the exact directory would be different but what you need to do is go into your personalization settings, find the setting for your screen (same place where screen resolution is) and then click the tab for an additional monitor. There will be either a tick box or a slider that allows for the function, either pc as primary or external screen as primary and the last function should be "mirrored". I believe that is what you're looking for.
Good morning, afternoon, evening or night; whatever time of day you you are viewing this solution posting. Thank you for choosing FixYa to assist you with your problem. Your problem is that your weather radio's 'Alert Type' setting is set on Tone and will not change to Voice. To change your 'Alert Type' setting...
1. Press Menu. 2. Press the down arrow button until you see 'ALT TYPE' displayed on your screen. 3. Press Select. 4. Press the down arrow directional button. You should see 'VOICE' on your screen. 5. Repeat step #3. 6. Repeat step #1 to exit.
You should now be able to receive voice alerts on your radio.Thank you for choosing FixYa as your one-stop solution spot for problems, questions, concerns and requests. Visit our website again in the future, and have a good morning, afternoon, evening or night; whatever time of day you are viewing this solution post.
Good morning, afternoon, evening or night; whatever time you're reading this. Your complaint is that the stations on your radio do not work and it just rings for no apparent reason? The possible cause of this could be your alert setting. Your alert setting may be set on TONE. When this setting is activated, a ringing sound will be played on your radio for 5 minutes or until any button other than the Weather/Snooze button, on your radio is pressed. If this is the cause to your problem, you need to change your alert type setting. Here are the steps to doing this task...
Press the MENU button.
Use the directional up button until "ALT TYPE" is showing on your screen.
Press SELECT
Using the directional up or down buttons, choose DISPLAY or VOICE.
When this is done, press SELECT.
Press the directional up button until "ALT TEST" is shown on the screen.
Test your alert type to find out if you'd prefer this setting.
If this setting is preferred,press SELECT and MENU to exit. If you prefer to choose another setting, press MENU, then the directional down button until "ALT TYPE" is showing on your screen. Repeat steps 3 through 8.
I hope this solves your problem. Reply back if it doesn't. Thank you for choosing FixYa as your one-stop solution spot for your problem. Make sure to read our Tips & How-to page for this product. Have a good morning, afternoon, evening or night; whatever time you're reading this solution.
It has a 12 volt lamp in it that illuminates the display screen. It is not a user serviceable part. You will need soldering skills and tools to replace it.
You are simply in blackout mode. This is so at night you aren't blinded by the glow of a screen. Here are instructions right from the manual to turn on or off.
Blackout Mode On and Off
When Blackout mode is turned on, the monitor display will turn off to
reduce power consumption.
This additional power enhances the sound quality.
1 Touch [VISUAL] on the main source screen.
The VISUAL selection screen is displayed.
2 Touch [OFF].
The backlit-display portion goes out.
3 Touch [OFF] again to cancel the display backlight.
• To make the setting, set to “Setting the VISUAL Touch Button” (page
34).
• If any button on the unit is pressed during Blackout mode, the
function will be displayed for 5 seconds to show the operation before
returning to Blackout mode.
• While the backlighting is turned off, the function indicator
