Question about Philips Go Gear 4 Gb Personal Mp3 Players
I drop my phillips go gear aria to the floor and i can't turn it on
  • Philips Master
  • 32,281 Answers
The player is faulty, I suggest you purchase another player as the cost of repairing the player may not be worth the cost.
Posted on Apr 21, 2013
Why is my HTC Aria freezing, or How can I fix this issue?
you can try by updating your phone
if the problem remains try factory settings(back up your data)
Mother board has to be replaced from an unauthorized service center.
Nov 17, 2017 | HTC Aria Cell Phone
Lg aria phone showing "LDP-7016D V1.4 SCOUT-DX V1.1 OK SYNC" same as below
Lg aria phone showing "LDP-7016D V1.4 SCOUT-DX V1.1 ...
www.faqqq.com/.../lg-aria-phone-showing-ldp-7016d-v1-4-scout-dx-v1...
Question Product: Phones Question Details: Lg aria phone showing "LDP-7016D V1.4SCOUT-DX V1.1 OK SYNC" same as below View Answers Search ...
LG Aria 130 & LDP-7016D Handset Issue - LG / Goldstar Systems ...
www.tek-tips.com/viewthread.cfm?qid=1694833
Oct 3, 2012 - I recently purchased 3 additional LDP-7016D handset for our phonesystem, but have ... System is a LG-Nortel Aria 130 running 7 handsets 1 x LDP-7024D Handset (V1.4) 6 x LDP-7016D Handsets (5 x V1.4 and 1 x V1.5)
Sep 16, 2013 | Lands Phones
1992 Dodge Stealth SOHC - no problems, running great, then I replaced the distributor (forgot to mark it) & now the car won't start up. It'll turn over, even got it to start once but won't...
put number 1 cylinder at top dead center and drop in distributor so the rotor points to number 1 on cap. may have to try several times as gear moves when lowering dist.
Sep 07, 2013 | Cars & Trucks
I drop my go gear aria to the floor and i can't switch on the device
I suggest you put your money towards a new player as the cost of repairing the player may not be worth it.
Apr 21, 2013 | Audio Players & Recorders
Lens will not extend when turned on message on screen lens error
This error indicate that focusing ring got stuck or jammed due sand, dust or may be due to external shock caused by dropping the device.
  • Try compressed air. With a fine tip blow off gun around lens barrel. It should remove all dust and sand. Turn the camera on this will solve the problem.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move once or twice then it will stuck again.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Thanks and have a nice day
Jul 04, 2011 | Fuji Cameras
Need new screen for htc aria i drop it and cracked the screen . .can it be fixed phone works fine
http://www.iphonerepair.com/htc-aria-glass-replacement/
You can get it repaired by sending it to them and they'll send it back fixed. It's pretty costly though.
Dec 22, 2010 | HTC Aria Cell Phone
I can't seem to shift in forth gear. Can't find it & the original shift stick has been replced. Is 4th gear all the up to the right or doow on the right? Please help
Hello there
you should look under the cover behind the seat on the floor.There are 4 phillips screws remove the cover and there is a shifter coupler.Look if it has a play (the plastic is worn out) or the little 3mm allen screw bolt is loose.If ok look at the shifter tower bushing.
let me know
proporsche@yahoo.com
Nov 01, 2010 | 1972 Porsche 911
Water damage to a phillips go gear aria
The best method would be to open it up and dry off as much moisture as you can. If you are not confident enough to open it up, you can try the "rice method". The "rice method" is when you take a water damaged electronics device and seal it in a container or bag with uncooked rice, the rice will absorb all of the water out of it. Let it sit for a day or two to get most of the moisture out. good luck
Sep 27, 2010 | Philips GOGEAR SA6045 MP3 Player
My Phillips GoGear 16GB won't come on.
I have a phillips go gear 8 MGB.numbers on inside of mp3 is 4901v3.68 and sstm12 080929 . I have tried reset & charging it but nothing will make it turn on. I spent alot of money on this thing for it to work a short period of time.What can I do???????????
Apr 14, 2010 | Philips GOGEAR SA6045 MP3 Player
Phillips Universal remote control fell to floor & will not work
unscrew it and check the broken part and try to put solder in that connection
Sep 11, 2009 | Televison & Video
Philips Go Gear 4 Gb Personal Mp3 Players Logo
81 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
