Question about Kyocera Mita Office Equipment & Supplies
Kyocera km-6030 light copy on both print and copy what is broblem?
Pls help me as soon as problem?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 167 Answers
This can be caused by a number of reasons.
Ensure that your paper is not damp.
Ensure that you do not have toner save/eco mode turned on.
The optics may be covered in dust.
The transfer belt unit may not be lifting/locked into place correctly. Are you using genuine toner? if not try using genuine toner. Will take hundreds of copies before the quality improves.
The list is extensive that may cause this problem.
Posted on Oct 25, 2013
sir fixalot
  • 146 Answers
SOURCE: Kyocera KM 3050 - error C3300
Error C3300 is a CCD Automatic Gain Control issue.
It could be poor contact in the connector terminals from the SHD PWB to the CCD PWB.
It is more likely a defective exposure lamp or inverter board that powers the lamp.
Try lifting up the Document feeder so you can see the optics frame through the platen glass and turning off and then on, the main power switch to see if the green exposure lamp illuminates.
A better, but more complicated way to check the lamp is to enter the service mode and run the exposure lamp test simulation. I will outline this procedure below. BE SURE NOT TO MESS WITH OTHER THINGS IN SERVICE MODE OR YOU COULD RENDER YOUR UNIT COMPLETELY UNUSABLE.
To Enter Service Mode:
Hit the "Status" button
Hit the following sequence on the numerical keypad:
1 0 8 7 1 0 8 7
You should be in service mode.
Use U601 by typing 6 0 1 and then "Start"
U601: Turning the exposure lamps on
Description: Turns the exposure lamp on.
Purpose: To check the exposure lamp.
Display:
CCD: Main Exposure Lamp
CID: Document Processor Exposure Lamp (inside the feeder)
Method
1. Press the start key.
2. Select the item.
3. Press the start key. The selected lamp lights.
4. To turn the exposure lamp off, press the stop key.
Completion
Press the stop key. The screen for selecting a maintenance item No. is displayed.
After checking the lamp(s) operation hit "reset" a few times to back out where you can type 0 0 1 "Start" to Exit Service Mode.
Posted on Jun 03, 2008
leroyal
  • 2120 Answers
SOURCE: Kyocera Mita km-1820
Unplug the power cord for 10 seconds.
Posted on Jan 15, 2009
SOURCE: kyocera km-2050 scanning function
The km 2050 was on network, but moved to home and directly into tower system via usb interface connector. Printer works, but can not get scanner to work? read instructions without a clue. can someone help with correct proceedure?
Posted on Mar 12, 2009
  • 46 Answers
SOURCE: Kyocera Mita KM-2530 Laser Printer will only print the first page not the rest.
Log into your pc as admin and under the driver properties change from kpdl to pcl5
Its a combo of a problem with adobe reader and the KPDL driver
Posted on Jun 11, 2009
n25an
  • 622 Answers
SOURCE: Kyocera-Mita going offline
it sounds like there is an ip conflict... you may need to reserve an ip address just for the copier or failing that change your copiers ip address to one below the ip range... if it still has problems then I would check the network cables.... and see if you get any error codes... copier can go offline if 1. the print card is loose... bad mounting socket on the main board... ip conflict... someone else has the ip address... poor network traffic... the signals over the network cables are degrading too fast... so the copier gets a corrupt file or unfinished file and bombs out... power surge... this causes firmware corruption and the thing just starts shooting wierd error codes... I think I have given you enough to think about...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Posted on Dec 07, 2009
Kyocera km-6030 printer
try turning off copier unplug from wall for a few secs or try to restart your computer
Dec 22, 2016 | Kyocera Km-6030 With Feed, Finisher, Bank,...
How to solve the km 6030 machine error code c7200
Hi Farid,
Error Code c7200 means : Broken internal thermistor wire • The thermistor output value is 4.5 V or more.
Because of : Poor contact in the connector terminals. Defective developing humidity sensor.Defective engine PWB.
Need to replace the defected part. please visit to the nearest service center.
Thanks
Aug 18, 2015 | Kyocera Km-6030 With Feed, Finisher, Bank,...
My kyocera km 6030 is showing an error C3300. Kindly tell me its solution
clean the opticals, the mirrors and the lamp. seems there is alot of dust on them.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
May 16, 2014 | Kyocera Km-6030 With Feed, Finisher, Bank,...
C3300 code
I am living in a Pakistan Village and have cyocera K-6030. I am facing an error on control pannel C3300, I would be most grateful, if I may be informed only that in which part of the machine this fault of C3300 is? it solution please. Thanks with regards. my e mail no is gmtyping@gmail.com and gmtyping@yahoo.com. If some one here can show me its solution, because my e mail is also not opening. thanks. my name is ghulam muuhammad
Mar 08, 2014 | Kyocera Km-6030 With Feed, Finisher, Bank,...
C3300 kyocera km 6030
Open the Glass and clean the opitcals. dirty mirrors and ccd. Run mode 906 after.
Kyocera error c7200
km 6030 machine have a code on screen c7200 so how i solve it
Dec 18, 2013 | Kyocera Km-6030 With Feed, Finisher, Bank,...
In KM-6030 C4110 appear
laser scanner unit and main PWB check for correct operation
Oct 27, 2013 | Kyocera Km-6030 With Feed, Finisher, Bank,...
214 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
