SOURCE: camera wont turn on...gives beep sounds and green light glows when pressing power button
Does the lens extend in either of these cases? If there has been some malfunction in the lens and it fails to extend the situation can cause the camera to power-off in order to protect itself. Some cameras show error messages before powering off, others do not. Hold the camera up to your ear and turn the power on. Is there a series of mechanical sounds before the beeps? Hearing sounds but not seeing the lens extend indicates some sort of failure in the lens assembly. If you hear nothing then the problem most likely lies elsewhere, possibly a failed electronic component or something as simple as a loose connection. Check with your manufacturer for any recalls or technical bulletins, and see if they will service your camera under warranty. If not there are a number of repair facilitys available on the internet who generally have better rates than out-of-warranty service at the factory. David Millier Advance Camera Repair
SOURCE: Fuhifilm finepix a700
Can you play back pictures and is the quality of these ok ? If you can but there is no image in capture mode then the CCD sensor is faulty and needs replacing.
SOURCE: Camera won't switch on
I thought the batteries had worn out because when I press the 'on' button the 'busy' light comes on for a few seconds and then goes out and nothing happens. Have changed batteries and checked installed correctly.
Any ideas please?
