A4 Tech 1080P Full-HD WebCam (PK-910H) having echo feedback after plugged in
PK-910H
ser71
  • 818 Answers
SOURCE: Webcam Speakers Echo and Double Feedback
"Noise", as used in this document, is a general term referring to any sound a speaker system makes that is not part of the original source material. There are many different types and sources of noise, each with its own solution. Below is an explanation of the common types of noise, what causes them, and how to minimize their occurrence.
Hum or Buzz
There are four common causes of humming and buzzing:
  1. Sound card If the humming or buzzing gets louder or softer with changes in the volume setting, this is an indication of noise coming from the sound card. In this case, check all of the connections to the sound card to make sure they are all completely plugged in and secure. Then, adjust the level setting of the sound mixer to obtain the best performance. Generally, you should leave your CD volume settings in the mixer at full and reduce the sound card's master output level down. For information on doing this, please refer to your sound card manufacturer's documentation.
  2. Unused input cables If you are not using all of the source inputs to your speaker system (such as using a 5.1 speaker system with a 4 channel sound card), the unused input cables will pick up noise. The solution is different for each speaker system, as described below:
    Z-540 / Z-560 (2 channel sound card): Depress the M3D button.
    Z-640 (4 channel sound card): Depress the Matrix button.
    Z-680 (2 or 4 channel sound card): Disconnect the unused input cables from the control pod
  3. High-power devices If you are using other high powered devices on the same electrical circuit, they may be causing hum or buzz. If so, discontinue their use while you are using your speaker system. Examples of such devices include microwave ovens, halogen lamps, power tools, etc. Also note that high-power devices with dimmer switches (such as halogen torchiere lamps) will cause an especially pronounced buzzing effect. To minimize hum or buzz, make sure that the dimmer switch on these products is either all the way on or off.
  4. Electric Polarity In many countries, the US being one, the electrical power grid is polarized. In these countries, the power plugs are designed so they can only be inserted into the wall socket in a single direction. For example, in the US one of the plug blades is larger than the other. To avoid humming and buzzing, both your computer and speaker system must be properly plugged into polarized outlets. If your wall outlets do not have polarized plugs, as in the case of many older homes, and you are using adapters to plug these power cords into the wall, it is possible that the polarity of either your computer or your speaker system is reversed. In many other countries, such as most of the European continent, wall sockets are not polarized at all - making it even more difficult to properly match the computer and speaker system. To solve the problem you will need to remove the power plug from the wall outlet, rotate the plug 180°, and re-insert it into the wall. Try this for your speaker system power cord, your computer power cord, or both. You should be able to find a combination that will eliminate the humming and buzzing.
Pops and Clicks
There are three main causes of pops and clicks:
  1. Sound Card Many pops and clicks are created by the sound card. There are two common causes: sound card quality and older or mismatched drivers. If the overall volume level of the pops and clicks goes up and down as you change the volume on the speaker system, the noise is being generated by your sound card. Lower quality sound cards don't include the necessary circuitry to cleanly remove noise from the sound output. Logitech's higher-powered systems, such as the Z-560 and Z-680, are also sensitive to the overall quality level of the sound card. If you are using an older or lower quality sound card, we suggest upgrading your sound card. The other primary cause is older or mismatched drivers. Make sure you are using the latest drivers for your sound card.
  2. Multi-tasking If you are running more than one program on your computer that accesses the sound system at the same time, small pops and clicks can be common. This is a function of your computer and/or sound card. A common example is using a program that generates occasional audio feedback (such as beeps or other sound effects) while listening to an MP3 track in the background. The solution is to turn off audio feedback in the first application so that the background MP3 track is uninterrupted.
  3. Interrupts in the Digital Bitstream On digital systems, such as the Z-680, it is normal to hear a very faint "tick" when you switch between inputs (by pressing the input button). You may also hear louder 'clicks' or 'pops' on a device such as a standalone DVD player or a sound card if it is plugged into one of the digital inputs. On some systems, this noise may occur when skipping tracks, switching audio streams (for example, from Dolby Digital to DTS), or navigating a DVD menu. The clicks and pops occur because the device is sending out an interrupted digital data stream. This behavior generally occurs with older software and older players, but is uncommon on most modern equipment. The Z-680 has been extensively tested with the latest sound cards, software DVD players, and standalone DVD and CD players. If you experience extensive popping and clicking, we suggest upgrading to the latest version of your software DVD player or, if using a stand alone device, trying a different speaker model. If you need more assistance with this issue, please contact Customer Support.
Stutter
A stuttering sound track is an indication of either insufficient or conflicting computer resources. Check to make sure that your computer has sufficient processor power and memory to handle the applications you are running, especially if you are using a software DVD player. Defragmenting your hard drive may also help. If you are sure you have sufficient resources, check to make sure that you don't have any conflicting IRQ or DMA channels.
We have also seen some software DVD player/sound card combinations that cannot properly output a Dolby Digital or DTS signal through the sound card's S/PDIF digital connector. (S/PDIF is a generic term for either coax or optical digital connections.) The result, when using a Z-680 hooked up to a S/PDIF connector, is a stuttering soundtrack. As mentioned, this stuttering is caused by the computer, not the Z-680 speakers. Switching the software DVD player's sound output to the 5.1 analog outputs will generally solve this problem.
Hiss
All high-powered amplification devices - everything from multimedia systems to home theater systems to movie theater sound systems -- generate some level of background noise, or hiss. In addition, low quality sound cards with poor signal-to-noise ratios can generate a significant amount of steady hiss that is reproduced on the speakers. Under normal conditions at a normal listening distance, the hiss coming from the sound system should not be noticeable. In a very quiet room, or if you place your ear very close to the speaker, you may hear a very low level hiss. This is normal, but should be completely masked by normal music and game sounds.
If you find that hiss is noticeable, it is likely that the speakers are too close to your listening position. If the speakers are too close, you will not obtain the best imaging of the sound and you risk damage to your hearing when the system is playing at full power levels. Try moving the speakers further away from your normal listening position. We recommend at least 18" for the moderately-powered systems (such as Z-340, Z-540, and Z-640) and at least 30" for higher-powered systems (such as the Z-560 and Z-680).
Also, note that the satellites in most Logitech speaker products are designed to be wall-mounted. Wall mounting the speakers provides two benefits: 1) it moves the of the satellites further away from your listening position, making any hiss less noticeable and 2) it moves all of the satellites further away from each other, providing better channel separation and surround sound spatialization.
Posted on Feb 29, 2008
  • 221 Answers
SOURCE: un install a4 tech pk-635m webcam
To install the driver for your cam all you have to do is go to the a4tech website, click on downloads, then select your cam model,
www.a4tech.com
Thank's for using fixya.
Posted on Apr 07, 2009
halbrook
  • 560 Answers
You may download your driver here, select your webcam model and click go. Read the install instruction on the download page.
Posted on Apr 09, 2009
SOURCE: install A4 tech PK635 M web cam without cd installer
how to install a A4 tech PK 635 M web cam without using cd installer?
i have no cd installer of a4 tech pk635 m webcam
Posted on May 20, 2009
mace1mace
  • 1138 Answers
SOURCE: i want installer of a4 tech pk 835 webcam
click this file and download... PK-835 webcam driver
Posted on Jun 20, 2010
How to rotate my video
you have to install the software for video rotation i am giving you the link for best result and best software... and pls vote me
Jun 14, 2015 | A4tech A4 Full HD 1080p Webcam with...
I need a driver and software for my hd 1080p
1st You download Webcam Driver.
software for my Camera After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Other Companies Camera Drivers for Windows XP Vista Windows 7
Feb 21, 2014 | A4tech A4 Full HD 1080p Webcam with...
A4 tech webcam + microphone issue
A4 tech webcam After this install the Webcam driver in the system.
Jan 20, 2014 | A4tech 1080p Full HD Wide Angle Lens USB...
Pc camra driver pk 800 free dounlode
try this: http://www.webcam-driver.com/a4-tech/a4-tech-pk-800mj-webcam-drivers.html
Dec 29, 2010 | A4tech Xmaster PK-835 Webcam
A4 tech without installer.
You have not mentioned the Operating system
Download the drivers from this below link ( the attachment is in RAR file )
http://www.webcam-driver.com/a4-tech/a4-tech-pk-635-webcam-drivers.html
* Please rate this answer with thumbs up comment if answered correctly
Sep 28, 2010 | A4tech PK-635 Webcam
Lost my A4 Tech web cam installer cd
Hi Friend,
You can download the free driver for your webcam from the below links
http://rs263.rapidshare.com/files/73706033/a4tech-pk-635-driver.rar
just copy and paste in the web browser.Since u didn't mention the model name of A4 Tech,the above link will show u all the webcam drivers of A4 Tech model.
Kindly download which is suitable for u and kindly check it out.
Revert back
Regards,
Ayyasam
May 29, 2009 | A4tech PK-635 Webcam
Install A4 tech PK635 M web cam without cd installer
May 20, 2009 | A4tech PK-635 Webcam
Webcam
please send me installer of a4 tech model: pk-635m webcam
Jul 10, 2008 | A4tech PK5
use the A4 support website
http://www.a4tech.com/ennew/support.asp
Jul 02, 2008 | A4tech G-Cube Cosmo-tini notebook webcam
Just plug the webcam in and windows will automatically install the drivers, if it asks for the drivers just insert the disc, when you do this windows will auto play the CD so just shut down the auto install program and leave the disc in the drive and carry on with the driver installation manually.
Here is the driver download as well: http://www.a4tech.com/ennew/download%20driver.asp
Cheers
May 18, 2008 | A4tech Xmaster PK-835 Webcam
Computers & Internet Logo
296 people viewed this question
David Payne
David Payne
