Question about Kenmore Washing Machines
CA on display
Washer is display says CA,
  • 15,935 Answers
The CA indicates that an average current limit on the drive motor has been exceeded (see images below). This is an extremely hard problem to diagnose and one that I've seen cause the best service techs to pull their hair out. It can be one of so many different components, and you have to catch conditions just right to have half a chance to discover which one it is.
Try removing some of the clothes; this could be caused by overloading. You could have a mechanical failure in the universal joint, wiring harness, the drive motor, central control, or the motor controller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
I ran a self diagnostic test on my Whirlpool calypso washer and got CA error code. Do I need to replace the drive motor?
If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or Cl for instantaneous current limit trip.
Before replace, I would first check the power supply, wiring and electronic.
Dado
Dec 24, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
Why is my Maytag washer showing lr code again?
If you live in North Hollywood, CA and need washer repair service call us at (626) 460-0903 or visit our website Washer Repair North Hollywood CA 747 248 4544 Samsung
Sep 03, 2017 | Washing Machines
IT WILL DRAIN THE WATER BUT WONT SPIN AND CODE SD WILL COME ON
The Sd (5d) error code is displayed on this washer when the machine control board detects a suds-lock condition by analyzing the drag on the washer basket. It will be displayed while the control runs a mini-clean out cycle. If this clean out cycle is unable to remove the excessive suds and correct the condition, then the cycle will end and Sd will flash in the display.
Make sure that you are using HE (High Efficiency) detergent in the appropriate quantity in your washer. If you detect excessive suds in the washer, this likely caused your problem.
Another cause could be a toy or other item under the washer that would cause friction on the drive mechanism. If you do not see excessive suds, check for this type of problem under the washer.
Washer repair in Corona Del Mar, CA
Appliance repair in Corona Del Mar and Orange County, CA
Jan 26, 2011 | Kenmore Oasis HE 27082 Top Load Washer
What is F21 . (Fault)
Most likely bad water level switch.
Also,
EXPLANATION AND RECOMMENDED PROCEDURE
F21 LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:After 4 minutes the "Sd" error will be displayed, then
4 minutes later the "F/21" error code will be displayed. Press
PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Jan 26, 2011 | Kenmore Washing Machines
What is F21. Its keep showing.
Also,
F21 LONG DRAIN
kinked.
Jan 26, 2011 | Kenmore HE2 Plus Front Load Washer
Washer has stopped and is flashing "CA" on the monitor
Hello there:
the ca or even a ci can mean the following
CA
Cl Average current limit Or
Instantaneous current limit If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or Cl for instantaneous current limit trip.
Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings.
Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings.
This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
Press STOP/CANCEL to clear the display
unplug the machine for 1 hour and then plug back in and see if the error is now cleared
Dec 26, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
Press STOP/CANCEL to clear the display.
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
Sep 15, 2009 | Washing Machines
CA flashes on the display
Aug 05, 2009 | Kenmore Elite 45986 Front Load Washer
CA error code on Calypso Washer
CA Cl Average current limit Or Instantaneous current limit If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or Cl for instantaneous current limit trip. Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings. Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
Meaning you had stuffed it full one time and then it was hard on the motor, you will have to change the drive motor most likely...
May 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Sears Calypso Washer purchased in 2004, displays the CA error code. Unplugged the washer for a couple hours and replugged in. Ran a cycle without anything in. Worked fine. Placed a load in and it ran for...
CA - Average Current peak - happens if there is a 2 second average of current draw greater than 5.55 amps at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. Overloading the unit may cause this problem. Try washing smaller loads and see if the problem goes away. If it recurs when you wash bigger loads, decrease the size AND watch to see if you have to continue to decrease the size to keep the error from happening. If that were occurring, it could well be a sign of the electrical problems noted, requiring service.
Washing Machines Logo
19 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
