Question about Porter Cable 362 12 Amp 4 Inch By 24 Inch Belt Sander With Cloth Dust Bag
Smells like wires buning
About 4 years old, worked fine until I started to belt sand something, and all of a sudden a strong smell of electrical wires burning was present. I've had tools last 20 plus years, hard to believe a good name like this would go out so soon. would assume the motor is burning up. any recourse?
  • David Ford
    David Ford May 11, 2010
    What is brand and model. It could be a broken wire in the cord or a burnt switch or worse case the windings in the motor are going bad, however the bearings could be also locking up causing it to slow down and heating up. I will look at a print when you get back to me and see what I can do for you
  • 205 Answers
Motor may just need new brushes, Cooling vents may be clogged with dust. or bearings in the motor or front roller maybe bad. Causing excessive drag
blow it all out with compressed air or shopvac
look for external brush caps (2) oppsite from each other take them out to be sure they slide freely, sometimes one gets hug up and doesn't make good contact
Posted on Mar 22, 2009
Sudden strong smell of smoke in cab of car
as you did not bother with a make , model year data we cannot help
it could be an alternator fault , shorted wires or starter motor stuck in the ring gear
get an accredited auto electrician to check for the fault
Apr 25, 2017 | 1997 Oldsmobile Cutlass Supreme
My 5 year old Whirlpool dryer just didn't start one day.Instead of dealing with repair,we got a used 4 year old Maytag dryer.It dried the first load,then when I pushed the start button it made a weird...
It is the motor winding shorted out which caused the smell. If you still have your old dryer the safty thermal located on the exhaust housing is blown. White plastic with 2 wires going to it. Very inexpensive repair. Hope this helps.
Feb 13, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Buning smell whenever I use my vacuum
If it's a rubbery burning smell, check the belt for the beater, it could be rubbing on the sides or even broken.
Jun 22, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
My whirlpool electric dryer smells hot.
generally if the uint shuts off from overheating and then will not restart for a 10-20 min period of time usually a sign htat hte motor is overheating and needs repalcing
Mar 31, 2009 | Whirlpool LER5636P Electric Dryer
GE microwv-doesn't heat, strong electrical smell, all else ok
The most common problem would be your magnetron. Check your purchase date, magnetron's usually have a five year warranty. Not a part I recomend trying to fix yourself (high voltage ).
Mar 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Washer has burning smell and does not spin.
It sounds like your belt has burnt off. take the front off the washer or tip the washer back to check it. easy fix.
Nov 17, 2008 | Washing Machines
Sebo x1.1 - burning smell
Try replacing the belt. My vacuum cleaner had the same problem and once the belt was changed the burning smell was gone.
Jun 10, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Smelly fridge`
Can you describe the smell or relate it to something common? Plastic, burned wires, fishy, rotted meat, etc. Is it only when you open the door or can you smell it outside too? Are the temps normal in the freezer and refer sections? When did the smell suddenly get noticed?
Nov 12, 2006 | Samsung RS2630SH Side by Side Refrigerator
Porter Cable 362 12 Amp 4 Inch By 24 Inch Belt Sander With Cloth Dust Bag Logo
210 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
