Tower fan runs fast without stopping
The Tower fan runs constantly on a fast mode and I can hear it more and more
    Genius:
  • 1,066 Answers
Either your computer is running too hot (clean it out physically, or clean out viruses) OR the fan is failing, and it sounds louder and faster cause the bad fan bearings are making that noise.
Posted on Mar 12, 2009
Freezer is warming- up to 24 degrees now. something is running- should i unplug the freezer to keep the defrost fan from coming on until repairs can be made?
the fan is not a defrost fan? it helps to circulate the cold air into fridge and freezer. so when the fridge goes into defrost mode the fan and compressor stop running. if ur getting constant warm or heat? I suspect ur defrost timer is not coming out of defrost cycle? the heat is only suppose to last up to 20-30 minutes then back into cold mode? hers a trick u can use that may get u back into cold mode, locate the defrost timer in ur fridge usually at top center. then under the timer u will see a tiny slot or hole. if u stick a small screw driver into that hole and turn slowly clockwise till u hear it click? if its stuck in defrost , it will now come out of defrost and u should hear the fan and the compressor come on, hope this helps let me knoiw if u have any more questions
Mar 16, 2015 | Refrigerators
Why fan operates in sleep mode Dell OptiPlex 780?
Possibly it is overheating, which would depend on how often it runs, and how fast. During startup, it is normal for a fan to run at high speed, but if it's on constantly in sleep mode, I would look towards an overheating problem. Open it up, check for, and clean any dust around the heatsink / fan, and power supply fan. Also make sure that outside the PC there is plenty of space to allow airflow.
May 15, 2014 | Dell OptiPlex Computers & Internet
LG model TS-K2430hl .Outside fan stops after a few min.
Should like your unit is working fine unless this is constantly happening. If this is a constant thing then condenser coil if dirty,check thermostat setting
Dec 16, 2017 | LG Heating & Cooling
My outside fan will not run and the inside unit runs constantly. can't push the reset button on unit outside
Your out door unit fan motor not runs due to pressure not build up at Heat mode. If its cool mode only fan runs with compressor when thermostat calls for it.
Without having technical knowledge, don't press any reset button. Hope it's helpful?
Dec 09, 2010 | Ruud Central System Air Conditioner
All the leds turn on, incluiding the tower fan oscillate, But the essential doesn't work "it doesn't ventilate". What do you suggest?
check the fan if it is working.. if not ,can you hear any humming sound coming from the motor? if there is you need to remove the cover, then remove the circular fan,try to turn on the unit without a fan if the motor is running then just clean the rust in the bushing and shaft of fan by using sand paper. then put lubricant in the shaft and bushing(oil or wd40 or grease). make sure that you remember all the parts and the position of it.. good luck
Sep 13, 2010 | Windchaser WCUFLTI Tower Fan
Fans on Mac Intel Tower
I would suspect it needs a good internal cleaning. The accumulated dust will cause the computer to overheat. Disconnect all cables and take the unit to a place where you can clean it. Remove the side panel and then with a can of compressed air or an air compressor blow all dust out of the unit. Pay special attention to the heat sink on the processor. Make sure you clean the power supply fan. Be sure and not touch any internal components without first grounding yourself to the chassis. It is best to do this outside as the dust will fly everywhere. You should clean the inside at least once a year. Merry Christmas.
Dec 15, 2009 | Intel Mac Pro Tower Desktop
Heat runs constantly. Feels cool unless emergency
make sure out door unit is running not just the fan out side should hear compressor and in heating mode the large copper line should be hot fan should be in auto position on stat hope this helps
Dec 06, 2009 | Heating & Cooling
My pc tower is going mad like a fan on fast speed
you have a virus...run your anti virus appliciation. if you don't have one, get one. AVG is free, google it
Apr 21, 2009 | eMachines T3998 Cel 2.93GHz, 256MB, 100GB,...
Compaq Presario fan problems
the fans on a computer tower run all the time to help keep the pc cool. this is normal in a tower pc of any brand
Dec 04, 2008 | Compaq Presario Fan
Computers & Internet Logo
854 people viewed this question
David Payne
David Payne
