Question about Garden
Intructions to change cork drive pads on greenfield ride on mower
4 Suggested Answers
SOURCE: i am trying to remove the cutter drive pulley from
Hello Mate, I know its been awhile since you posted but the deck pulley has a left hand thread. hope this helps.
Posted on Aug 30, 2010
vincob
  • 718 Answers
SOURCE: I need a diagrahm of a belt drive greenfield ride
Go to this website, upper right hand corner and do a parts look up. Search for your model and that good stuff they ask of you and then choose mower housing should be there, browse the site it's really cool and has a lot of info.
http://www.jackssmallengines.com
I did a sample search for generic riding mower deck and found great diagram of belt routing. Give it a try you will find same results Good Luck! Don't forget the thumbs!
Posted on Nov 10, 2010
SOURCE: Have a Greenfield Evolution 2000
The Greenfield clutch (drive belt) is adjusted by spring pressure pulling a long rod that has serations on it. Either the belt has run out of adjustment (= new belt needed) or the adjuster has stuck. Lift up the seat and push the adjusting rod that has a big spring attached to see if you can move it towards the front. Look at the pulley beside the rod, if the belt has stretched too far, the pulley will be hard up against its slot. The pulley moves towards the front to tighten the belt. I just push with my leg to get another "click" out of the adjusting rod. New belts are cheap too.
Posted on May 03, 2011
Do the drive chains on Greenfield Ride on's have a removable link?
If not. Grind rivet head off on a link. Replace with a removal one.
Dec 20, 2014 | Garden
GREENFIELD 8, 11 & 12 HP ANNIVSARY manual
Some manufacturers will not sell the full manual to consumers, perhaps yours will.
Your best bet is to email them with the full model and serial number of your mower with your request:
http://www.greenfield.com.au/contact.html
Jun 07, 2014 | Garden
Greenfield mower chain tension
take chain off -- lay on floor --pull taught end to end push together --if it flexes more that one quarter of a inch --chain is worn --replace chain--also see how deep chain sits on sproket--- if sits too deep sprokets are wore and need replacing
Dec 27, 2013 | Garden
I need a diagrahm of a belt drive greenfield ride on mower
Nov 10, 2010 | Garden
Have a Greenfield Evolution 2000 mower , the forward drive clutch is slipping badly on hills is ok on the flat, what is required to fix this problem. Can the clutch pads be replaced or are complete clutch...
Oct 31, 2010 | Garden
I am trying to remove the cutter drive pulley from my greenfield ride on mower (will not move) tried puller with heat any ideas.
May 11, 2010 | Garden
We mow 2 acres with a Greenfield ride-on. Sometimes have to cut long grass by slipping the clutch to get slow forward speed. Problem is that the clutch system occasionally locks into forward or (worse...
Hi i have seen this with most greenfield models The only way to fix this problem is to replace the drive clutch assy as it ends up to costly to replace the worn parts : shaft,clutch plates & drive pulleys.
In most cases replacing these parts has led to a new assy six months later.
Mark.
Jul 18, 2009 | Garden
Garden Logo
264 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
