Question about Craftsman Garden
How do you adjust the gap on magnita coil on pony briggs and stratton riding lawn mower
Can not get a spark to the spark plug on model 210000
  • 7 Answers
SOURCE: is there an oil filter on a Briggs/Stratton riding lawn mower. Model#42A700
Yes there is a spin on oil filter. Depending on the date code when the motor was built there are two possibilities. The easiest way is to measure the length of the filter, If the filter is 2 1/4" long the Part Number is 492932.
If the filter is 3 1/4" long, the Part Number is 491056.
Posted on May 25, 2009
  • 8 Answers
SOURCE: briggs a stratton 35 lawn mower
Turn the mixture screw on the carburator slowly counter clock wise till the idel stabalizes.
Posted on Jul 01, 2009
  • 130 Answers
SOURCE: briggs & stratton 190707 wiring diagram
make sure your coil has not move ajust to 010. gap check magent on flywheel.see if strong.if all is ok yes coil is bad
Posted on Jul 22, 2009
rwvanlue
  • 486 Answers
SOURCE: Craftsman lawn mower. Briggs & Stratton 6.75
1) check plug for being carbon fouled or fuel fouled. Even though it fires, it may not be firing correctly
2) make sure you have compression 75-100 psi. since the compression release so you can pull the rope works off of the exhaust valve, you may not get anymore than that.
3) Is there water or debris in the float bowl
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your local lawn & garden dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
Posted on Nov 26, 2009
micromatikal
  • 2777 Answers
SOURCE: i need an owners manual for a brute riding lawn
This was very difficult to find, but I found it just for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. To view the manual you will need adobe reader, which you can get for free from http://get.adobe.com/reader/ You probably already have it though, please try opening the file first and find out. Here is the manual / guide please give it a few minutes the file is quite large:
http://www.doitbestparts.com/MANUALS/BRUTE/7800583.PDF
Posted on Oct 12, 2010
Yard Machines 21hp briggs & stratton, 46" cut riding mower. What is the spark plug gap?
Most gaps on the plugs are approximately ..020 to 030 for all Briggs motors.
Most plugs are pre-gapped when you purchase them.
Use this link to be sure:
http://www.briggsandstratton.com/us/en/support/faqs/identifying-the-correct-spark-plug-and-gap#SparkPlugChart
Jun 26, 2015 | Garden
Why won't engine start after doing all these repairs
Make sure it is the correct spark plug with the correct gap. Then check to ensure that fuel is being delivered and is not bad
Jul 30, 2014 | Briggs & Stratton Briggs Stratton...
What is the gap on a spark plug on a 18.5hp b/s engine rideing lawn mower
There are so many engines manufactured by Briggs and Stratton there is not enough information to answer your question directly. Suggest you check : www.briggsandstratton.com/...the-correct-spark-plug-and-gap this site with additional information about your engine should get you your answer.
Jul 28, 2014 | Cub Cadet Street Sign- tractor lawn riding...
Briggs and stratton spark plug
If it's a lawn mower or such, the plugs are pretty much the same, available at most hardware stores. Take the old one if possible to match sizes.
Nov 29, 2013 | Champion International Champion& Small...
What spark plug for a 19.5 hp briggs & stratton
what is the settings for the spark plug gaps in a Briggs and Stratton 19.5 engine 46 in riding lawnmower
Jul 26, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
No fire mtd 21inch 3.5hp
You should have a strong, blue sparlk. Make sure plug is grounded to engine when you test. Don't do it in the air. Check the flywheel/coil air gap. I think on Briggs it should be about the thickness of a standard business card. If after setting the air gap and there is no spark...plug is bad or ingition coil module is defective. When you adjust the gap, make sure the magnets in the flywheel are lined up with the "legs" on the coil to assure the correct setting.
Aug 11, 2010 | Briggs & Stratton Garden
Briggs & stratton 190707 wiring diagram
Jul 21, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Cleaned the Briggs & Stratton Riding Lawn Mower's head and valves. Put it back together and it refuses to start, get good starting try, no joy. Checked the spark, great! Checked the gas- great!...
did you usae a new head gasket and clean the old gasket off? does the plug get gas? you must have spark, fuel, compression and timing in order for it to run. also did you gap the coil to flywheel spacing?
Jul 08, 2009 | Parks Optical 13.5hp Briggs And Stratton...
Garden Logo
19 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
