Question about Robertshaw 780-010 Universal Ignition Control for Bradford White Water Heater
Robertshaw universal ignition valve - Robertshaw 780-010 Universal Ignition Control for Bradford White Water Heater
  • Robertshaw Master
  • 16,210 Answers
Define the problem.
Posted on May 05, 2013
How change robertshaw 110-32f
Turn off gas to the heater close water supply drain the water out of heater.Remove pilot tube assembly remove thermocouple/or thermopile assembly disconnect gas at the union and remove from valve. Use wrench that fits the hex shaped nut that holds the aquastat and water heater in the tapping. Usually the wrench size is 3/4" or 7/8" depending on the unit.
Put pipe dope on the male thread of the valve and keep it off the aquastat bulb, and rethread into the tapping.
Replace the ilot assembly being sure it was not damaged when it was remover if it was damaged replace it. replace the thermocouple/powerpile assembly replace the gas piping from the valve being sure to use pipe dope on the fittings and tighten them enough so they do not leak. Do not use teflon tape because it could get into the gas valve and cause problems.Test the gas piping for leaking do a tight test on the meter if possible or test with testing fluid and look for bubbles or use a gas leak detector that sniffs for gas and beeps when it detects a leak
Fill the water heater up with cold water and check to be sure there are no leaks at the thread where the valve is threaded into the tapping. Open a hot water faucet and be sure the heater is full of water.
Light the pilot and turn the gas on set to the temp that is best suited to you..
Apr 06, 2014 | Robertshaw 110-32F/110-326 Natural Gas...
Keep replacing control
Check to see if anything on the low voltage circuit is stealing voltage ie gas valve...make sure you have the proper low voltage to the ignition module (check the transformer)
Nov 22, 2013 | Honeywell S8610U3009 Universal...
How to replace a robertshaw gas control valve
Robert Shaw water heater gas control valve?
Copy following link for replacement of each type of gas control and related troubleshoot.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Mar 28, 2013 | Rheem Waterheater Natural Gas Valve
Pilot doesn't stay lit
1) Copy following link to troubleshoot by type of gas control valve:
2) Replace gas control valve.
Mar 02, 2013 | Rheem Water Heaters
Heater has low voltage and will not run
check high limits and incoming voltage maybe low battery voltage or bad converter
Nov 28, 2012 | Atwood Mobile Products Atwood G6A-8E...
The indicator light stays on our PVS50 water heater.
You have the Robershaw wiper gas control valve.
Here are error codes and troubleshoot table for that gas control.
http://waterheatertimer.org/pdf/Robert-shaw-gas-control-error-codes-1610.pdf
Here is general service manual for power vent water heaters.
http://waterheatertimer.org/pdf/Power-vent-water-heater-service-manual.pdf
Here is general parts list for that water heater, 2009:
http://waterheatertimer.org/pdf/Rheem-power-vent-RS-parts.pdf
Aug 20, 2012 | Rheem 50 Gallon FVR NATGAS Water Heater...
WIIL NOT FIRE I REMOVED BURNER AND CLEANED IT AND SENCER IT FIRED. tHE NEXT DAY I HAVE THE SAME PROBLEM. i DID SEE A GREEN LIGHT FLASHING ON THE rOBERTSHAW CONTROLER. WILL THIS HELP TO TROUBLE SHOOT MY...
When you removed the burner and replaced it did you bump the thermocoupler? If that isn't in the pilot light flame or ignitor heat, it will not allow your gas valve to open and send gas to your burners.
If it isn't misaligned then it could be bad or just corroded/caked and need cleaned.
Jul 18, 2011 | Water Heaters
How do you remove a tmp valve out of a propane gas water heater and are they universal or do I have to go to a Bradford White dealer? Thanks
yes you can get a universal one at any hardware store[about 15$]. shut off cold valve at top of tank and drain tank through drain at bottom of tank.you only need to drain enough to get the water level below the t&p valve. you should use dope and teflon on the new threads of the valve to ensure no leaks. a big cresent wrench or pipe wrench will work to unscrew the valve in a counterclockwise direction
Oct 23, 2010 | Fasco Bradford White Hot Water Heater...
I have a raypak heater with robertshaw 7000 gas
Remove the wires from the gas valve and call for it to light. While it is trying to light, take a voltage reading on the wires that go to the valve. If it is sending voltage to the valve and it won't energize the valve then the valve is defective. Just make sure that the valve is being told to come on. It could just be a limit switch. Double check the manual reset limits also before doing the vavle check. Hope this helps.
Mar 21, 2009 | Water Heaters
Robertshaw 780-010 Universal Ignition Control for Bradford White Water Heater Logo
136 people viewed this question
Top Robertshaw Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Robertshaw Water Heater Expert? Answer questions, earn points and help others
