Question about Recoton Advent Advent Q2035A 20" TV
TV picture goes out after like 5 minutes of being on
I just got an Advent 32'' model Q3235A tv from the neighbors, the screen is flat but its a regular big box tv, not a flat panel. Anyways, when i first turn it on the picture is fine, then about 5 minutes into it being on, the screen turns black with squiggly colors of green, pink, etc. My roommate thinks its because it overheats, and my boyfriend thinks its either because theres a lot of dust inside or because the fact that the speakers are too close to the parts and since speakers have magnets its interfering with the display. I think both of them are wrong, can you help me? Is it a part that needs to be replaced, or is it really damaged, or what?
  • manis2societ Mar 12, 2009
    Thank you for your response, however, I forgot to mention that the speakers are the ones inside the tv! I looked up degaussing, and thermistor, it was helpful, but now my boyfriend wants to take the tv apart and repair it himself!
  • Anonymous Mar 30, 2009
    need a code for an advent 27 q2735a dose anyone know the code
    President:
  • 2,992 Answers
Your problem is not due to magnetism. If the set needed degaussing, the picture would otherwise be normal except for spots on the screen where the colors were wrong. The screen wouldn't go black with colored squiggles. You have a thermal problem with some part of the circuitry that begins acting flaky after the set warms up.
The usual technique for troubleshooting a thermal problem is to get a spray can of cooler, and chill down suspect components until the problem clears up. Without knowing all the details (and not having worked on many Advent TV's) I can't suggest any specific parts. But a common trouble is an integrated circuit often called the "jungle" IC which does most of the video processing. If the trouble occurs on TV channels but not when you are using a video input with a DVD player or other source, this could also be a symptom of bad solder connections in the tuner.
Unfortunately, this problem is not something you'll be able to fix just by opening the set and cleaning or moving speakers. Your best bet if you want to keep the set would be to have a TV technician check it and give an estimate for the repair.
Posted on Mar 12, 2009
    Problem Solver:
  • 18 Answers
Get speakers away from screen, Yes magnetism causes this problem. You must use shielded speakers if they are close to a TV.
Issue with Samsung LE32B450. After the TV has been on for about 5 minutes, when you change channel the screen goes blank and the sound goes off. However, the TV is still on as pressing the power but
Just do a hard reset to this set and check. Unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so. This must make it a hard reset.
Jan 12, 2013 | Samsung LE32B450 32 in. LCD TV
CAfter the JVC model LT-42E910 is on for 10 minutes, the picture goes blank/black, but I have sound. I must turn off the tv and turn it back on every 5 minutes to get a picture. The tv is 4 days old.
It is a new tv.Take it back where u bought it and trade it in for another tv.This tv have those 2 LCD long inverter boards have problems.These 2 long LCD inverter boards are to help the tv LCD screen panel to have a backlight for the tv LCD screen to produced a picture.
Jul 07, 2011 | JVC LT-42E910 42" LCD TV
Dynex 32" tv picture goes black
If there is still about ? 24. Volts coming from the Power Board when it goes dark, it will be the Inverter board that needs replacing. If not, it is the Power Board that needs replacing. The Voltages should be written next to the sockets & plugs on the Power Board.
Jun 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Screen goes blank but come back when TV is turned off and back on
Ur tv LCD inverter board it dead.Replaced this LCD inverter board ur tv picture will return.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
May 13, 2010 | RCA L32HD32D 32 in. LCD HDTV
Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
Apr 30, 2009 | Sharp Aquos LC-C3234U 32 in. LCD TV
Advent 32" tv flat screen
It's likely one of two things. There are drive transistors on the CRT board which control the output to the guns, the one that controls the red gun may be open, also check this board for burned resistors. It could also be a bad picture tube although this is less likely. If it is the tube, replacements if available are fairly expensive.
Oct 17, 2008 | Recoton Advent Advent Q2035A 20" TV
Picture goes into multi coloured vertical lines
have a tech check your tv your problem is in the video circuit could be a cold solder or a component is damaged and need to be replaced.good luck.
Apr 15, 2007 | Philips 32PF7320A 32 in. LCD Television
Recoton Advent Advent Q2035A 20" TV Logo
176 people viewed this question
Top Recoton Advent Televison & Video Experts
S. Gontko
Are you a Recoton Advent Televison and Video Expert? Answer questions, earn points and help others
